Switcheson fine but does not accept paper
Switches on fine but does not accept paper
    Genius:
  • 1,218 Answers
Does it run in reverse???? Does the motor work.???
If it runs in reverse then the motor is probaly OK....does your machine have "eyes" that automatically start the shredder when the paper is inserted??? if it does then they may be "dirty/dusty"...try cleaning them ; if that dosn't fix it then you may have defective "eyes" or defective pcb.
Posted on Aug 29, 2010
Overload light stays on
Most likely the cutters are still stuffed with paper shreds and needs to be dismantled and cleaned
Mar 29, 2014 | Honeywell Seven Sheet Micro Cut Paper...
Using Win7 - switches to NLQ mode every time regadless of driver used - Okidata Elite (Microline) 520, Okidata Elite (IBM) or Okidata 520. Tried changing drivers - none other available for Win7. With the...
This is a SNIP of a rather LONG FIX:
Found here:
http://forums.windrivers.com/showthread.php?7080-RESOLVED-Okidata-Microline-184-Turbo
"Just purchased this thing and am running it a machine to print checks with (Win95, p1-200, 48 Mb ram). The Oki dot matrix printers don't give you drivers, they tell you to use the drivers from Win95 disk. Sure... (just lazy if you ask me :-) OK using the Oki Microline 184 IBM Turbo driver the thing works fine, EXCEPT that it *always* prints in NLQ mode no matter what the settings in the control panel, it just switches to NLQ before each print job. So... we switch to a "generic text" driver and it works fine that way EXCEPT that it no longer recognises the custom paper length (8.5" wide X 7" long) Now here's the wierd part... IF I switch back to the win95 driver, re-accept the custom paper size, print a test page (in NLQ of course), switch back to the generic driver, re-accept the the custom paper size, switch the printer to normal (non NLQ), and print it works fine with the custom paper size and non-NLQ mode until the next time it needs to print. The printer remains ON 24/7, so its not reseting itself. It just seems that with the Win95 driver there is no way to set it to print in anything but NLQ AND the generic driver refuses to keep the custom paper sizes in memory. Anyone seen this before? Never came accross this myself. I may just end up sending this thing back and getting an Epson or someting else."
AND THERE IS THIS:
"This is like going back to the dark ages....most of those old impact printers had dip switches to set things like default print quality. Additionally, Oki's usually came in two 'flavors'--plain Oki and IBM Oki. It's important that you install the correct driver between the two options..."
Anthony
Dec 25, 2017 | OKI MICROLINE 520 Matrix Printer
When i use card stock it acts like a paper jam,with a little help it prints fine
Make sure that you are setting the proper paper type before printing any paper other than "plain" by going into the printer's "properties/preferences". If it's thick paper, choose "thick" or "heavy" or "cardstock" in the drop-down arrow.
Unless, of course, your printer doesn't accept cardstock at all, then you're out of luck.
Hope this helps. :)
Sep 29, 2010 | Dell Office Equipment & Supplies
Paper switch flashing and would not feed paper
This may be because your paper had lost its temperature. Papers should have a minimum temperature to be accepted by the printer. papers exposed to atmosphere for a long time may not have this required temperature. You should try to keep paper inside some drawers or something and take out papers only when it's actually needed.
Mar 27, 2010 | Computers & Internet
Can't print on colored paper but will print fine on white. How do you set it to accept the colored paper, which happens to be blue?
The printer can't differentiate between the colour, but it may have problem if the couloured paper is thicker than the white stuff that you're using.
Dec 06, 2009 | HP Photosmart D7160 InkJet Printer
I have been using my shredder heavily in the last 30 minutes. I have had to stop twice for it to cool down. It was working fine, and now it won't accept paper. The cutters are turning fine. It is not...
Most shredders don't recommend use for more than 20-25 sheets in a session. Try using the reverse setting; even though you can't see paper, it's possible that there's some still in the feed channel. If after switching to reverse paper comes out, inspect the feed channel for more paper and clear any you find before trying to feed more sheets. Also in the future, constant use as you've described will burn out the motor.
Nov 16, 2009 | Tech Solution TS-4500 Shredder
Won't Accept Paper
sometimes you will have to clear the printer memory to get rid of this error.
Definintely make sure paper isn't stuck in the tray or rollers or any where else
1) make sure the print job queue is empty.
2) UNPLUG (don't just power off) the printer.
3) leave the printer unplugged for about 3 minutes
4) plug printer back in and try to print again.
Please let me know how this works for you.
May 31, 2009 | Canon PIXMA iP1600 Printer
5300 won't load 8 1/2x 11 photo-weight paper.
''grabber'' roller out of work sometimes, you may try
1) there is a input paper sensor around roller, the roller out of runing if the sensor is not senitive enough or sensor switch dirty,
clean the sensor as you can find it,
2) Lighter-weight paper feeds and prints fine, which means this paper input sensor works ok, but you need to make sure they are same paper input sensor,.
3) the paper surface bright and the roller worn could be cause paper feed fail, you need clean the roller anyway. still not fixed, you need to adjust the roller pressure by increase the spring force.`
Feb 07, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Fellowes P600C-2 Motor runs in reverse, but not forward
On mine a tooth broke from a drive gear. I am trying to find somewhere where I can replace this part.
Oct 25, 2007 | Fellowes P600C-2 Shredder
117 people viewed this question
k24674
jasbo
jasbo
