Question about Vornado Circulating Fan
How to remove the grill to clean the Vornado fan?
  • Douglas Tom
    Douglas Tom Sep 07, 2017
    You can also unscrew the motor from the housing. Then protect it with plastic and hose down the rear housing. Let dry or blow dry with shop vac before reassembly.
Around the wall/body of the sides fan near the rear grill are embossed arrows pointing to screws (first unscrew all-depending on the fan model, there may be 3 or 4 screws (or, as suggested, with the fan's back towards you, use a flashlight to locate the screws).. next, with the fan facing you, grip the edge of the front piece (over the clips) with your finger and gently lift out and towards you. Usually the bottom 2 will also come off easily. DO NOT remove the screws on the posts. You can unscrew the nut on the blade to wash the blade and the front piece. the rear piece doesn't come off. Wipe the rear piece patiently with a moist cloth. Make sure all are dry. Leave alone the motor, blow air into screw holes, else the motor shaft, screws and fan shaft will rust. (paraphrased from official user manual). Remember the orient the notch of the blade to the motor shaft flat edge, and the fan nut unscrews the other way (clockwise).
Posted on Mar 15, 2015
  • Douglas Tom
    After removing the front grill as detailed by Kyle, you can clean the fan thoroughly by unscrewing the motor from the rear housing. Then protect it with a plastic baggie and hose down the rear housing. Let dry or blow dry with shop vac before reassembly.
    Problem Solver:
You cannot with the clips... its impossible.. wound up breaking the clips... and STILL cannot get grill off. Don't ever by a Vornado if you cannot clean it!
Posted on Dec 25, 2014
5 Suggested Answers
  • 12 Answers
SOURCE: i HAVE A Vornado Type
There are three clips the hold the grill to the cowl.
One clip at 11 o'clock, one at 2 o'clock and one at 6 o'clock.
Use a flat blade screw driver to push the 11 and 2 positions down (do 11 then do 2) and the grill shold come off.
I can send pic if needed.
cawicks at g mail . com
Posted on Mar 12, 2011
SOURCE: need to remove gril to clean blade and grill
You can remove it by pressing the clips. I used a flat screwdriver as there was no way my thumb would fit in there. But it worked like a champ with the screwdriver. I pressed two clips and it popped and then I could simply lift the grill away from the fan blades.
Posted on May 06, 2009
SOURCE: Removable grilles for easy cleaning?
We just figured this out ourselves. There are four (4) screws on the back of each fan that when undone it releases the grill for cleaning. But the fun part is getting the screws back in to the little holes. But all in all we got it clean...
Posted on Aug 21, 2008
SOURCE: Opening Vornado fan (model EH1) for cleaning
How do I open vornado fan (model eh1)so I could clean fan blades?
Posted on Jul 08, 2011
Need to take appart vornado to clean
It depends on what type of unit you have. There are grill clips on the back of the unit that you will need to depress. Some models have screws that need to be removed in order to remove the grill. If assistance is needed please call us at 1-800-234-0604.
Thank you,
Vornado Helps
Oct 24, 2012 | Vornado Dryers
I HAVE A Vornado Type 630 fan. How does one remove the cover so that the fan blades and circular grill can be cleaned. Tahnk you, Joanna
Feb 14, 2011 | Vornado Circulating Fan
How do I clean mynvornado fan blades
Look along the outer edge, on the back.
Use mild soap and water the clean the blades after removal.
Dec 18, 2010 | Vornado Circulating Fan
I have a Vornado floor f an, the blades iof which are coated with heavy dust. How do I remove the front protective screen to clean the blades.
On the model I have, the front grill just pulls off from the front; there are some tabs that you might need to release by pushing with a small screwdriver from the rear. After cleaning, just align the tabs and push it back in until they click back in and latch.
Oct 24, 2010 | Vornado Circulating Fan
Fan is making squeeling noise when running.
After reading dozens of similar problems on here about the Vornado fans squealing (and rattling) it seems they are in need of some 3-in-1 oil for the bearings and any moving parts in and around the motor area.
Also good to keep the fan clean by wiping down and removing front grill and the fan blade...A high pressure duster or spray air canister for the motor body etc. should get out any dust inside the unit.
good luck!
Oct 19, 2010 | Vornado 785 Stand (Pedestal) Fan
How do I open to clean 600 series vornado floor fan
Look along the back, outer edge of the fan.
Use a flat blade screw driver to push the 11 and 2 positions down (do 11 then do 2) and the grill should come off. The blade just pulls off. It only goes on one way (due the the "D" shaped shaft).
Oct 18, 2010 | Vornado Circulating Fan
I want to clean a very dirty Vornado circulating floor fan but I don't see how to get it apart.
Oct 09, 2010 | Vornado Circulating Fan
Need to clean..............how do I get it apart to clean model 280SS Have had this model for quite sometime and it deperately needs a cleaning. THNAK YOU!
There are four clips the hold the grill to the cowl.
One clip at 11 o'clock, one at 2 o'clock, one at 4 o'clock, and one at 8 o'clock.
Use a flat blade screw driver to push the 11 and 2 positions down (do 11 then do 2) and the grill shuold come off. The clips are just tabs molded into the grill, don't push too agressively, or the tab will break, and the grill will not latch on as well. Check the Vornado website for more information. They used to have a video about cleaning.
Sep 14, 2010 | Vornado Circulating Fan
I have an older Vornado 280B (it looks just like the current 730 series with the small stand). I've been able to remove the front grill & clean it and the blades, but now I'd like to remove the rear...
It's similar to the 600 and 700 series based on a picture of those compared to the 280b model I have. http://www.vornado.com/product-support/support/faq.aspx
Jul 04, 2009 | Vornado Circulating Fan
Need to remove gril to clean blade and grill
Apr 24, 2009 | Vornado Circulating Fan
Vornado Circulating Fan Logo
10,622 people viewed this question
Top Vornado Dryers Experts
Dusty Ryan
Level 1 Expert
Steve
Mack Baxter
Are you a Vornado Dryer Expert? Answer questions, earn points and help others
