Question about Fahrenheat Electric Convector Baseboard Heater, 240 Volt
I had a Dimplex electric heater installed. It has the built in thermostat with the button on the side. I wish to override the built in thermostat with a wall one. (I have a bad back and can't get down to the floor)I've connected the thermostat according to instruction, but it still just reads the built in one, and as soon as the heater shuts off, so does my wall thermostat.Any help?
  • 3 more comments
  • Kim Smith May 10, 2010
    how do I disconnect the internal thermostat? When I disconnect the wire leading from it, it won't turn on.
    The home I had the baseboard installed in is out of town, so I'm unable to get the model number but it is the BN series,if that helps any. There is no internet there yet so I had to wait to get back in town to ask.Will be going back in June, so I'm hoping to be able to fix this problem then.
    Thanks for all the help
    I have set the baseboard at a higher heat than wanted,hoping the wall one would override, but the heat remains on
    as mentioned earlier, I'm not sure how to disconnect entirely the onboard thermo.
  • Kim Smith May 25, 2010
    I still haven't been told how to disconnect the thermostat so the heater power remains on. when you disconnect the wire coming from the built in thermostat the power shuts off on both heater and wall thermo. model #6010015300
  • 2,427 Answers
Yeah you have to remove the inbuilt thermostat or at least disconnect it by cutting one of the wires leading to it..
Posted on May 10, 2010
  • Kim Smith May 12, 2010
    that was one of the first things I was going to do, but the problem is the thermostat control is also the power on. So when I disconnect the wire for the thermostat ,the wall one won't turn on
  • Kim Smith May 17, 2010
    so if the thermostat and the power on button are the same wire ,how do I disconnect the thermostat but leave the power on? When I tried disconnecting the wire that leads to the thermostat, the power for it shuts off which in turn then doesn't allow my wall thermostat to turn on
    Master:
  • 497 Answers
Did you make sure to unattach the Onboard Thermostat from the switching unit completely? And only have the Wall Thermostat conected to the Heater?
    President:
  • 2,501 Answers
If they are in series, then the one that is set the lowest will control the heater.
Set the built in theremostat to a much higher temperature than you want and the wall one should control the heater.
    Guru:
  • 415 Answers
I will work with you in helping you to resolve your problem. In order to better assist you, can I get the model number of your Dimplex electric heater?
  • 1 more comment
  • laura Newman May 12, 2010
    Vern,
    You should be able to disconnect the wires from the built in thermostat and wire them directly to your wall thermostat. In other words, we are taking the built-in thermostat completely out of the circuit and only using the wall thermostat to allow completion of the circuit to the electric heater.
    Should you have any questions, comments, concerns, please feel free to ask. :-)
    Disconnect the leads from one end of your old thermostat and connect thenew thermostat directly to the heater as the instructions provide. You'll have to remove the knob of the old thermostat and pull off the cover plate to get to the old thermostat connections. That should remedy your problem. :-)
  • laura Newman May 26, 2010
    Hi Vern,
    Disconnect the wires from each side of your floor thermostat and wire one side to one side of your wall thermostat. Wire the other side of your floor thermostat to your wall thermostat. You can leave the floor thermostat in place....just don't attach any wires to them. Hope this helps.
  • 4,924 Answers
The inside one is closer and this is the reason that it reads its temperature ...the issue will be that the wall one will read the room temperature ..so this should be kept in mind when used..the thing to do ..is to remove or disable the internal one ..by removing one contact with the main circuit ..and by pass with a direct wire ..you can even leave in inside for not to affect the rest ...if depends in structure...but the main issue is that it is just in a serial connection with the circuit ..and if you remove one contact ..you have to get the other end in contact with the one you removed..or ..if it has 2 wires in ..just get one from its place and put with the other ...This way you have disabled and bypassed the thermostat completely ..after that be sure the one in the wall its proper set...cause like I said will detect the temperature of the environment temperature and not the one near the source of the heat ..Good Luck!
  • Catalin Turcu
    Catalin Turcu May 10, 2010
    By the way ...another idea that got in my mind for you to try before you made any drastic changes...is to try and set different temperatures for the 2 of them ...Cause the on inside is closer...set it to a higher temperature ...and the one in the wall to a closer to the one you need in the room ...and see (if they both work ) what values you need to set in order for the wall one to interfere first in the controlling ...and shut the system by its setting ..
Dimplex club heater flicks on/off either on manual or using remote
It sounds like a dodgy thermostat or thermistor to me. When a thermistor goes wrong it can cause what is known as rapid-cycling in a heater, where the unit will keep switching on and off, on and off repeatedly.
