Question about Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher
Whirlpool gold dishwasher
The blade was stuck, so I took it apart. All went well except there are two white plastic balls now floating in the basin. Are these parts or have they just fallen inot the washer??
Thanks
    President:
  • Whirlpool Master
  • 2,651 Answers
Yes they are part of the assy. and need to be put back to function . whatever level of dissaslby you were at when you found them is where they belong. you can see by flipping over the last removed plate a little chanenl where it looks like the balls would go( the d/w fills with water and diff. pressures hold them against or push them down) depending on operation.they go in seperate openings as well
Posted on Mar 29, 2008
Water not draining from basin Whirlpool gold GU2700XTSQ
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
Mar 20, 2011 | Whirlpool GU2700XTSB / GU2700XTSQ /...
Took apart to clean because it would not drain. 2 plastic balls popped up from who knows where. where do they go ?
hi if these balls apeard when you took the pump apart they may be part of the anti syphon device.****
Dec 02, 2010 | Kenmore Dishwashers
Our dishwasher will not drain. We took the drain hose off, it is clear. So we dismanteled the botton thing in side the washer. Cleaned all the lime disposits and other ****. There were two little bead...
Pull out your dishwasher
Lean backward about 45 degrees
A small amount of water is coming out
put your appliance at its original position
Now it will be working
(normally there is a floating valve under the bottom of your appliance which has been stacked and sends the signal of no water flow.)
In case that it does not function, then there is a hard work to clean the plastic "labyrinth" which normally is fixed at the left side panel where a floating valve has been stacked a cause of dirty material.
Jul 29, 2017 | Kenmore 24 in. 17012 Built-in Dishwasher
Water will not drain. Motor is working. Drain does not appear to be clogged.
GE has equipped many of their dishwashers with a crappy anti-syphon ball. The problem with this is that they often relocate and clog the drain. To fix it, syphon all the water out of the basin of the diswasher and remove the kick plate. Open the dishwasher and remove the 1/4" hex head screw behind the food screen and remove the spray arm by prying the plastic clip on the back side (be careful not to break it). Then remove the two 1/4" hex head screws in the plastic basket and remove it. Remove the two screws that hold the dishwasher to the countertop and slide the dishwasher out. There is a large manilla colored hose with a huge hose clamp on it. Have plenty of rags on hand because this part gets messy. Remove the hose clamp and pull this area open. A small white plastic ball should roll out. Replace the hose clamp and slide the dishwasher back into place (clean up all the water that escaped first, and make sure you have turned off the power to the dishwasher before beginning). Drop the ball into the small tube on the left side under where the plastic basket goes. Installation is reverse of removal.
Aug 03, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
Whirlpool is showing err 4 which is water overfill but there is no water is the bottom of dishwasher
Is the float stuck in the top position? There should be a raised plastic dome inthe front corner. Pop that cover off and check for free movement of the float. If the washer 'thinks' there is high water from that float, that error message will occur.
Jul 07, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
GE profile dishwasher gsd5130d00ww does not pump all the water out of the basin after each cycle. The pump runs at a very low flow and only removes a small portion of the water. the basin screen and sump...
I believe this unit has an anti-siphon ball that is equipped to prevent back flow. Pull the dishwasher out and syphon the remaining water out. There is a large manilla colored hose that elbows from the back with a large hose clamp. Loosen the hose clamp and pull the hose free, you should see a little white ball come out. Put the hose back together, remove the spray arm (there is a plastic clip on the back, use a small screwdriver to pry it free but don't break it and a small 1/4" head screw for you to remove). Remove the two 1/4" screws from the food trap basket and remove the food trap basket. Drop the ball down the tube that is roughly the same size and reassemble the reverse of removal.
Jul 06, 2009 | GE Dishwashers
Stuck on clean light always flashing
There is something jammed in either the arm or blade that is setting off the code.
Jul 01, 2009 | Whirlpool 24 in. Portable Dishwasher...
Kenmore dish washer wont drain
Those are Chinese massage balls. You place them in your palm and rub them together and the result is a "calming" effect, which are ingeniously placed their by the courteous engineers at Kenmore to help you relax while you perform the self-repair. Just kidding. I had the same problem and learned that they are called "float balls". There should a small hole where the water comes up and drains - they are placed in that hole.
Nov 14, 2008 | Dishwashers
Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher Logo
265 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
