Question about Goldstar KG6000R Window Air Conditioner
Power outlet is fine but It will not start. Older model with low hours on it. It does start sometimes with no problem
  • 82 Answers
If it starts sometimes and not others...I would check the start capacitor. This is the "booster" to get the electrical items running.
Posted on May 11, 2010
I have a rca flat screen 32 inch l32hd31r(model) that will not turn on. Nothing no lights or anything. Tried plugging it into several outlets and still nothing. However it was working fine a few hours ago.
Fault in the main power supply regulator. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Mar 19, 2015 | RCA Televison & Video
Unit sometimes takes several minutes to several hours to turn on
Check power outlet and ensure proper voltage is present, if you know how to handle power, and have a measurement meter. Try connecting the TV to some other power outlet, where another equipment is working fine. If problem persists, the defects could be due to dry/leaky capacitors, dry solders in the PCB etc. and might require attention by a qualified service technician.
Jul 25, 2012 | Sony 42XBR900 Television
I have an older model Niagara 4kw by generac with low hours. I started it recently for the first time in 3 years. It ran fine but produced no current. I checked the brushes and cleaned the slip rings but...
I have not seen yor generator in practice, but saw some pictures of it.
As it is an older model, but it is not rare for modern generators too, when they stay a lot of time (3 years is a good lot of time), they lose thier magnetism.
In order to build the magnetic field up again you can connect for a short time (1 - 3 seconds) by a working motor, a 12 V battery to the field terminals, + and - respected. A series diode 10 - 25A to battery can stop the built up field voltage to overcharge the battery.
Jul 31, 2010 | Generac Electrical Supplies
NO 20amp 120v power
you probably tripped a circuit breaker. Carefully push in all the circuit breakers, I bet that one of them will give slightly and power will be restored.
Sometimes the 20amp outlet is also a GFI outlet. You may need to reset the outlet itself if so equipped.
May 21, 2010 | Coleman Powermate Powermate 5000W...
Whirlpool refrigerator trips gfci outlet
Yes ,, if the fridge outlet is behind the fridge and therefore not accessible for use by counter top appliances .. then yes change it to a regular outlet.
The cause is probably the compressor, getting a bit noisy..electrical noise I mean.
Feb 23, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
WorkCentre M20i will not power on
Most likely on this machine the Low voltage power supply is out.
Before ordering parts, check the back of the power supply to make sure the connectors, 110 volt on the back of the plug have not slipped off. Sometimes they are not slipped on the connector very good and come off. Also, make sure the switch is good, sometimes these switches are just mechanically bad inside.
Disconnect the power and disconnect the main motor plugs, power back on the machine and see if the machine at least comes on, even with an error messege on the console. Sometimes a bad main motor will cause the main board to drain power.
Also, make sure before ordering this power supply, the correct part is ordered for this model machine.
Let us know what you find, just becareful with the power plug in the machine when working in the electrical circuits. Unplug the copier when needed.
Oct 02, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Panasonic Plasma TV model TH42PD60U Shuts off power led flashes 7x
There is a software upgrade to address this particular problem. Contact Panasonic to see if the upgrade can be provided to you free of charge.
Oct 30, 2008 | Panasonic TH-42PD60U Television
Goldstar KG6000R Window Air Conditioner Logo
87 people viewed this question
Top Goldstar Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
