Question about Dual Car Audio & Video
My dual xdm7510 wont slide down. When i turn on my car i hear the stereo radio turn on like the buzzing noise, but i have to move the face plate up and down in order to see the screens...What's wrong?
    President:
  • 1,297 Answers
Pretty common problem with these
I've had at least 6 customers this year
Each time it is the faceplate motor that has failed
only fix is to replace and I'd advise to avoid the brand Dual
Posted on May 10, 2010
Dual CD770 (Same as XDMR7700) face stuck open (down)
Change the Flex cable that connects from main chassis to the front face plate. This is a common problem with Dual drop down face plates, since the flexible wires break and lose connection.
Mar 06, 2013 | Dual XDMR-7700 CD Player
My new dual XDMA450 stereo wont turn on. when i take off the face plate the red sensor light is flashing. this only happens when my head lights are on. what problem am i having with my stereo and why
Check your wiring connections. A similar thing started happening to me out of the blue. The unit would work fine for a period of time, and then just shut off for no reason, and I couldn't get it to come back on. The next day, it would come on again when I started the car and stay on for a while, only to shut down again. The red light behind the face plate continually flashed, regardless of whether the receiver was working. In my case, there was something off in my red wire connection. The unit would turn on / shut off when I moving the wires on either side of the connection. I redid the connection, secured it with electrical tape, and the problem has not reoccurred. If the red wire is not the problem in your case, try the black and yellow connections. These appear to be the wires that could cause this to happen. I can't explain why the power kept repeating the power on / off cycle, unless the wires were in just the right position to be moved / jostled slightly while driving. Hope this helps.
Oct 19, 2012 | Dual Audio Players & Recorders
Just installed an XDM7615 Dual stereo and the face plate won't detach. Can anyone help? The manual says there is a button behind the face when it's in the 'eject' position but pushing this button does...
There are 2 very small screws on the back of the face plate that need to be removed. Once these are removed, you may then remove the face plate.
Feb 10, 2010 | Car Audio & Video
Where can i plug in my ipod?
XDM7510 CD Player This dual model radio it comes w/ a Aux, wire plug where it need to be connect it from back of stereo first.
Jan 04, 2010 | Dual Electronics XDM7510 CD Player
How do I turn my subs on on my xdm7510 radio
check to see if you have power going to the amp. Battery(+) and Negatve(ground). if those are ok, turn the radio on and check to see if the remote wire(it's usually blue) has power. if you have power on the battery wire and the remote wire from the radio, then there is a problem with your amp. check fuses on the amp if any.
Sep 07, 2009 | Dual Electronics XDM7510 CD Player
I have a Dual XDM7510 and i can't figer out how to get the face plate off of it
Hello sneary_08,
The front panel was semi-permanently attached during
assembly. In order to be removable, the installer is required to follow specific procedures contained in separate instructions. If the installer did not perform the procedures, the front panel will not be removable.
If the procedure was followed during initial installation, then you can remove the front panel as follows:
With the unit off, press OPEN to allow the front panel to slide
down. Gently squeeze the release tab located on the bottom
center underside and pull front panel down and away from
unit to remove. To install, insert left side first, then push
right side to secure.
Hope this helps.
Jun 01, 2009 | Virtual Reality Sound VR3 CD Player w/ USB...
Face plate removeal
Hello capthowdy148,
Here's the removal/installation procedure:
1) With the unit off, press OPEN to allow the front panel to slide
down.
2) Gently squeeze the release tab located on the bottom center underside and pull front panel down and away from unit to remove.
3) To install, insert left side first, then push right side to secure.
Hope this helps. If it does, please rate as "FixYa.
May 05, 2009 | Car Audio & Video
I have a dual xdmr7700 stereo and lost the manual need to get the face plate off
Same problem as yours with my deck. Bought the deck a month ago, turned car on in the morning face plate does not move down, music plays everything ok but can not access the cd or move the plate regadless button pushing.
Have you tried the reset button? Hold it for 3 seconds ( ball point pen to press the button above power button) U will lose the presets but Oh weel.
I am going to remove power completey from the unit later on today, and if it still has issues I am returning it for a replacement ( Bought it form Best Buy)
L8R
Nov 09, 2008 | Dual XDMR-7700 CD Player
Stereo issues
I'm assuming that you installed the head-unit new and that the faceplate did (at one time) previously slide down the way it was intended to work - is this assumption correct?
Is the molding around the head faceplate (mounting ring) damaged?
Are you sure you're not using the semi-permanent mounting configuration??
(see page 6 of the manual)
This particular unit has the option for a semi-permanent mounting of the face plate. If the two screws are inserted into the sides, it will lock the face plate in to the head unit (have you done that?) - if so, removing the screws will allow the face plate to be removed.
May 29, 2008 | Dual Electronics BDS692 Coaxial Car...
Car Audio & Video Logo
60 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
