Question about Krups ProAroma 453-42 Coffee Maker
How do I program my Krups coffee maker
How do I program my Krups ProAroma coffee make> I want to set the clock and program to start the coffee automaticly in the morning.
5 Suggested Answers
mcdevito75
  • 1970 Answers
SOURCE: I lost my manuel and want to know how to program
mcdevito75 here check online at Krups coffeee maker.
Posted on Jun 20, 2010
SOURCE: How do i clean my krups proaroma coffee maker
I put a mixture of water and vinegar thru the coffee maker and let it sit for about one hour. Then i rinse clear water thru and its find.
Thanks.
Posted on Jun 06, 2009
  • 4088 Answers
SOURCE: No power on the coffee maker/clock. Expresso side
Look for a defective heater, thermostat, safety thermal fuse, or a possible interconnecting wire is broken. This not considered a homeowner repair as it involves mains power and if the safety fuse blew, something made it fail. Because this is likely to be fairly expensive to repair (at a service shop), you should get an estimate and compare that to a new machine. Hope this helps!
Posted on Apr 12, 2010
Testimonial: "Good suggestions and right on. One of the thermal fuses was open. Thanks."
SOURCE: Need instructions on setting clock and timer for
I know this is an old post, but I had the same issue. Go to this website for the manual.
http://www.applianceinsider.com/krups-user-manuals/
Posted on Feb 10, 2011
I need to replace my Krups 453 Thermo fuse (ms-0061607). Where can I find one or is there a replacement?
Many times the Thermal (not Thermo) fuse is soldered in line with silver solder and unless you have the ability to cut the old one out and replace it, the cost would be greater than a replacement coffee maker.
Jan 05, 2015 | Krups ProAroma 453-71 Coffee Maker
Our Krups heats the water but does not brew
may be its not heating properly try some descaleing
Jul 13, 2014 | Krups ProAroma 453-71 Coffee Maker
The Krups coffee maker brewed as usual, it was a little hot so I did a few other things went back to the coffee maker it had shut off by it's self and now wont come back on???
unplug the coffee maker. Let the unit cool down for say a half hour. Try another pot of coffee and see if it comes on after plugging it back in of course
Oct 31, 2010 | Krups ProAroma 453-71 Coffee Maker
The coffeemaker tube leaks on my Krups ProAroma 452. How do I replace the tube?
I have the same problem. The rubber elbow seems to have shrunk with aging. Krups customer service pointed my to SmallAppliance.com for a replacement part. It appears that "Krups 0067516 Coffeemaker Tube" is the proper replacement. It is a special order part that may take 6 weeks to ship. The elbow pulled off a connection inside the coffee maker and I hope that the replacement will just slip back on. While I haven't completed the repair, I think I'm on the right path.
Jun 17, 2010 | Krups ProAroma 453-42 Coffee Maker
Looking for water pipe from pump to shower...otherwise 452 has been running fine for years!
It's probably not cost effective to pay someone to repair it.
If you can find the part and do it yourself, go for it. Otherwise, buy another one.
Most small appliances today are not worth paying for repairs.
Oct 09, 2009 | Krups ProAroma 452 Coffee Maker
I lost my user manual for a Krups ProAroma453-71 coffee maker. Where can I find one?
Contact Krups, and they should be able to send you out a new one. Their phone number (according to their website, www.krupsusa.com ) is 1-800-526-5377
Good luck! :)
Aug 26, 2009 | Krups ProAroma 453-71 Coffee Maker
Thanks.
Jun 05, 2009 | Krups ProAroma 453-71 Coffee Maker
Flashing red light
Just found the answer!
The type 453 coffee maker offers a carafe ‘pre-warm’ function.
This feature will heat the carafe for 5-10 minutes before the brewing process begins and is indicated by a flashing red light.
To toggle this feature, push the top-right button in the control panel until the display reads "off".
Aug 08, 2008 | Krups ProAroma 453-71 Coffee Maker
Coffe does not stay hot in carafe
The wavy lines indicate the carafe pre-heat function. When it is ON the red light blinks for several minutes and the goes on solid. It doesn't start brewing until the light is solid red.
Mine also doesn't seem to keep hot also.
Mar 19, 2008 | Krups ProAroma 453-71 Coffee Maker
Krups ProAroma 453-42 Coffee Maker Logo
199 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
