Question about Diesel Audio NSHTVDVD Car Video Player
I need manual for nsh-tv.dvd diesel audio - Diesel Audio NSHTVDVD Car Video Player
    Problem Solver:
  • 13 Answers
Down load from wed site
Posted on May 12, 2010
I have a sb wa340 active subwoofer. I have subwoofer and speakers but I don't have DVD how can I use this
So is the DVD part missing? There is a VCR / Aux input on the back but it is for audio only. There are no video inputs so if the DVD is not included in your sub/speaker system, you'll be limited to audio only. First, you'll need to connect a TV to your system using one 'Video Out' cable methods so you can see the menu for the remote control changes on the system. From here there are 2 options:
  1. Connect up a working DVD player directly to your TV using the best option available. Use the audio outputs on your TV to connect to the VCR or TV input on the system box. (Using standard RCA cables.) You may need to enable the external audio outputs on the TV. (Check the setup -> audio menus etc.)
  2. You can use this as an audio amp by connecting a RCA cord from the a DVD R/L audio outputs to the VCR-Aux input on the amp box. You will need to run a separate video feed from the DVD directly to your TV. (Select the desired input on the TV to watch a DVD.)
You'll need to do a lot of switching back and forth with multiple remotes to get everything working, but the speaker setup can be made useful if it still works.
Here is a manual for the system: http://service.us.panasonic.com/OPERMANPDF/SCMT1.PDF
Mar 13, 2015 | Audio Players & Recorders
Why do I have sound when I turn on my dvd and not when it is just the tv?
Where does the sound come from ? Is it a type of Amplifier with speakers connected to it ? Suspect audio cables go from DVD player to HI FI Amplifier. You may need to feed Audio cables from TV Audio Out into a audio switch box with DVD audio cables and manually switch inputs into amplifier. You might just need cables on TV audio out into Amplifier ?
Jul 12, 2014 | Panasonic Viera Tc-p42x5 42" Inch Flat...
What do you need to do in order to hear the TV through the DVD-925 System?
For the best TV-related sound, connect the audio from the unnamed source (not necessarily the TV) directly to the Colby's Aux In.
If you believe the sound benfeits from the TV's electronics, run the unnamed TV's possible audio output to the AUX In and configure the TV to put out a Fixed level of audio so you can turn its volume down and not lose it to the Colby. (page 11)
Register and download the manual for free audio.manualsonline.com
http://audio.manualsonline.com/manuals/mfg/coby_electronics/coby_dvd_dvd925.html
Apr 24, 2011 | Coby DVD-925 System
How do I set up my receiver to connect with my tv, dvd recorder and a satellite box?
First of all read carefully user manual or guide book of receiver Installation. connect all Devices like Satellite TV box, HD TV, DVD recorder with audio video & coaxial splitter cable.
set-up-receiver-connect-tv-104u1fzs1oqkwm1vdgsl0pue-2-0.png For more help
4k TV Home Theater Audio Video installation in Houston
Aug 23, 2009 | Audio Players & Recorders
Need instructions to set up Cyberhome DVD 1200 player
Useing RCA cables -(yellow video out) on the dvd go's to yellow video in on the tv. Then (red -right) out on dvd go's to red audio in on the tv . And white-left out on dvd go's to white-left audio in on the tv! and thats it
Dec 24, 2008 | Cyberhome Televison & Video
Won't work with my tv
You need to connect a Audio video cable (Red/White/Yelloe) from the TV out on you TV set to the approriate input in your DVD player
Oct 09, 2008 | RCA RTD120 System
User Manual
Why did you disconnect the chat session?
Anyways here are the detailed instructions for connecting a DVD recorder to a TV
  1. The first step to connecting a DVD Recorder to your TV is to determine what type of connection you want to make between the TV source (Cable, Satellite, Antenna), the DVD Recorder and the TV. This is usually determined by the outputs and inputs available on the DVD Recorder and the TV.
