Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
I have a tfx30pb refrig with a cracked tubing at a blue valve in the back. I purchased new tubing but how do I get to the inside of unit to the other end of the tubing to replace it? The access panel doesn't have room for my hand to follow the line.
3 Suggested Answers
  • 126 Answers
SOURCE: Leaky Water Valve Inlet
The part number for the valve for a pss26msrss is:
WR57X10032 it is around $45.00-$50.00. There are several look ups available but you need a complete model number that you will find on the refrigerator usually inside upper fresh food section. you can order at repairclinic.com, sears .com ... or you can google appliance parts and see what you come up with. You might also try a local appliance store. Good Luck.
Posted on Jan 08, 2009
  • 531 Answers
SOURCE: water does not dispense from unit,but goes onto floor from inside
the water line is cracked
Posted on Apr 07, 2009
The ice maker is not working anymore and the light inside the freezer is flashing red.
Do you have water at the dispenser?
The water tube to the icemaker inside the refrig is frozen up. Thaw out with your hair dryer. To make sure the tube is clear. Shut of the water to the refrig, disconnect the inlet water line to the icemaker. Insert a flexable through the connector fitting, I used a zip tie. The flexable item should go all the way to the icemaker
Solution #2 Replace the "water inlet valve" at bottom back right of refrig. Easy To Do.
Jun 06, 2010 | KitchenAid Superba KSRG25FK Side by Side...
Ice maker stopped working. the water and ice dispense from the door, but it does not make any NEW ice...
Jun 06, 2010 | GE Profile PSW26P Stainless Steel Side by...
Ice maker does not make ice.
The water tube to the icemaker inside the refrig may be frozen up. Thaw out with your hair dryer. To make sure the tube is clear. Shut of the water to the refrig, disconnect the inlet water line to the icemaker. Insert a flexable through the connector fitting, I used a zip tie. The flexable item should go all the way to the icemaker
Jun 06, 2010 | LG LMX25981ST Stainless Steel Bottom...
Ice maker not working on model #frs24zsg
The water tube to the icemaker inside the refrig maybe frozen up. Thaw out with your hair dryer. To make sure the tube is clear. Shut of the water to the refrig, disconnect the inlet water line to the icemaker. Insert a flexable through the connector fitting, I used a zip tie. The flexable item should go all the way to the icemaker
Jun 06, 2010 | Frigidaire FRS3R5EMB Side by Side...
Kenmore model 79578502800 refrigerator error code 1F. icemaker does not work
Jun 05, 2010 | Refrigerators
Water leaking from top rear left of refrigerator and dripping on coil line in the back of unit. Inside is dry and no water on floor yet. Is it the ice maker connection? If so how do I access it?
You will have to remove the ice maker , to have access to the fill tube . Only 3 screws , hold the ice maker on . After removing , make sure the tube is not frozen inside , and that it is securely , pushed inside the fill tube holder . If frozen inside , then the water valve behind the refrig , where the wall water line connects to , on the refrig , will need replaced also , due to " seeping " , not closing completely , after filling .
Dec 20, 2009 | KitchenAid Refrigerators
The canister that holds the water filter in my whirlpool refrig. is leaking .model# ed5fhgxkq03 . the 2 tubes coming from the back may be the problem .can they be replaced.
Check the filter itself , around the end inserted into the housing , to see if it is cracked . I recently install a new housing , due to water leak , and turned out to be the filter itself which was cracked . But , yes , the 2 lines can be purchased from any hardware store ( this type of tubing ) . Just cut a small piece and take with you , so you can get the correct size (s) . Doesn't have to be strictly refrigerator tubing .
Sep 19, 2009 | Refrigerators
WATER DRIPPING FROM BACK
I assume its on the refrigs side? Either the water valve "blue thing" is cracked or broken or the water line hooking up to it needs an new washer and or tightening.
If this helps you please rate me as high as you can and or get back to me. Thanks for using fix ya.
May 06, 2009 | Refrigerators
Water leaking from bottom of unit
For original poster: Check all milky white colored (polyethelne) plastic water lines. These lines tend to get brittle and can crack over a period of time. They extend from the water valve to the ice maker, and from the water valve to the inside of the refrig to a "radiator" so the water can chill, before it runs back out the refrig, past the left side of the refrig behind the bottom grill, through a coupler, and up through the bottom hinge of the freezer door. I'd also advise putting in a separate shut off for the water supply to the refrig so you can have water to the rest of your house when you have a problem with the refrig.
For next user with similar problem: you can check the above, but it may be that the defrost drain is plugged. (on a S x S unit, it is located at the bottom of the freezer compartment, behind the back wall.) If you have a layer of ice on the floor of the freezer, that's a dead give away of a blocked defrost drain tube, Use a turkey baster with hot (not boiling) water to flush it out.
Aug 31, 2008 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
Refrigerators Logo
210 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
