Question about Kenmore 22512 Bagged Canister Vacuum
Belt won't reset
Trying to get the bottom plate off so we can see if belt needs replaced. Have removed 5 screws, but bottom plate will still not come off?? HELP
It is the Kenmore canister model 116 Intuition Quietguard.
SOURCE: Kenmore canister model 116
The top plate encloses/covers the lilght.
Posted on Mar 02, 2008
VacuumRepair
  • 438 Answers
SOURCE: Belt broken a a Kenmore
Greetings from GoVacuum.com,
To properly fix a belt on a Kenmore vacuum, you will first need to indicate whether this is an upright or a canister vacuum. The model given, 116, is only the first part of the model number, and all Kenmore vacuums, upright and canister style, start with 116. There is a period first, then a whole string of numbers, 116.255553 etc.
Kenmore vacuums are mainly made by Panasonic for Sears, and most will use a Panasonic belt. If the belt is an upright, this makes it simple, and will be a Panasonic "UB" belt.
For a canister vacuum, most models use what's referred to as a cogged belt. This type of belt has little teeth on the inside of the belt, and is Panasonic CB-5 belt.
Instructions on How to Replace the Belt for an Upright;
There will usually be to plastic screws on the top of the agitator housing on the base of the vacuum, that will say belt access. Simply take a flat head screw driver, and turn the screws so that the screw is pointing up and down on both sides. Then pull the plastic agitator housing, or the top of the base of the vacuum off. Inside you will see a the roller brush, and the belt (or broken belt). Simply take the new belt and wrap it around the silver pulley located in the back of the machine, opposite the roller brush, and wrap the other end of the belt through the roller brush. Stretch the roller brush back into the housing of the machine, and replace the top of the base of the vacuum back on the machine. You should give the belt a tug, to ensure that the brush is spinning when the belt is being pulled.
Feel free to email me if you have any further questions, I'd be happy to walk you through it, or even shoot an instructional video to show you how you to replace it. My email is chris.jones at govacuum . com.
Chris Jones
GoVacuum.com
chris.jones@govacuum.com
Posted on Oct 01, 2008
provactek
  • 17 Answers
SOURCE: belt broke, can't get bottom off
if it's the one in the picture then pop off the light cover by gently pushing in and prying on both sides . Remove the bulb by pushing and twisting , OK?, now see the 2 screws? take them out. now flip over the powerhead and gently pry at both sides toward the rear wheels.
Ta Daa!
Posted on Oct 02, 2008
SOURCE: Kenmore vacuum manuals
I tried what reddevil6 suggested and was not able to get Sears to produce a manual. I would prefer an online manual but at this point I'm desperate enough to try anything.
Posted on Oct 05, 2008
  • 70 Answers
SOURCE: Kenmore 3.9 with power-mate Model 116 2839581.
You have to take off the top of the power nozzel that has the light lense. There are two pressure locks,one on each side. Use a screw driver to release. You will see the screws.Take the two screws out and on some models, there are two pressure locks on the back of the nozzel. Again use the screw driver to release. The top should come right off.Hope this helps.
Posted on Oct 18, 2009
How to remove the belt
Most vaccumeing have 4 to 5 screws holding the bottom plate remove plate pull out roller . Slide it off the roller and motor replace with new belt by first slide belt around motor arm then roller pull roller into place then roll the roller 3-4 times to insure it's in the right spot. Replace bottom plate
Apr 11, 2015 | Vacuums
Replacing the belt for the motor
the brush roller lifts up and out. Just lift it out but your belt around the roller and belt shaft and push the brush roller back down. I own one too.
Feb 18, 2015 | Oreck XL Ultra Bagged Upright Vacuum
How do I replace the belt for this model
Make sure vacuum is not plugged in to power outlet. Lay it upside down and remove 4 screws from bottom plate covering brush roll. Remove bottom plate and pull the brush roll out. Clean hair and debris from brush roll and make sure it spins freely. Remove end caps from brush roll if possible and clean debris out. Install new belt around motor shaft then insert brush roll into belt and pull on brush roll to give you enough leverage to stretch belt far enough to put. Brush roll back into position. Reinstall bottom plate and screws. Make sure brush roll will turn before turning vacuum back on. Belt will lose elasticity and should be replaced twice a year.
Jan 17, 2015 | Hoover U5434-900 WindTunnel Plus Bagged...
HOW DO I CHANGE BELT ?
Hello! Below are step-by-step instructions for changing the belt on your Hoover S1147.
1. Rotate nozzle to the vertical position. Lift off front cover.
2. Remove the two bottom plate screws.
3. Pivot off bottom plate making sure to unhook center tab on inside edge of nozzle.
4. Remove agitator and used belt from nozzle.
5. Put new belt on agitator. Position agitator in nozzle orienting agitator end caps with slots on both sides of nozzle. The belt should line up with tab on inside of nozzle.
6. Attach belt to motor pulley.
7. Replace bottom place by first hooking it to center tab on inside of nozzle.
8. Reposition screws and front cover.
Hope this helps!
