Question about Faberware 12-55 Cup Coffee Urn
The stem isn't producing enough water force over the grounds.
The unit is heating fine but the stem isn't producing enough water over the grounds. The coffee is very weak and only colored water.
    Scholar:
  • 176 Answers
Hi. Check the spring and make sure it is just under the coffee basket. Next thing check the keep warm element, it should be on at all times the poy is in use. 1 of the 2, one is a fix.
Posted on Jul 26, 2010
Frigidaire dishwasher fghd2433 gets stuck on Heat Delay waiting for water to heat up
With new regulations and data set forth but the government the units produced must have at least 120-140?F water coming to the unit. If you do not have your home water heater set to this, you will need to do so. Otherwise the sensors and the unit itself will not operate correctly.
Dec 28, 2012 | Dishwashers
No hot water from certain time of the day living in a single family home with wall thermostste
see the following steps:
If the unit produces no heat, raise the thermostat, check switches, fuses, circuit breakers, and the water level. Also check the burner's safety controls (see below).
If the unit doesn't produce enough heat, check the combination gauge, then the expansion tank (see below). Next, flush the boiler (see below). If water leaks from a heating system pipe, try repairing it yourself.
If only some radiators in the system heat up, bleed air from the cool units (see below). If you suspect that the circulator requires repair, call an experienced serviceperson.
If the pipes suddenly start clanging, the circulator may need professional service or replacement.
If there is a chronic banging noise, check the slope of all return lines; they must slope toward the boiler to work correctly.
If a single radiator warms only slightly, but evenly, water may be trapped inside. Make sure it slopes toward the return; if it does not, insert a wooden shim under the end opposite the return.
Jul 21, 2012 | Heating & Cooling
Apple Thermal Shutdown
well generally speaking there are 2 reasons that thermal overload and forced shutdown will occur. The first being that the fans are not running or running at the proper speed to help push the heated air from the sink out of the unit, or they are blocked in some way, internally or externally. The other possible cause is that the processor isn't making good contact with the heat sink because there isn't enough thermal grease (a paste that is used to increase the surface area between the sink and the processor that conducts heat well) or it has become seperated from the sink. Theres a PDF or video on powerbookmedic.com if you feel comfortable enough to take it apart yourself, but first I would make sure you're giving it enough room to breath when your using it by locating the vent ports and making sure that youre not blocking them in any way during usage. On apples these are typically between the case and monitor around the hinge area. I hope this helps!
Jun 24, 2012 | Apple MacBook Air
The dishwasher is not cleaning the plates and glasses as should, leaving a lot of residue on everything
It sounds like water isn't being forced through your spray lines, which could be a result of either you trap being clogged or the sump pump not working. It could also mean that your heater element isn't heating the water hot enough for it to clean.
If it only the upper rack then it could be a blockage for the upper sprayer, but if it is throughout the machice, then it would either be the sump pump, trap or heating element as the most likely causes.
Jul 03, 2011 | Dishwashers
I was called out because a tennants water heater wasnt working. I tried to restart the pilot. but nothing happened. I checked the gas line and it was getting gas. I checked the electronic starter and it...
if the heating element is out, the pilot will try and start , but if the thermocouple in the unit itself isn't letting the gas release,, it isn't going to fire up , Check the thermocouple , if its built into the controller valve,, your either going to have to replace that ( if its possible on that unit,, ) or get a new water heater
May 08, 2011 | General Electric Water Heaters
Coffee grounds in the coffee pot. It appears water does not flow into pot quickly enough, so filter basket overfills and causes grounds to go up and over the filter, then flow into pot. Also heat plate...
From what you described, it sounds like your carafe isn't fitting properly. The lid of the carafe is supposed to open a valve on the bottom of the filter basket. If this valve is clogged or not opening completely, that will produce your symptoms. Also, the warming element will not keep carafe hot if the carafe isn't sitting properly.
Sep 29, 2017 | Black & Decker BCM1410B 12-Cup Coffee...
My coffe maker turns on but nothing comes out, I already checked the spray head & its,not clogged, what can I do
check and make sure the heating pad gets hot if it does not then in the bottom inside the Base you will have to take it apart and under the heating pad their will be some wires their will be a thermal resistor that will be attached to a part of the element this part needs replacing and can be purchased at radio shack for about $1.50 replace it with the new one and reassemble as it was then try the unit. it should be working fine if the heating pad gets hot then you have another issue most likely the water tube come loose at the bottom of the water tank simply re-attach and reassemble some times wile filling the tank when the unit is still hot a steam shock will force the tube off. explanation of the workings the water tank supply water to a tube that attaches to the heating element the water runs though the element heating by the time it reaches the other side it is hot enough to force the water to the top where it is expended to the coffee grounds and brews the coffee like the same way a peculator pot works only difference is the water runs through a tube under the heating element instead of a fire under the pot. hope this helps the radio shack link for the thermal resistor or thermal fuse is the proper name is http://www.radioshack.com/search/index.jsp?kwCatId=&kw=thermal&origkw=thermal&sr=1
chose the proper temp most are for home use at 128°C (262.4°F) Thermal Protector Fuses
Aug 30, 2010 | Bunn VPR Coffee Maker
We have an Aprilaire whole house humidifier that is functioning, but it does not have the ability to humidify our home. We have 3000 sq ft. When the heat comes on, the temperature must be high enough then...
