Question about Yard Machines Cultivator
The tiller starts then dies, can u help? - Yard Machines Cultivator
    Brigadier General:
  • 3,917 Answers
Hi
The air filter should be replaced. Also remove the old gas and put in new from the gas station.And if you didn't change the spark plug from last season, do that so as it is another cause that stalls your tiller.
Let us know if you want something more else please accept the suggestion.
Thanks for contacting fixya.com
Posted on May 10, 2010
Yardman 3.5 cultivater starts but dies when choke is opened
Most likely the Carburetor is dirty and needs a good cleaning
Apr 30, 2015 | MTD PRODUCTS INC yardman"" garden tiller"
My troy-bilt 8hp tiller starts and runs good but after about 3 minutes of tilling it dies
Could be a number if things..the filter may be pluged or restricted the fuel pump if it has one us going bad..or if it does not have a pump..and by what you are saying you might have dirt in the carb bowl causing the float that supplies enough fuel under power to stick. This will let enough gas to start and run but under power essentuliy run out of gas temperarly...the carb will need to be cleaned and adjusted..Hope this helps...good luck.
Sep 16, 2014 | Garden
My mantis tiller with a honda gx22 engine starts then shuts off after approx. 30 sec.
If your unit has a primer bulb, start your engine . When it starts to die push your primer, if the engine comes back to life you have a carb issue.
Aug 09, 2014 | Mantis Tiller 4-Cycle Engine Handy Item...
My mantis starts easily - but then dies. it sometimes doesn't even rotate. i can do about 3 seconds before it dies. help. what do i do?
The Carb is either cracked or needs to be rebuilt - OR - you might get luck and just blow it out with a professional dose of AIR from a larger compressor like used at mechanics shops.
Gary @ Fix Ya
Sep 05, 2010 | Mantis 2-Cycle Tiller
Tiller won't stay running
If you choke or prime the engine, it starts up for a second or two and dies, the carburetor need to be cleaned/repaired.
May 25, 2009 | Mtd Products Yard Machines 158CC Tiller
Dies out at high rpm
bolt on bottom of fuel bowl is actually a metering jet.take to lawnmower parts supplier to get replacement $7.00 appx.
May 08, 2009 | Mantis 4-Cycle Tiller
Ryobi Model 65020 gas tiller dies when engaging the throttle
sounds like you need to adjust the carburator
Apr 25, 2009 | Ryobi Cultivator
Craftsman tiller engine dies when I try to engage tines
tilt the back of the tiller up and check for a rock or stick wedged in between the tines and the shield
Mar 22, 2009 | Craftsman 8.50 Torque Rating Dual...
Craftsman Front Tine Tiller 6.0HP/26" -- can not start it
First check for spark, if you have spark than you can try spraying a little fuel into the carb and try to start it if it starts then dies its the carb
Dec 24, 2008 | Craftsman Garden
Yard Machines Cultivator Logo
232 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Phil Walker
Phil Walker
Dean Gruber
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