Jun 02, 2014 | Hoover S1147 Twist Vac Handheld Vacuum
The beater motor will not turn. Is there a fuse? I've tried the reset, but this still doen't work. My wife smelled a burning smell and quit using.
Sounds like you need a new belt.Turn it upside down and locate the screws on the bottom.Remove those screws,and then the plate they hold on(if there are no screws then the plate will be held by clips just pull it off,carefully.The brush now may be lifted out,but before you do.The belt fits around the brush.Find which side,if the belt is broken and still in the vacuum,it should still be on the side it came from.If the belt is not still in the vacuum,there is a groove in the brush about one inch wide.That is where the belt fits.The other end of the belt fits on a small wheel about 4-5 inches back from the brush.There may be a small plate over the belt and wheel if so just remove it and you will see what I am talking about.
May 17, 2011 | Eureka Capture Upright Vacuum Vacuum
I cannot find my owner sheet and need to change the belt in my upright oreck
THERE IS A SINGLE SCREW ON THE SIDE OF THE VAC KNOWN AS THE 'BELT DOOR'.
LAY VAC ON IT'S RIGHT SIDE, SO THE BELT DOOR IS STICKING STRAIGHT UP IN THE AIR. REMOVE DOOR AND BELT DOOR. CUT OLD BELT IF IT IS NOT BROKEN. TUCK NEW BELT UNDER BRUHROLL PULLEY FIRST THEN STRECH OVER MOTOR SHAFT.
DO NOT REPLACE BELT BY REMOVING BASEPLATE. 1) THE MOTOR IS NOT STABLE ENOUGH FOR THE TIGHT BELTS WITHOUT THE SUPPORT OF THE MOTOR 2) REPLACING BASEPLATE IMPOPERLY MAKES VACUUMING DIFFICULT. ">
Feb 18, 2011 | Oreck XL21 Bagged Upright Vacuum
I Need to change the belt on hooverwhirlwind
there should be 4 screws on the bottomsome have little flat snap that secure the bottom cover on.push the snaps toward the outside of the base and the cover should come off.if they are screws just remove the screws and take off the bottom plate.then you will be at the belt and roller.be sure to clean the old rubber off the motor shaft before you put the new belt on.otherwise the new belt won't last long
Apr 10, 2009 | Vacuums
I have a Hoover TurboPOWER 7300 Windtunnel V2-belt change
1. Remove the 4 screws holding the bottom plate.
2. remove roller and old belt
3. install new belt on motor spindle first and then on roller.
4. pull roller, stretching belt, set into roller cavity.
5. turn roller by hand to center belt.
6. reinstall bottom plate.& screws
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Feb 26, 2009 | Hoover U5444-900 5100 Wind Tunnel 15 Inch...
Installing belt
here are the step by step instructions from the owners manual for your machine.
Disconnect cleaner from electrical outlet. WARNING: Agitator brush roll can start suddenly. Unplug cleaner before turning it over. Replacing Flat Belt Place handle in low position and turn cleaner over so bottom side is facing up. Remove the 6 screws as shown with a Phillips screwdriver. Lift off bottom plate. Replace belt if it is stretched, cut or broken. To check the flat belt. Removing Bottom Plate Removing Belt Positioning Belt Remove used belt from large pulley and discard. Reposition bottom plate and 6 Phillips head screws. Tighten screws securely. Insert agitator brush roll through belt and position belt in groove (A) on agitator brush roll. Inspecting V-Belt The V-belt is designed to last for a long time and is not normally replaced. However, if the V-belt is cracked, gouged or broken, it should be replaced. Slide flat belt off large pulley. To remove V-belt, slide back of belt over pulley (A). Then firmly pull on belt and “snap” it out. Discard used belt. To install new belt (with lettering on outside of belt), slide back of belt over pulley and pull front of belt toward groove next to pulley. Belt will “pop” into place. Flat Belt: What to Buy Use only genuine HOOVER belts with your cleaner. When purchasing a new belt, ask for Flat belt - HOOVER part No. 40201-271. V-Belt: What to Buy Use only genuine HOOVER belts with your cleaner. When purchasing a new belt, ask for V belt - HOOVER part No. 40201-200.
If you can't get the answer from this post, send me a message and I will try to walk you through this. I hope it helps.
Jan 19, 2009 | Hoover Windtunnel Supreme U5280-900...
I can't figure out how to change the belt on my hoover bagless Sprint upright. Please help.
1 set up vacume with bottom facing you , making it easy to deal with.
2 remove the 4 screws holding base plate on and carefully remove the base plate, on mine there is a small catch that must be released.
3the belt compartment is on the right, remove the old belt, it's about 1 and 1/4 wide.
4 You have to put the belt on the stainless steel motor spindle first, then work the belt over the plastic drive wheel, and spin it around a few time to ensure it's running on track ok.
5 Replace the base plate , click in the self catching clip last.
6 Replace the four screws and test the vacume.
Oct 23, 2008 | Hoover Vacuums
Kenmore 22512 Bagged Canister Vacuum Logo
144 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
