Question about Craftsman 24 Hp 48" Deck Yard Tractor
Lawn tractor turns over real slow. it has new starter and new battery. with the spark plug out it turns over just fine.
  • 755 Answers
Clean and check all you battery connections.
Especially the ground connection on the frame or motor.
If the cable ends look corroded and frayed.....go to a parts store and get new ones. They are pretty cheap and come in many lengths to fit your needs!
Posted on May 10, 2010
Solenoid clicks but starter does not kick in to start tractor
Clicking Sound While Attempting to Key Start - Riding Mower
troybilt.custhelp.com/.../clicking-sound-while-attempting-to-key-start---r...
Jul 19, 2002 - Why does the tractor make a clicking sound and not start? ... Thesolenoid connects the battery to the starter motor when the solenoid is energized. ...It can click, but not make a complete connection. ... Starting - Riding Mower · Professional Shop Manuals · Basic Troubleshooting - Lawn & Garden Tractors.
How Do I Tell If the Starter Solenoid Is Bad on My Kohler ...
homeguides.sfgate.com > Real Estate Advice > Basic Real Estate Advice
Most large Kohler engines on riding lawn mowers use an electric starting system. ... A bad solenoid can deny electricity to the starter motor and prevent engine startup. ...Lawn Mower Will Fire but Not Start · Replacing a Solenoid on a Craftsman Lawn Mower or Tractor · How Does a Starter Solenoid on a Lawn Mower Work?
My Bolens lawn tractor won't start. It just clicks when I turn ...
Dec 03, 2015 | Garden
Craftsman 18.5hp new battery new solenoid will only crank one revalution then quit what next?
It could be several things !! well not the battry !! you can check that out from the list !! sounds like the starter is dragging, you can try to jump it off with a screw driver turn the key on and touch the two srews on the solenoid becareful cause its going to spark a little , check to see if it still drags or it fires right up !? if it drags and turns slow than its most likley your starter ,check and see if the starter geting real hot also ? thats one of the signs that its going out also ,
Feb 14, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
17.5 hp bolens lawn tractor motor turns slowlyand will not start. new battery, starter works. what is valve adjustment proceedure?
check the battery cable bypass them with jumper cables that engine uses a lot of amprich to spin it over valve adjustment would change all at once but i set mine to .006 when the opposite valve set the other one
May 11, 2012 | Ariens Garden
Tractor will not turn over even with new battery
try taking the spark plug out and spinning it over, it your still not getting anything does it even make a noise when you turn the key if your hearing a click and nothing else you could have locked up motor, a bad starter solenoid, or a bad starter, let me know what happens
madminibiker@gmail.com
M.Woodring
Apr 19, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Lack of Spark
If all of your tests are correct, the thing remaining is the ignition coil. A bit of a pain to get at and expensive too. Parts diagram here. Before you buy a new coil, see if there might be just a broken spark wire or loose connection at the spark plug contact end.
Jul 16, 2010 | John Deere Garden
Starter get hot engine won't start. When I remove the spark plug and put the plug back in the wire and crank it I can see the spark but when I put the plug back in and try to crank. It won't crank very...
You likely need to get the valves adjusted,it sounds like the decompressor is not working.You need to get the compression down to 130 lbs while cranking or the starter can't overcome the compression.Try turning the motor past the compression stroke by hand and see if it will crank faster,if so then the decompressor is out of adjustment.If the decompressor is not just a lob on the valves then you need to call the repair depot for craftsman and find out what you need to do to fix the problem.If none of the above works then you may need a battery,or just clean the cables and battery posts.
Apr 19, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a Sears Craftsman Lawn Tractor, Model 917.272751, S/N 060503B025327, B/S engine 18 Hp Model 31H777, Type 0202-E1. I have a new battery and a new starter on it but when I hit the starter the engine...
Have you checked the oil in the crankcase, is it full ?
Has engine been sitting along time ?
Have you double checked all the battery conections, all are tight, good ground connection to motor ?
Please let me know.
Feb 07, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman Lawn Tractor/ hard start/ whitish smoke
does it turn over slow or fast if it turns slowly thats the problem so it could be battery or starter they have to have a good amount of rpms to burn fuel right when starting if not it floods out the engine with gas hope this helps thanks wade
Jul 05, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Have new proper batt.Have new starter celenoid,new
Remove spark plug and attempt to crank. If it turns faster (without compression) it may be valve adjustment. If it still turns over slowly with plug out check battery ground for tightness to mower body. If the ground is good check the starter by removing battery and atttaching jumper cables to pos and neg battery terminals first, then the pos jumper to starter terminal (where red wire attaches). Then touch the neg jumper to a good engine ground (I use shroud bolt). Be careful as this last connection will cause some arcing. If it still cranks slowly with the plug out, it is probably the starter.
Apr 11, 2009 | Craftsman Garden
Craftsman 24 Hp 48" Deck Yard Tractor Logo
101 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
