Question about Dual Car Audio & Video
My dual xdm7510 radio won't slide down - Dual Car Audio & Video
  • spenglercoty May 10, 2010
    How do i get to that rod and where to i buy a new one?
  • 668 Answers
The internal rod which helps in sliding down is either bent or damaged thats why you are facing this problem . To solve this problem need to remove the unit and replace the rod .
Hope this helps .
Posted on May 10, 2010
  • Shane May 10, 2010
    You can find the rod by removing the screws and it will be tiny thing connecting the internal switch . You won't get these parts online , you need to contact manufacturer to get one for you .
    Hope this helps .
Schematics for dual xdm7510
You would need to contact Dual for these.
Dec 05, 2016 | Dual Car Audio & Video
On the back of the dual xdm their is a nut in the middle is that an accesory ground
It could be used as a ground but the main purpose is to hold the cooler (the black aluminum piece on the back of the radio) in place so the radio head unit doesnt overheat.
Mar 09, 2012 | Dual Electronics XDM7510 CD Player
How does the Iplug work on the xdm7510 car radio....i have on and i want to use my mp3 player how do i do that????
you have to switch modes until you are on aux (just like hitting TV/VCR on your remote at home)
Feb 27, 2011 | Dual Electronics XDM7510 CD Player
Dual Electronics XDM7510 CD 770 Player.It comes on but no sound,speakres pop when cut on.
Go check out this manual: http://www.fixya.com/support/p920254-dual_electronics_xdm7510_cd_player/manual-26883
Jan 11, 2010 | Dual Car Audio & Video
Where can i plug in my ipod?
XDM7510 CD Player This dual model radio it comes w/ a Aux, wire plug where it need to be connect it from back of stereo first.
Jan 04, 2010 | Dual Electronics XDM7510 CD Player
Xdm7510 will not accept any disc
try unhooking the battery for a couple minutes then hooking it back up
Sep 25, 2009 | Dual Electronics XDM7510 CD Player
How do I turn my subs on on my xdm7510 radio
check to see if you have power going to the amp. Battery(+) and Negatve(ground). if those are ok, turn the radio on and check to see if the remote wire(it's usually blue) has power. if you have power on the battery wire and the remote wire from the radio, then there is a problem with your amp. check fuses on the amp if any.
Sep 07, 2009 | Dual Electronics XDM7510 CD Player
I have a Dual XDM7510 and i can't figer out how to get the face plate off of it
Hello sneary_08,
The front panel was semi-permanently attached during
assembly. In order to be removable, the installer is required to follow specific procedures contained in separate instructions. If the installer did not perform the procedures, the front panel will not be removable.
If the procedure was followed during initial installation, then you can remove the front panel as follows:
With the unit off, press OPEN to allow the front panel to slide
down. Gently squeeze the release tab located on the bottom
center underside and pull front panel down and away from
unit to remove. To install, insert left side first, then push
right side to secure.
Hope this helps.
Jun 01, 2009 | Virtual Reality Sound VR3 CD Player w/ USB...
My Dual XDM7510 display quit working and I can't find out what is wrong. Everything else on the XDM7510 works. Help me please. It was working when I went in the store came back out and no display.
try checking the illumination light on the back of the radio if that doesnt work then try looking at the red ignitionswitch wire and make sure it is connected to the 12vt constant (the yellow wire)
Mar 10, 2009 | Dual Car Audio & Video
Car Audio & Video Logo
56 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
