Question about HomeTech HT503 Main / Stereo Speaker
Wiring speakers to volume control
What is the wiring config for the Hometech HTVC 150 volume control?
Installed a pair of NS-OS112 speakers on our patio. Also installed a legrand AU0050-WH-V1 volume control. Speaker volume is too low. Can you hel us?
how are powering these speakers? Iff you are coming of speaker out on amp try turning volume up. Did you wire the speakers on series. If you have a multimeter disconnect speakers and measure resistance. The reading should be 8 ohms on each speaker wiring, if it is 16 then you have the speakers in series and the volume will low. Post back and wi
Apr 22, 2017 | Legrand Audio Players & Recorders
Need a wiring diagram for fuel injector harness for 1987 F-150 4.9 inline 6 motor
Hello Chuck Burdine,
Your answer (close 1988) awaits at the bottom... When I don't have an answer... I wait out the world... until I find it...
(consequently I have a couple of beautiful cars 20 years waiting for proper attention (yeah... stubborn)).
Maybe this will help.. BBB Industries (below: bbbind.com)
I found your UNANSWERED question...misplaced in wiring...
Loving house and cars... (both: I don't care).
I thought this one might finally deserve an answer...
My VERY BEST RECOMMENDATION FOR YOUR vehicle's
reference documents are the $100- $150 (new paper bound volumes... much cheaper on CD... but I don't like them,)
FACTORY+WORKSHOP+MANUAL... (Volume 3 (electrical)).
I used to have an awesome master mechanic... AND the worlds foremost parts authority (from Cirimele Ford (Oakland, Ca.))...
In 1970... before restoring '65 Mustangs was popular... these guys helped me pull ALL the right PARTS &Techniques.
AFTER that I had to buy the books...!!!
Hope this helps you... 34 Technical service bulletins, and exquisite circuit drawings!!
http://www.bbbind.com/free_tsb.html
also look at:
CHILTON BOOKS 26664 Repair Manual Ford F150 F250 F350 Super Duty Bronco 87...
https://www.tzarmedia.com/signup?ad_domain=ads.ad-center.com&ad_path=%2Fsmart_ad%2Fdisplay&prod=2&ref=5044641&q=1987%20Ford%20F150%20Truck%20Wiring%20Diagram&seed=3410948014&utm_source=bocdoo.com&utm_medium=referral&placement=http%3A%2F%2Fbocdoo.com%2Fdownload%2F1987-ford-f150-truck-wiring-diagram.pdf&adserver=0.18.4-rc1&sf=eone&m=books&sfv=11&_sign=6489ea2c7e86986d18e01f555e247d26&_signt=1460064133
87 ford pickup wiring volume 3 Bing images
Dec 14, 2014 | Electrical Supplies
Jvc rx 5052 overload when volumes open
Could be....
  1. There's a short in your speaker wiring somewhere
  2. or a blown speaker
  3. or you are recycling the speakers from an old all-in-one system and they're too low Ohms
Check your speakers first. If they are less than 8 Ohms, or there's no label on them which gives the Impedance (in Ohms) then I'll lay money that they aren't suitable for the amp. Stop using them and get some proper 8 Ohm speakers.
Wiring shorts might be only a single strand of copper wire. But it's enough that at higher volumes it conducts enough current between the speaker terminals to trip the amp's protection mode.
Fix the problem. Go through your wiring. Check using a torch. If all looks good then it's a blown speaker.
Remove the speaker wires from the amp. Switch the amp on and turn the volume up full. The amp should stay on. Turn the volume down and switch off.
Now connect ONE speaker only. Try the amp on and volume up again. If it trips out then that's the faulty speaker. Repeat by adding one more speaker each time. When the amp trips, the last speaker added is the culpret.
Sep 08, 2014 | Audio Players & Recorders
On Screen Volume Adjusment
go to control panel and pick sound icon, tick the box that says display in taskbar.
Jul 09, 2014 | Acer Aspire 5500 5570-2609 Laptop
Codigo del control remoto universal para hometech
0390,0399,0391. Try these codes. If you wish to get more codes and other details check:
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
Both the sites have setup code list, and setup procedure to many popular brand remote controls. Check the site in 'Mosaic' view. It will make search easy.
Jan 09, 2014 | Televison & Video
My Kenwood RC-150 Learning Remote. How do I delete a programmed key
Remove the batteries and let the remote sit idle for a time until retained memory fades. Reinstall the batteries and start over again.
Nov 16, 2013 | Kenwood Remote Control RC-150...
My cisco ip phone 7905 series is rebooting continuously
the reason for this would be that it is not getting it's config from the CallManager (or CME router).
The steps in a phone booting up something like this:
1) DHCP for IP Address, and Option 150 for TFTP Server
2) TFTP to address provided by DHCP Option 150
3) Get config file, a(an upgrade of firmware may occur at this point)
4) Connect to Call Manager/CME as specified in config file
First check DHCP server to see if it is allocating an address to the MAC address of the phone
Second confirm if DHCP is providing Option 150 and that is the IP Address of the TFTP Server (typically one of your Call Managers)
Third check that the phone is correctly configured on CCM/CME. A common error at this stage is that the phone is configured with the wrong model type.
Call back if you get to that stage and are still having problems.
Cheers, Simmo99.
Jan 03, 2011 | Cisco 7905 IP Phone
Volume control issues
MMmmm, I'm doubting this has anything to do with wire. Can you test that theory by wiring one speaker with each type / length of wire and getting the same reslults?
Define the speakers and the amp for us.
Feb 02, 2010 | Audio Players & Recorders
HomeTech HT503 Main / Stereo Speaker Logo
267 people viewed this question
Top HomeTech Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a HomeTech Audio Player and Recorder Expert? Answer questions, earn points and help others
