Question about Garmin Nuvi 360 Bilingual GPS Navigator and Personal Travel Assistant GPS Receiver
My Nuvi360 works fine on batter. When connected to car adapter it goes into USB mode instead of GPS mode. how to get it back to GPS mode when connected to car adapter
  • myjobsleuth May 10, 2010
    However, I found a work around.
    When it starts booting, it comes up with a screen which has computer and a wire. As per the manual it is in USB data storage mode
    Then i pull out the USB cable, boot process continues and the computer icon on the screen disappears. I put in the USB power table again.
    Voila, Boot process continues and I get the Warnig message(with Accpect button) and Once I hit it, it brings me to GPS menu
    There after there is no problem. Until ofcourse I pull the USB cable and put it again or I switch of the car (power goes off).
    Story repeats every time the USB power plug is put back in
  • 503 Answers
Try a different connector, what you are describing sounds like one of the pins in the adapter is bent and is touching the data pin, in the gps unit, when this happens it automatically switches it into usb mode. You MIGHT be able to bend the pin out of the way in the power cord, but this is delicate and easy to break work. Hope this helps
Posted on May 10, 2010
Garmin nuvi 40 goes into usb mass storage mode when pluged to charge
I updated my Nuvi 40 with the latest software and it will not reboot into GPS mode with the usb cable connected. It used to work. I have figured out how to get it to charge with a standard USB cable:
1) Power it on.2) Press the battery icon for 8 seconds - it will enter TEST mode.3) Plug in your USB cable from the PC to the Nuvi - the screen will change to say charging.4) Press the power button 3 times rapidly - it will say Charging across the screen and it will go dim and then dark.5) To wake it up and use GPS mode while charging simply press the power button 3 times rapidly, again.
Works Great!
Nov 15, 2011 | GPS
Garmin 340 street pilot
Remove the battery out and put back in after 5 minutes to reset it.
, check also that the in car power cable is working, and the Garmin is not drained. Tru to connect it to power outlet if you have an adapter
Mar 29, 2008 | Garmin StreetPilot c340 GPS Receiver
Tip
Problem charging MAGELLAN GPS.
I found there are select 120v AC adapters that will work on Magellan GPS. When a working 120v or 12v adapter to mini USB adapter is plugged into the unit, the battery bars will be 'scrolling' and therefore charging.
When your adapter, or even USB cable from your computer, is plugged into the GPS unit, and the battery goes to FULL, it is NOT CHARGING. The battery bars must be SCROLLING for the unit to charge. In this case, get a different adapter until it works.
This was tested on a Magellan 1412, and may apply to other Magellan GPS.
on Dec 28, 2008 | Magellan RoadMate 1412 Car GPS Receiver
Garman 225w won't start, stops after "loading
The micro usb port is at the back. Connect Vehicle Power Cable to the nüvi and connect the other end to your computer, your nüvi does not operate as a GPS unit - it goes into some sort of charging mode. However, if you FIRST turn on the nüvi in the battery mode then go into the test mode (press the battery icon for about 8-9 seconds) from the main screen, THEN PLUG in the USB cable, and finally exit the test screen, your nüvi will restart (reboot) and it will operate just like it was plugged into the cradle connection in your vehicle.
This mode will charge the battery
AND operate as a GPS.
It works with my computer USB cable, my cell phone charger and my car charger for my cell phone.
Don't forget to turn off the nüvi before unplugging.
Jan 08, 2011 | Garmin nuvi 255W GPS Receiver
Nuvi 660 ~5yrs old. With auto charger connected the unit powers off quickly with low battery indication. However if charged overnight on a USB cable the unit operates fine and indicates the battery is...
You probable have a blown fuse in the cigarette lighter adapter.... Unscrew the silver tip of plug and check fuse..... be careful its spring loaded..
Oct 24, 2010 | Garmin Nuvi 660 GPS Receiver
I've been using after market chargers in car and on ac. They worked fine for a long time. Now, my Garmin NUVI 660 seems to turn off (goes into "charge mode" or something) when I plug my car charger into...
Yes, many aftermarket chargers are not wired the same as a Garmin charger and will cause your Nuvi to think it's connected to a PC. What happened to the original charger that plugged into the cradle (the part your Nuvi snaps into?)
Please see this link:
http://www.sharc.net/gps_charger_repair.htm
- Jim
Jul 15, 2010 | Garmin Nuvi 660 GPS Receiver
I cannot use the GPS unit while in charge mode(NUVI 350)
Are you using a USB cable & charger to operate the GPS?
If so, you should stop and use the supplied cradle / power cord to power the GPS instead. The USB cable is used to transfer data to and from the GPS and on other models (maybe your 350, too) to slow charge the GPS battery when completely discharged. Powering with the USB cable will power up the GPS, but does not allow navigation, mapping, etc.
Oct 12, 2009 | Garmin Nuvi 350 Car GPS Receiver
Have garmin nuvi360 gps can't find any uddates or do i have to buy an update
Search for Garmin WebUpdater. Connect with USB cable Run while connected to 'net.
Jan 04, 2009 | Garmin nuvi 350 GPS Receiver
Garmin 1412, wont run on battery power, DC only. Need info on maybe a full reset whether to return as defective
Dec 22, 2008 | Magellan RoadMate 1412 Car GPS Receiver
Battery question
Oct 08, 2008 | Magellan RoadMate 1412 Car GPS Receiver
GPS Logo
76 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
