Question about Compaq Presario 1200 Notebook
Will it take 512mb memory - Compaq Presario 1200 Notebook
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Sniper:
  • 62 Answers
No. It only will take 256 MB memory at most.
Posted on May 11, 2010
IBM T23 wont turn on after adding new RAM
Hi - according to memory suppliers your T23 has the following memory capacity / requirements:
  • IBM ThinkPad T23 maximum RAM capacity: 1GB
  • Your IBM has Two (2) memory slots or sockets
  • Module upgrade PIN count is: 144-PIN
  • The memory speed is: SDRAM 133MHz, PC133
  • The laptop DIMM type for the ThinkPad T23 is: SODIMM, SO-DIMM, Small Outline DIMM
  • Non ECC
If you are meeting these requirements, you may have a defective module.
Also, according to Lenovo's page on the machine:
Memory
The system has 128MB or 256MB of memory standard and can be configured for up to 1GB of addressable memory. Memory options up to 512MB SDRAM SO DIMMs each can be added in the two available slots for memory expansion. The standard 128MB of memory is expandable up to 640MB and the 256MB of memory is expandable up to 768 MB of addressable memory with 64, 128, 256, or 512MB SO DIMMs without removing the 128MB SO DIMM that is standard in one of the internal slots for memory. For customers that need the maximum 1GB to which memory can be expanded, it is necessary to replace the 128MB or 256MB card with a 512MB card plus add another 512MB card in the extra slot. Only 133MHz DIMM memory can be used in this system. The use of 100MHz DIMM memory is not supported in the T23 systems.
This means yo can trouble shoot the 512MB modules individually by installing one of the original 128MB modules and one of the new 512MB modules (for a total system memory of 640MB). If it does not boot, try again with the other 512MB module. This will help you identify a defective module that may be preventing the machine from booting.
I hope this helps & good luck!
Sep 28, 2012 | IBM ThinkPad T23 Notebook
My n72 512mb card is not reading either in phone or in pc
With regard to your N72 512mb memory card, basically, if your phone or computer is unable to read it, there is a big possibility that it was damage or broken.
Once you connected your 512mb MMC to your card reader and the computer is not recognizing it, it is already broken.
To make sure, try other memory card and if it works, obviously, your 512mb is defective.
And if you need some files to be recovered from the old 512mb memory card, there is only a small possibility that you can recover it, you can try going to some repair store that fixes memory card.
Nonetheless, if there is no important files or data on the memory card, I would suggest getting a new one since it doesn't cost that much nowadays.
Thank you,
Jack
Feb 15, 2011 | Nokia N72 Cellular Phone
RAM Slot does not recognize more than 512MB ( 184 )
Consider updating your motherboard bios.
http://www.asrock.com/mb/download.asp?Model=K7VT2&o=BIOS
Also make sure that your memory is correct for this system:
- Max. capacity of system memory: 2GB DDR or 2GB SDRAM
- DDR x 2, DDR266/200 non-ECC, un-buffered memory
- SDRAM x 2, PC133/100 non-ECC, un-buffered memory
Jun 26, 2010 | Asrock K7VT2 Motherboard
Acer Aspire ASE571-ED450A configured with 2x1gb My acer is configured with 2x1gb memory. I have two additional 512mb memory chips HYS72T64000HU.3.7-A 512mb 1Rx8 PC2-4200E-444-11-A1. Can these be used in...
The 512MB PC2-4200 DDR-533MHz ECC Unbuffered CL4 240-Pin DIMM Memory Module Mfr P/N HYS72T64000HU-3.7-A will run with you're current 2GB DIMMS.
Cheers'
Mike
Feb 23, 2010 | Computers & Internet
Whatis the maximum memory the medion rim2520 pc
Standard Memory : 512MB or 1GB Maximum Memory : 2GB ( 2 x 1GB) Total Memory Slots : 2 Memory Type : DDR2 533MHz (PC2-4200) 200-PIN SODIMM
Oct 08, 2009 | Computers & Internet
Sharp Actius AV18 does not recognize added 512MB PC2700 RAM. The machine still only sees 256MB. Is there something else I need to do?
I assume the laptop had originally 256Mb RAM and you put 512Mb RAM in a the spare memory slot and you expected to see 768Mb of memory, is this correct? Try removing the 256Mb memory module and insert the 512Mb memory module and see if the laptop boots up with 512Mb of RAM. If it doesn't boot up then the RAM is either incompatible or faulty. Try using RAM modules from the same manufacturer.
Jun 09, 2009 | Sharp Actius AV18 Notebook
Acer Travelmate 529atxv states max memory as 512mb
512mb is the max memory amount this computer will accept.
Each memory slot can hold SDRAM, PC133 with a maximum of 256MB per slot. Two slots total. Hope this helps.
Mar 07, 2009 | Acer TravelMate 529ATX Notebook
Memory upgrade
The M45-S169 only has one available memory slot.
(I'm confused about your post that states "M45-S265" in the head line).
  • Configured with 512MB DDR SDRAM (both memory slots may be occupied)
  • 512MB(min)/2048MB (max), 256MB on-board memory with 1 available memory slot for 256MB, 512MB, or 1024MB PC2700 DDR 333MHz SDRAM 2.5V SODIMM memory modules
You can find the complete specifications here.
Jan 05, 2009 | Toshiba Satellite M45-S265 Notebook
Compaq Presario 5352 memory installation recognizing
be sure that the memory u got is compatible in your presario 5352. I tell you that adding 512mb to current 64 mb maybe a problem. you should remove the 64mb and replace it by 512mb and be sure that the new memory is compatible. want more information about your presario go to www.hp.com then search "compaq presario 5352"
melnavz
Dec 12, 2007 | Compaq Presario 5000 PC Desktop
Can I add another 512MB of memory to my A105 satellite toshiba
i dont know as much about laptops but you should be able to get the 512MB. to replace it look on the bottom on the laptop there should be somewhere down there that you can open up the to put it in.
Nov 22, 2007 | Toshiba Satellite A105 Notebook
Compaq Presario 1200 Notebook Logo
35 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