You can turn the blower on so that the humidifier will run more... there should be a manual on detting on your t-stat that will run the blower constantly. The humdifier should be wired to go on withthe blower.
The other option would be to install a stem humidifier which will produce more humidity faster...
heatman101
Apr 19, 2010 | Honeywell HE365 Humidifier
I dont know how to make coffee
Water Level ////Amount of Ground Coffee
42 Cups --2 ½ Cups
36 Cups-- 2 Cups
30 Cups- -1 ¾ Cups
28 Cups --1 2/3 Cups
24 Cups --1 ½ Cups
22 Cups --1 ½ Cups
18 Cups-- 1 ¼ Cups
12 Cups --1 Cup
1. With basket and stem removed, fill coffeemaker with COLD water to desired level using the cup markings on inside of coffeemaker as a guide. Do not make less than 12 or more than maximum capacity of the coffeemaker at one time.
2. Place stem into heating unit in bottom of coffeemaker, then put basket on stem. Spread the recommended amount of ground coffee evenly into the basket. See chart. Use regular electric perk grind coffee or coffee ground for all coffeemakers. Do not use drip or finely ground coffee as flooding of the basket can occur.
3. Turn cover in place on coffeemaker. To reduce coffee spills, especially if coffeemaker is tipped over, make sure cover has been turned clockwise until it is completely secured in the handle slots. (Note the arrows on the cover for correct turning.) The cover temporarily reduces coffee spilage if coffeemaker is tipped over, so care should be used when moving coffeemaker.
4. Place coffeemaker on a dry, level surface. Attach cord to coffeemaker and plug into a 120 volt AC electrical outlet ONLY.
5. Coffeemaker stops perking automatically. (Each cup of coffee requires about 1 minute brewing time) Serving light will glow when coffee is ready. Before serving, use a hot pad to remove cover, then carefully remove stem and basket from coffeemaker as coffee and grounds are HOT. If not removed, bitter oils from the coffee grounds will drip into coffee. Replace the cover making sure it is completely secured into the handle slots.
6. Coffee will remain at serving temperature as long as coffeemaker is connected to outlet. (if you have an insulated coffeemaker, the sealed-air insulation will keep coffee hot for up to two hours without electricity.) To serve, place cup and saucer under faucet and press down on handle. If a continuous flow is desired to fill a carafe, lift handle straight up until it locks into open position. When approximately one cup of coffee remains in coffeemaker, disconnect from outlet.
TO MAKE MORE COFFEE: If another pot of coffee is desired right away, partially fill coffeemaker with cold water to reset the thermostat. Pour out water, refill with cold water and repeat steps 1-6.
TO HEAT WATER FOR INSTANT BEVERAGES: Plain water may be heated in your coffeemaker for use with instant beverages. Simply fill the clean coffeemaker with cold water to the desired cup level, and then place the stem and empty coffee basket in place. Using the stem and empty basket will heat the water more uniformly. Secure cover in place and plug coffeemaker in. Heat water until perking stops and serving light comes on. Unplug coffeemaker when less than 1 cup remains. Other than making coffee or heating water, no other liquid should be heated in coffeemaker as damage to heating unit can occur.
When coffeemaker is used to heat water only, the metal inside will discolor which is normal and does not affect performance or the water heated in the coffeemaker. Refer to Special Cleaning Instructions in this manual for removing discoloration as well as mineral deposits, which form inside the coffeemaker when heating water. If these deposits are not removed, pitting of the metal inside may occur and result in damage to coffeemaker. Refer to the cleaning your coffeemaker section
Apr 14, 2009 | West Bend 58030 Coffee Maker
Holmes HM5601 quit working
I had the same problem with my Holmes HM5601 humidifer unit - right out of the box. I almost returned the unit to the store, but was able to figure-out the problem. Not enough water had been filling the heating section (where that black knob-like protrusion is) and the lack of enough water had caused the unit to shut-off soon after plugging it in. The problem is in valve at the bottom of the water tank! The valve is a factory defect. It needs to open more when you sit the water tank onto the base so water fills the reservoir. I had solved the problem by going to the hardware store and purchasing some small, rubber pads or feet. These rubber pads are the type used to place under things where you want to protect a table-top from being scratched or you want the item not to slide too easily on a table-top. These rubber feet or pads have an adhesive on the bottom of them. Find the size that matches the diameter of the valve stem on the bottom of the water tank. Once installed, the valve should open and close with your finger without the rubber pad interferring with the operation of the valve. The pad, if installed properly, makes contact with the water reservoir base when you placed the water tank down onto that base. The valve open a bit more allowing water to pass-thru and fill the water reservoir. Water fills the heating section as needed and the unit runs perfectly after! The round rubber pad I had used was about an 1/8 inch thick and 1/2 inch in diameter.
Nov 30, 2008 | Humidifiers
Faberware 12-55 Cup Coffee Urn Logo
Top Faberware Coffee Makers & Espresso Machines Experts
Starnley Johnwells
Starnley Johnwells
Steve
Kolbrun...
Are you a Faberware Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
