Question about Amana 24 in. ADB1500AWS Stainless Steel Dishwasher
I've had my ADB1500AWS Amana dishwasher for 3 1/2 years and this problem is recent. dishes are not rinsing and dirty marks can be found on the inside of the washer door at cycle's end. disposal drain hose is not clogged.
  • vickijo685 May 10, 2010
    Already tried all the basics mentioned in the first two paragraphs. no clogged drain hoses - water drains out - no clogged screens - no cracks. Water pressure in the house is fine.
    The spray arms are moving but sound like they could be stronger. Water is filling just so it touches the heating element. the fill valve feels like it could float about an inch higher.
    switching experts because I've been waiting for a couple of hours for a reply to my second email.
    I've had my ADB1500AWS Amana dishwasher for 3 1/2 years and this problem is recent. dishes are not rinsing, glasses silverware are very cloudy, coffe cups rinsed but not clean, and dirty marks can be found on the inside of the washer door at cycle's end. disposal drain hose is not clogged.
    Already tried all the basic cures mentioned in the first two paragraphs of a response from rylee smith. no clogged drain hoses - water drains out - no clogged screens - no cracks. Water pressure in the house is fine.
    The spray arms are moving but sound like they could be stronger. Water is filling up so it barely touches the heating element. the fill valve feels like it could float about an inch higher.
  • Amana Master
  • 12,061 Answers
Http://www.devicemanuals.com/guide/Dishwasher/Amana/Amana-ADB1500AWS-Dishwasher-Owner's-Manual-==TWpjeU9ERXg=.html
http://www.managemylife.com/mmh/Troubleshooting_Guides/Dishwasher.pdf
http://appliancejunk.com/ge/dishwasher/31-3280.pdf
http://appliancejunk.com/ge/dishwasher/31-9137.pdf
Hi, please find above, your user manual, top, next is the troubleshooting DIY site, below that are a couple of service manuals, that you can use, to troubleshoot and repair your DW. I am sure once you perform the troubleshooting procedures you will have your problem sorted.
Posted on May 10, 2010
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks. Also make sure that the water is draining and is not accumulated in the dishwasher, if it is in dishwasher then check for clogged drain hoses and drain pump.
Low water fills are a very common trouble maker with today's dishwasher. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
On my Amana Model # ADB1100AWW dish washer the soap door will not open during wash.
Possible Causes:
1) clogged door latch
2) door latch solenoid faulty
3) PCB Board
Oct 01, 2013 | Amana 24 in. ADB1500AWS Stainless Steel...
My Amana sofsound dishwasher is not cleaning the dishes
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Nov 22, 2012 | Amana 24 in. ADB1500AWS Stainless Steel...
My LG LDF6920St has not been cleaning very well recently and there was an odor and grease left in the bottom after a wash. I pulled it out and found the Float Assembly pretty clogged and dirty, which I...
1 Scrape and rinse dishes before putting them in your appliance. Small food particles, grease, sauces and bones clog up the system, keeping the dishwasher from properly rinsing your dishes. You don't need to prewash the dishes but be sure to rinse off any solids.
2 Use a toothbrush to clean around the dishwasher door.
Clean around the seal and hinges of the dishwasher. This area often is forgotten and holds a good deal of bacteria and food splash. A tooth- or bottlebrush is the best way to get into the crevices.
3 Clean chunks of food out of the screen and drain at the bottom of your dishwasher, recommended The Family Handyman. If the drain is plugged, the dirty water can't be washed away and ends up back on your dishes. Nut, bean and seafood shells, bits of plastic and small dishes can lodge against the drain, keeping it from doing its job.
4 Unclog the holes in the sprayer arms. If the holes are blocked by food or soap, water cannot freely spray inside the dishwasher to thoroughly clean the dishes. Leftover food on the dishes can make the dishwasher smell.
5 Keep space around your dishes. Overloading a dishwasher keeps it from running efficiently, allowing gunk to build up around the drain and the spray arms.
6 Run your dishwasher as hot as possible to break down food and grease. The recommended temperature is 120 F.
7 Run the dishwasher with vinegar added to neutralize odor. Empty the dishwasher, place a dishwasher-safe cup filled with white vinegar on the top rack, and run a cycle at the hottest setting. If you prefer, use unsweetened lemonade powder or baking soda in place of vinegar.
Jun 21, 2011 | LG LDF6920ST Stainless Steel 24 in....
Dishes are not cleaning properly in my Amana dishwasher. It has worked well previously.
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Dec 28, 2010 | Amana 24 in. ADB1500AWS Stainless Steel...
Is there a way to clean the system to get rid of mineral buildup? I'm getting a white residue on my glasses
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
heatman101
Aug 10, 2010 | Amana 24 in. ADB1500AWS Stainless Steel...
Residue and unclean dishes in a miele dishwasher
Try more or less detergent. Is rinse aid solution and detergent dispensers working properly? Otherwise, you may have an issue with quality of water.
Apr 14, 2010 | Miele 24 in. G680 Built-in Dishwasher
The dishwasher is leaving residue on the lower rack dishes...everything except plates.
heatman101
Dec 29, 2009 | Amana 24 in. ADB1500AWS Stainless Steel...
Dishes recently started feeling gritty after cycle is complete. I cleaned the dishwasher, ran a full cycle w/o dishes, and added JetDry, which has helped some, but problem persists. The unit occasionally...
It is possible your dishwasher is dirty. I have found this wonderful product called "Dishwasher Magic" It cleans rust, midew and scaling from deep inside your washer leaving it like new. Try it it's a wonderful product
Nov 18, 2009 | Refrigerators
New Amana dishwasher leaving (dried) food particles on the dishes/not cleaning well
CHECH YOUR DRAIN HOSE. IT SHOULD HAVE A HIGH POINT SO THE DRAIN CAN DORK PROPERLY. THE HOSE COULD BE TOO LOW UNDER THE SINK AND DRAINING BACK INTO YOUR DISH WASHER. OR YOUR GARBAGE DISPOSAL HOLE CAN BE CLOGGED
Oct 28, 2009 | Amana 24 in. ADB1500AWS Stainless Steel...
White powdery residue on dishes
Decrease the amount of rinse aid (jet dry) your dishwasher is dispensing.
Sep 02, 2009 | Amana 24 in. ADB1500AWS Stainless Steel...
Amana 24 in. ADB1500AWS Stainless Steel Dishwasher Logo
77 people viewed this question
Top Amana Dishwashers Experts
Oloyede Monsuru
Kolbrun...
Mike
Are you an Amana Dishwasher Expert? Answer questions, earn points and help others
