Question about Dynex DX-LCD32-09 LCD TV
Dynex dx-lcd32-09 vertical colored lines. After tapping on back of tv lines go away, feels like loose wire, but tech said need to replace board. Will work off and on, not really dependent upon heat. Like loose wiring. What could it be and how much for a main board.
    Genius:
  • Dynex Master
  • 1,550 Answers
The video Ic are some solder cracked,resoldered but you need to send to a repair shop
Posted on May 10, 2010
Turn on tv ad see vertical colored lines with thick black line i middle
If you are a tech or know something about lcd tvs, lvds connector from main board to Tcon board needs to be cleaned. Connector and flat cables from Tcon to lcd panel are also to be cleaned. Good luck
Feb 10, 2015 | Dynex 32 in. LCD Flat-Panel HDTV
Screen freezes
the electronics are failing after it has got warm. Replace the TV.
Dec 15, 2013 | Dynex DX-19L150A11 720p 60Hz 19in Flat...
Dynex dx-40L261A12 won't turn on. Red power light is on, but no sound from speakers and no picture. Remote power button and power button on tv doesn't turn the tv on.
In this case, the symptoms you describe is a faulty inverter board. The TV will or should flash "PLEASE WAIT" and then you have a black screen no audio. Find Shop Jimmy on line. Enter your TV model number. You will find an inverter board for $24.95 plus $9.50 shipping. When you remove the back cover of the TV, look to the left. You will see a long vertical board...this is what you will replace. Thanks for asking, Matt of Martins TV Repair.
Oct 15, 2013 | Dynex DX-L42-10A 42 in. LCD TV
Half the screen doesn't work. It goes black sometimes, and sometimes that same half, the right side, has vertical color lines. The tv is only 6 months old. The problem actually went away for a while...
You need to go into the back of set and look for the wire connection to the board that is top center (looking from the back of the set). The wire plug will be about 1 and a half to 2 inches wide with several wires on it. Carefully unplug the wire going to that board and take a pencil eraser and clean the contacts gently and carefully. Plug it back up. The wire mentioned will come from the main board (with all the jacks and connections).
Jun 23, 2011 | Dynex DX-LCD37 TV
My flat screen tv has different colored horizontal hold lines across my screen. Where is the button for horizontal hold?
Those colored lines are a bad panel. Is no button to make them go away. The only fix is to replace your panel. Would be more cost effective to replace the TV.
May 06, 2011 | Dynex DX-LCD37 TV
I have the dynex dx-lcd32-09 model tv.One day I was watching ashow on tv and all of a sudden the picture went white,But can still see the image.I tried everything from turning it on and off to back on...
The T-con also called LCD contoller board needs to be replaced. You can check this link to find the part for your LCD. This board is located in the upper middle part on the screen under a metal shield.
I would suggest to contact them first before order the T-con board.
Sep 14, 2010 | Dynex DX-LCD32-09 LCD TV
Dynex LCD Tv with a single colored verticle line on the screen.
That is either going to be something simple like a connector being dirty or not seated correctly or a problem in the monitor itself.
Unplug and reconnect the cables a few times.If you are lucky this will fix it. Usually however this indicates a problem either in the video section on the monitor board or a panel edge connector problem.
Check if you have any warrenty left as this will be covered. Keep in mind that repair costs if you pay for them will be a good chunk of buying a new replacement.
Dec 30, 2009 | Dynex DX-LCD19-09 19 in. LCD TV
I have a DYNEX 32 lcd tv DX-LCD32-09 that was manufactured in 02/09. I have audio but the picture is only vertical colored lines. It was given as a gift and I cant get the receipt or it would be under...
The vertical lines from the top of the screen all the way to the bottom of the screen is the sign of the bad LCD panel, you need to find the receipt.
Nov 05, 2009 | Televison & Video
Dynex DX-LCD32-09. tv was working fine, then out
This type of failure could be in the LCD controller board or the power supply might not be providing enough voltage to the main board and LCD controller.
Let me know if you require further assistance locating the boards or part numbers.
Sep 28, 2009 | Dynex DX-LCD32-09 LCD TV
Horizontal lines and color problems?
this could be a format issue. When you change the channel do the lines go away ? If so try to go into the cable box (assuming you have a cable box) and reset your formats and exclude the format causing the lines.Make sure if your using component cables all colors match up.If this does not fix it replace your component cables/hdmi.All else fails unplug your TV wait 5 min. and plug it back in. Hope this works for you.
Jul 08, 2009 | Dynex DX-LCD32-09 LCD TV
Dynex DX-LCD32-09 LCD TV Logo
1,159 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
