Question about Toro Lawn Mower With Toro Power Tools
Front wheels quit pulling
I have a Toro Walk behind self propelled-Front wheels, they quit pulling. I have replaced the belt but that didn't do any good. Any Suggestions??
    Sniper:
  • 53 Answers
Ya most likely the lever that you normally squeeze to make it "go" has a cable. Cables stretch just like belts. If you replaced the belt already then that automatically removes any stretching that the first belt would have suffered from no doubt. Look at the drive lever's cable up at the lever end. There is usually a cable adjuster there. It will be a threaded shaft portion with a nut or knurled ring to spin. tighten up that "go lever" cable a bit. Even better, if you have visual access to the belt as you squeeze the drive lever, then you can see if squeezing that lever moves one of the belt's pulleys enough to cause it to tighten it up enough to transfer spin motion thru the belt to the other pulley. You see that whole system is really a "slip belt clutch" when belt is loose, no forward motion, as you squeeze the "go/drive" lever the pulley moves away tightening up the belt more and more. The tighter the belt, the less the slippage, the faster you go! But the slippage is necessary! ( That's the clutch component) If you simply had the belt tight all the time, the mower would always go full speed! It would be in full time "run away mode" LOL! so watch out. Once you see it in action...you'll get the idea no problem!
Posted on May 10, 2010
  • Ed Gore May 10, 2010
    Oh, on those front wheel drive types too, I forgot to mention this important fact! All of the above explanation about cables and belts could be academic. This is due to the fact that some of those front wheel drive types have "gear teeth" inside of them. Sometimes only one of the wheels are geared, other times both right and left wheels have them. So take a good look and see if any of those inner gear teeth are scratched or warn down, also the male gear that meshes with the teeth inside the wheels. If you start the mower and tilt it back just so the front wheels are off the ground an inch or so (BE CAREFUL! GET COMPETENT HELP YOU TRUST!) when you engage the drive lever, you should be able to "see" if there is a worn gear spinning in vain inside of one or both of the front geared wheels. If that is the case...then its definitely gear teeth you need to change and not belts or cable adjustments. Lemme know whats up.
I have a 1987 Toro GTS Self propelled walk behind mower- My question is that it runs fine but but seems to be slippling and can't get out of it's own way
  • Check for belt stretching even if it looks good. Next possibility
Is worn smooth, or oily surfaces on drive wheels. Can you tell if it slips on drive wheel, or those driven. Some Hondas have belt tensioners which can be too loose. See if axle on drive wheel is in a slotted, rather than round whole, meaning you could loosen/retighten while putting pressure on it to lengthen distance to driven wheels.
Apr 01, 2014 | Toro Garden
I have a self-propelled walk behind number and the wheels quit spinning and the mower becomes very difficult to push. I am so frustrated. The mower has only been used five or six times and is brand new,...
I would probably take it back to where I bought it to begin with. But, I have an old Huskavara mower self propelled, at times if I set it on top of two 4 x 6 blocks (6 inches up) I have to take off the wheels and clean up the axles using thinner, degreaser, or gas, anything to break down oil or dirt. Then I oil the surfaces and reassemble, and the wheels work for a while.
Jul 04, 2011 | Toro Lawn Boy Self Propelled CARB Walk...
I have a Toro self propelled walk behind mower model # 20016. The self propelled just stopped working. My owners manual does not mention anything about the self propell. Can you direct me as to what to...
Toro 20016 self propelled walk behind when the wheels are engaged it moves, when the wheels are not engaged, the wheels look up.
What should I do to fix the problem
Apr 19, 2011 | Toro Lawn Boy Self Propelled CARB Walk...
I have a Toro Proline walk behind . Problems with the self propel
I suspect the drive belt, not the Hydro. Especially if the drive belt was never replaced. The belts are known to stretch and wear out over time. It's a cheap part.
Jun 04, 2010 | Toro Lawn Mower With Toro Power Tools
Self propel toro mower will not "self propel", nor will it pull backwards
that dont make sense self propel is forward only release handel pull it back could have broke a belt on the pull or wheels are full of grass
Aug 29, 2009 | Toro Lawn Mower With Toro Power Tools
6.5 toro walk behind self propell b&s engine. self propel does not work
Try adjusting your self propel cable. A slight extension of the cable (1/4 inch) will double speed, so do a little at a time. Take the back guard off and clean debris 2 or 3 screws and it is just a cover so nothing will pop out unless that is your real problem. You should have grease fittings behind rear wheels so squirt 2 times with grease gun in each wheel and 1 squirt every 3rd mow.
Aug 05, 2009 | Toro Lawn Mower With Toro Power Tools
If you take the wheels off and remove the belt from the small pulley on the the front axle underneath the pulley you should see a small transmission. You usually can split this unit in half . You will see two gears and sometimes one plastic and one metal. The plastic one is usually the culprit. Hope this will help you out. Donnyb60
Mar 18, 2009 | Toro Lawn Mower With Toro Power Tools
Toro 20073 self propeled, walk behind mower-how to replace belt ?
Wait until the mower cools off
1. Remove the drive belt cover from the top of the mower
2. Tip the mower up, being careful to not go too far or the oil and fuels may spill out
3. Remove the mower blade - as I recall the bolt is 5/8" (could be 9/16") You will have to hold the blade from turning (if you have impact tools, this will be much easier)
4. Remove the blade
5. Pull the pulley out or off and remove the belt - be careful to not lose the crankshaft "woodruff" key - it's the little piece of half/moon shaped metal that keeps the pulley from spinning on the crankshaft.
6. Reverse the steps to reinstall
You MUST make sure the blade is tight when you reinstall it. Also, the blade usually fits over a couple of pins - make sure they are lined up properly and the blade is installed right-side up.
Mar 16, 2009 | Toro Lawn Mower With Toro Power Tools
Self propell toro mower will not "self propell."
Self propell toro mower will not "self propell", nor can i pull it backwards
Oct 03, 2008 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
544 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