May 28, 2014 | Dimplex Compact Electric Flame Stove...
Hi I have a Dimplex electric fireplace model# CS3311. I had the Remote Receiver plugged into the wall outlet and the Unit Plug was plugged into the side of the Remote Receiver, just like it says to do in...
Lisa, apparently there was an electrical overload in the receiver box. I assume this electric stove is new and still under warranty. In which case, armed with your Proof of Purchase, you need to contact Dimplex USA or the retailer you purchased it from.
Below is a link to Dimplex USA Customer Support.
http://www.dimplex.com/customer_support/contact_us
Feb 23, 2011 | Dimplex Compact Electric Flame Stove...
I wish to find a copy of an instruction manual for a Dimplex portable Evaporativeair conditioner - model Deva -13
Here's a link in pdf format for the owners manual for a DEVA-13 Dimplex Heater.
http://www.glendimplexdealer.com.au/Resource1049853HJDUFOS023X/Owners%20Manuals/Cooling/DEVA-13_IML.pdf
If the link doesn't work when you click on it, copy and paste it into your web browser.
Jan 18, 2011 | Dimplex DEC1000H Electric Heater
Where can I find replacement thermostat for Dimplex DGWH 4031 electric heater?
I have been lucky using Grainger they usually have these items in stock or can locate them quite quickly.
Dec 13, 2010 | Dimplex DGWH4031 Heater
How to install a wall dimplex thermostat to a dimplex fan wall heater /RDH2010tcw/1000/2000W/240
disconnect wire A from the thermostat, and connect it directly to one of the supply wires. Connect B and C to the other for 2000W.
Mar 03, 2010 | Heating & Cooling
Please help me to get the manual. dimplex thermostat, or i need help to stall my thremostat
Dimplex products are typically sold at most Home Depot and professional electrical supply houses. However, they rarely will have all the literature for those products in their stores.
Dimplex once provided an online list for all their heaters and thermostats, but no longer have the product manuals available on their website for customer download. They make both 120V-AC and 240V-AC versions and several different models, so I can't safely provide you with the wiring connections, since each installation is different and depends on the type of thermostat and heater(s) being utilized.
So now that I've given you the bad news, let's move onto the good news!Dimplex now uses an online request form for customers to get manual and literature on all their products. They'll send you the manual for your Dimplex product free, once you submint the request.
Here's the link to the request form for you to fill out and submit, just have your model number handy and you should be all set.
http://www1.dimplex.com/customersupport.aspx
Hope you find this Very Helpful and best regards!
Sep 18, 2009 | Dimplex Heating & Cooling
DF3015 electric fireplace insert- unit is plugged into power outlet but does not turn on.
The blower is controlled by a thermostat and will only come on when it's hot. If still does not come on check thermostat.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jun 28, 2009 | ACE Dimplex (r) Compact Electric Fireplace...
My dimplex night storage heater has stopped working.
...not too sure of your model but all dimplex heaters to my knowledge have an 'overload' cut out built into the system. Ours is more up to date but still goes now and then, problem is you have to get into the electrics and click the reset button, normally near or on the thermostat it's self, could be a small white plastic button, or a piece metal sticking up that needs pressing down to reset...but please before attempting make sure that you TURN OFF THE ELECTRIC / REMOVE THE FUSE/ WHAT EVER IT TAKES TO CUT ANY CHANCE OF AN ELECTRIC SHOCK!!!...because I can and will get you if it can ;-)... if your not a competent electrician please get hold of one !... good luck.
Feb 01, 2009 | Dimplex Heating & Cooling
Dimplex baseboard heater wiring
no does not matter but you must have a ground leg
Jan 05, 2009 | Fahrenheat Electric Convector Baseboard...
ELECTRIC FIREPLACE ONLY 1+ YEARS OLD HEAT STOPPED WORKING ONLY?
The heater will not work if either the thermostat or blower are not working. (or the heater element is bad). Most of the time with these electric heaters, it's the thermostat.
http://extranet.dimplex.com/files/domain4103//DS5598%20DS5603%20DS5804%20PARTS%20&%20SERVICE%20MANUAL%20REV00.pdf
page 6 has a list of the parts
Feb 02, 2008 | Dimplex DS5598 Mid-Size Heater
Fahrenheat Electric Convector Baseboard Heater, 240 Volt Logo
257 people viewed this question
Top Fahrenheat Heating & Cooling Experts
Paul Carew
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
