Question about Canon DR-5010C Path-Through Scanner
Error while scanning
Getting following error..
error :- Error in the Back Shading Motor Canon DR-5010c driver version 1.2.10508.02002(-4431)
  • Gilbert14 Apr 02, 2008
    error on the front shading motor
  • Techlove Jun 03, 2008
    Replaced the motor unit & problem solved.
Techlove -
Was there any resolution to this problem?
Posted on Jun 02, 2008
  • BillWaltman Feb 20, 2011
    I pulled all the covers off and blew it out. Even took apart the top scanner cover and blew that out as well. After reassembling, it is working fine. No more "Error in the Front Shading Motor"
SOURCE:
"I get an error "Error in the back shading motor (4431) and the scanner stops. How can I fix it?
This error can be caused by a mechanical problem during the return of the shade. After many attempts, problem was fixed cutting both springs from pressure roll behind reading unit. The amount of spring removed changed from machine to machine. I cut 1 quarter of turn from spring and test the scanner. Procedure was repeated until problem was fixed. In worst scenario 2 turns were cutted. Be aware that cutting these springs will affect the scanned image quality.
Nov 22, 2011 | Canon DR-5010C Scanner
Hello, I am getting the following error message Scanner is busy, operation can not be completed. Canon DR-6080/7580/9080C Driver Version 1.3.10502.17001 (-4437) I need some assistance. Thank...
Uninstall all drivers and scanning software. Switch off the comp and Scanner, restart the scanner first and then the computer, reinstall drivers and scanning software. Pls run scandisk on the Computer and ensure the OS is okay.
S. Mohan
Feb 22, 2011 | Canon DR-3080CII Path-Through Flatbed...
Getting the following error. error in front shading motor. DR-5010C canon
I have many years repairing canon scanners so here if my suggestion for you.
You will need to open the scanner up by lifting up the top portion of the scanner like you were going to remove a jammed piece of paper in it. The large green button on the left side of the scanner (with the scanner powered on) hold down and count to 10 very slowly. You should see to white strips pop up out of the scanner. One on the top and one on the bottom. If they don't pop up that will tell you which motor is bad the bottom or the top one. If they do pop up look at them closely you will see specks of dirt on them causing them not to function correctly. Get a bottle of Fantastic or 409 your choice and a terry cloth wash cloth. Spray the wash cloth with either the fantastic or 409 until its very wet. Then gently rub across the white strips until all signs of dirt are removed then dry them off by rubbing them with the dry part of the wash cloth you are using. If its just dirt on the shader's your problem will be gone. If one of them do not pop up then you will need to contact your local canon dealer to have a replacement motor installed.
I hope this helps you out if not let me know.
Feb 21, 2011 | Office Equipment & Supplies
How to replace shading motor for canon 5010C
i having a problem in my scanner canon DR 5010c
it is showing error in the front shading motor (-4431) please need your help. how to solve my problem.
Thanks!
Nanette
Nov 23, 2010 | Canon DR-5010C Path-Through Scanner
Auto detection can not be set as default
A 'Driver' is only the software portion to connect two hardwares. You need to install a printer driver for Printer, or a DVD driver for a DVD drive. Similarly, the scanner driver just connects the scanner to the computer.
You need to use a Scanning software to use the scanner. Canon offers CapturePerfect 3, using which you scan documents, do rotation, convert to PDF etc. CP3 has option to detect the page size. CP2 is available free of cost from Canon sites. CP3 comes with the scanner.
S. Mohan, Chennai, India
Apr 01, 2010 | Canon DR-5010C Scanner
Canon DR-5010C just black scans
I would completely uninstall the software, unhook the hardware, reinstall software toy around with the program a bit at this point. If the software states it WILL scan in color, I would go to Manufacturers site and download the latest version of the software.
Sep 22, 2009 | Office Equipment & Supplies
Dr 5010c feeds one to five sheets, then stops
Clean the rubber rollers (pickup and ******) with a damp cloth, loosen the papers to be scanned. Clean all the rollers in the scanning path. What is the eror that is displayed? Download the user manual from this site http://www.usa.canon.com/opd/controller?act=OPDSoftwareAct&fcategoryid=2341&modelid=11293 (5010um.pdf). Change the rollers if they are old.
Apr 16, 2009 | Canon DR-5010C Scanner
I have a new DR-5010C scanner. I used to use the
I havent used Canon 2580C and hence cant comment on Scan Panel. But you can download SU5000 or Captureperfect 2.0 from Canon website (http://software.canon-europe.com/). This is easy to use and probably offers more features as compared to ScanPanel. Canon 5010C is a higher model as compared to 2589C and Captureperfect may offer better user interface.
S. Mohan. Chennai, India
Mar 19, 2009 | Canon DR-5010C Scanner
Canon Dr-5010C Scanner to Pc problems.
Are other formats, like JPG, working okay? Unselect multiple pages so that you get on image per sheet. Reinstall scanning software after a 'scandisk' command.
S. Mohan
Mar 04, 2007 | Canon DR-5010C Path-Through Scanner
Error Message-- Error in shading position (-4431)
The issue at hand here is a sensor error. Cut the power to the machine for at least five seconds. Then reboot the scanner and the sensors should reboot. This solved the problem for us. Good luck to you.
Nov 21, 2006 | Canon DR-2580C Path-Through Scanner
Canon DR-5010C Path-Through Scanner Logo
1,008 people viewed this question
Clive
Clive
old marine
old marine
Ekse