  2. If you have an older TV that only accepts RF (Coaxial) input, then you would connect the RF output (a coaxial cable) from your TV source (in my case a Cable Box) to the RF input on the DVD Recorder. Then connect the RF output from the DVD Recorder to the RF input on the TV. This is the most basic (and lowest quality) option for connecting a DVD Recorder to any TV.
  3. If you want to use higher quality cables, then you may want to connect the TV Source (Cable and Satellite only, not Antenna) to the DVD Recorder using Composite, S-Video or Component video and audio cables.
  4. To use composite cables (also known as RCA, the yellow plug is video, the red and white plugs, audio): Plug in the composite cables to the RCA outputs on the back of your TV source and then plug in the composite cables to the RCA inputs of the DVD Recorder. Then connect the RCA outputs from the DVD Recorder to RCA inputs on the TV.
  5. To use S-Video and RCA audio cables: Plug in the S-Video cable to the S-Video output of the TV source. Plug in the S-Video cable to the S-Video input on the DVD Recorder. Next, connect the RCA audio cable to the output on the TV source and the input on the DVD Recorder. Finally, connect the S-Video cable and the RCA audio cable to the output on the DVD Recorder and the input on the TV.
  6. To use Component Video cables and RCA audio cables: Connect the Component Video cable and the red and white RCA audio cables to the outputs on the TV source and the inputs on the DVD Recorder. Next, connect the Component Video cable and RCA audio cable to the outputs on the DVD Recorder and the inputs on the TV.
  7. Now that the TV source (either Cable, Satellite or Antenna), the DVD Recorder and the TV are all connected, you need to configure everything to make sure that TV is coming through the DVD Recorder, for recording and viewing.
  8. Turn on the Cable Box or Satellite Receiver, TV and DVD Recorder.
  9. If you connected everything using the RF connections then the TV should be passing through the DVD Recorder and displaying Television on the TV screen. To record in this mode, you would need to tune to either channel 3 or 4 on the TV and then use the DVD Recorder TV Tuner to change channels and record.
  10. If you made connections using either Composite, S-Video or Component cables, then to view or record TV, two adjustments need to be made. First, the DVD Recorder needs to be tuned to the appropriate input, typically L1 or L3 for rear inputs and L2 for front inputs. Second, the TV also must be tuned to the proper input, on a TV usually Video 1 or Video 2.
  11. If you have a Dolby Digital 5.1 Surround Sound A/V Receiver you can connect either a Digital Optical Audio cable or Coaxial Digital Audio cable from the DVD Recorder to the receiver to listen to audio through the receiver.
Sep 27, 2008 | Televison & Video
Connecting VCR/DVD combo
Confusing! TV with NO yellow,red white input ? Buy an RF
adapter Radio Shack about 30.00.....TV has input ? = yellow
video,audio R,L from Insignia source dvd/vcr out ( audio R,L,
video {yellow} ) You don't need to switch cables.As to record
feature,consult owners manual..................................T
Nov 21, 2007 | Televison & Video
Can't find my user manual and need help hooking it up
First check Color code
Yellow is for Video Red is for Audio Right Speaker White is for Left Speak.
Do you see rear pannel of the DVD there is Socket
Connect Yellow Cable to Video Out on the Dvd other end of the Cable to Video In on TV.
Connect Red Cable to Audio Out on the DVD other end of the cable to Audio In on TV.
Connect White Cable to Audio Out on the DVD other end of the Cable to Audio In on TV.
Turn on TV as well as DVD Player.
ON tv remote do you seee buttons as TV/AV. AV, Aux, Video, Input, or Game, Pree any one of these Buttons, You should be able to get Picture.
Jul 30, 2007 | Curtis CMD5000 DVD Player
Diesel Audio NSHTVDVD Car Video Player Logo
184 people viewed this question
Top Diesel Audio Car Audio & Video Experts
xxxxxx xxx
Are you a Diesel Audio Car Audio and Video Expert? Answer questions, earn points and help others
