Question about Garden
I have a troy-built model `TB230 self propeled walk behind mower. Mower just stopped propelling itself, no noise gears seem fine. But when I checked belt it was on but it looks like it is just sitting on the groved shaft coming out of crankshaft and not on any pulley, belt also seems loose and I can't find an adjustment for belt. Help.
    Sniper:
  • 53 Answers
There is a problem with some types of belt driven self propelled mowers. One is grass clippings and dirt get clogged in there, dry out and act like plaster. But if yours is clear of debris...then what has probably happened is good old "stretching of the belt" even a tiny bit. And unfortunately all belts stretch eventually. If you do not see a obvious adjustment to increase the pully spacing then take a good look at the cable that you squeeze to make the mower move. Up by that "go" lever there is usually s small screw or an "adjuster nut" to tighten the cable up. (Cables stretch too! just like belts.) you should be able to adjust it at least twice before you'd have to get a new cable or belt. So place the belt back onto its pulleys, then (mower off!) pull the "Go" lever and watch the pulleys move. You'll get the idea immediately. So, if no adjustment at the pulleys, look to the cable adjustment up at the lever area. Let me know.
Posted on May 10, 2010
  • Ed Gore May 10, 2010
    Look at the drive lever's cable up at the lever end. There is usually a
    cable adjuster there. It will be a threaded shaft portion with a nut or
    knurled ring to spin. tighten up that "go lever" cable a bit. Even
    better, if you have visual access to the belt as you squeeze the drive
    lever, then you can see if squeezing that lever moves one of the belt's
    pulleys enough to cause it to tighten it up enough to transfer spin
    motion thru the belt to the other pulley. You see that whole system is
    really a "slip belt clutch" when belt is loose, no forward motion, as
    you squeeze the "go/drive" lever the pulley moves away tightening up the
    belt more and more. The tighter the belt, the less the slippage, the
    faster you go! But the slippage is necessary! ( That's the clutch
    component) If you simply had the belt tight all the time, the mower
    would always go full speed! It would be in full time "run away mode"
    LOL! so watch out. Once you see it in action...you'll get the idea no
    problem!
What is the spark plug gap seting fot Champion RJ19LMC?
.30 is the standard for most lawn mower engines...you might check the "engine specifications" in your owner's manual to be sure.
Aug 22, 2014 | Troy Bilt 5.5hp Self Propelled Mower
Husqvarna Model 5521BBC. variable speed, walk behind, self propelled. The mower start fine, goes into cutting gear, but when I try to use the "self-propel" feature, it does not engage. It's rear wheel...
yes it could sounds like the cable is out of adjustment remove cover to see if belt still mounted and how to engage selfpropepelld adjust cable accordanlly
Aug 23, 2013 | Husqvarna Garden
Troy bilt xp self propelled not switching gears
Check transmission fluid. Ensure belt is good or replace. Check belt tensioner if installed.
Apr 21, 2013 | Troy Bilt 5.5hp Self Propelled Mower
Where is drain plug for oil on Troy bilt Tb230
It does not have a drain plug. You can remove the dip stick and tilt the mower to pour out the oil, or you can use one of those hand pump syphon units to pump it out.
Mar 23, 2012 | Briggs & Stratton Lawn-Boy Insight Series...
I have a Toro self propelled walk behind mower model # 20016. The self propelled just stopped working. My owners manual does not mention anything about the self propell. Can you direct me as to what to...
Toro 20016 self propelled walk behind when the wheels are engaged it moves, when the wheels are not engaged, the wheels look up.
What should I do to fix the problem
Apr 19, 2011 | Toro Lawn Boy Self Propelled CARB Walk...
My troy built 210 6.75 hp mower self propelled mower doesnt pull
remove the front black plastic plate that is stamped self propelled and replace the wheel drive belt that attaches the engine pulley (above blade) to the transmission pulley (found under the cover). When you buy the belts, pick up two or three as I seem to go through a couple per season. Hopes this helps
May 20, 2010 | Troy Bilt 5.5hp Self Propelled Mower
How do you remove the gears on a front wheel self propelled troy bilt push mower?
Take the front tires off, pull gears and take out pins, put tires back on and you have a "non-self propell" mower.
Apr 13, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Front wheels lock up when pull mower backwards
Typically self-propelled mowers are propelled using the front wheels, which only turn forward. Pulling the mower back while the front wheels are turning will damage the drive gears. It's best to raise the front wheels slightly off the ground before pulling back.
Mar 24, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Troy Built 6.75 Self Propelled to Slow
put oil or grease all the shafts and bearings inside and out, if possible adjust the cutter blade contacts.
May 20, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
138 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
