Question about Shimano 24 Speed Road Racing Bike Bicycle Modell Rs888
Rear brake adjustment or low fluid
Rear disc brake has no pressure- is it low on mineral oil? How do I add some?
  • Tom Bauman Oct 09, 2013
    In Nicaragua you have to improvise... so now I need to be the bike mechanic... and what Fluid can I use... ?
    My bike is a Giant Trance 1 about 2006 or 2007 model
  • 21 Answers
It's likely that you have some air or debris in your brake line. Bleeding hydraulic brakes can be done at home, but frankly considering the potential consequences if your brake fail, this something best left to your local bike shop mechanic.
Posted on May 14, 2010
How do I access rear brake reservoir that I may add brake fluid on 1995 Honda nighthawk cb 250
Hi, Anonymous a 1995 Honda CB250 Nighthawk has drum brakes front and rear. Newer bikes with disc brakes will have a brake fluid reservoir.
For more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
How to adjust the rear drum brake on motorcycle
2 HONDA ELITE FRONT DRUM BRAKES REPLACE AND ADJUST
Honda CB250 Shop Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda CB250 Nighthawk Owner Manual
Mar 30, 2017 | 1995 Honda CB 250 Nighthawk
WHAT IS DONE ON A 10K SERVICE FLHRC 2007
Change oil/filter
Service air filter (??? replace??)
Clean tappet oil screen (if applicable)
Change primary lube
Adjust Clutch
Change Transmission fluid
Check and adjust chain and belt
Inspect brake pads/discs
Lube; Front brake lever pin, throttle control cables, clutch control cable, jiffystand pin
Check operation of enrichener (carb model?)
Inspect fuel valve, lines, fittings for leaks
Check tire pressure
Check operation of all electrical equipment and switches
Check cruise control disengagement switch and clean connections
Check and adjust battery electrolyte level and clean connections
Change spark plugs
Check engine idle speed and adjust as needed (non-EFI?)
Lube foot shift, brake lever bearings, and speedometer cable (if applicable)
Check brake fluid level and condition
Inspect oil lines and brake system for leaks
Clean or replace fuel tank filter screen
Check air suspension, pressure, operation, leaks
Replace wheel bearings and replace lip seals where applicable
Check tightness of all fasteners except engine head bolts
Lubricate hinges, latches, fuel door, tour pak, and saddle bags
Adjust Springer rocker bearings
Check stabilizer links and engine mounts
Check wheel spoke tightness
Check rear brake pedaladjustment
check front fork bearings and adjust if needed
Check condition of rear shock
Check ignition timing and vacuum hoses
Test ride motorcycle
Jan 10, 2014 | Harley Davidson FLHRC Road King Classic...
2001 dodge 4x4 diesel abs and brake light on no codes exist
If the brake fluid is low or if you have low pressure, it will cause both of these lights to come on. This truck has rear drum brakes if I am not mistaken??? you also might want to adjust up the rear brakes some more. The rear brake shoes being out of adjustment can also cause this. Something else you might want to check is the rear speed sensor on the rear differential.
Apr 18, 2012 | Dodge Cars & Trucks
How do i replace rear brake pads off a 1995 ford contour
Check this REMOVAL & INSTALLATION
(see Figures 1, 2 and 3 / click over images for zoom )
CAUTION Older brake pads or shoes may contain asbestos, which has been determined to be cancer causing agent. Never clean the brake surfaces with compressed air! Avoid inhaling any dust from any brake surface! When cleaning brake surfaces, use a commercially available brake cleaning fluid.
  1. Remove 1 / 2 of the brake fluid from the master cylinder reservoir.
  2. Raise and safely support the vehicle.
  3. Remove the wheels.
  4. Remove the cotter pin and guide pin.
Fig. 1: Rear disc brake components
  1. Remove the caliper locating pin cover and remove the locating pin.
  2. Swing the rear disc brake caliper away from the brake rotor and anchor plate. There is no need to remove the parking brake cable or brake hose.
  3. Remove the inner and outer disc brake pads.
To install:
  1. If installing new disc brake pads, use rear caliper piston adjuster T87P-2588-A or similar tool, to rotate the rear disc brake piston clockwise, retracting the caliper piston. This will allow room for the new brake pads.
Fig. 2: Removing the parking brake cable
Fig. 3: Use the adjuster tool to rotate the piston into the caliper
  1. Install the inner and outer disc brake pads.
  2. Swing the rear disc brake caliper back into position over the disc brake pads.
  3. Clean the locating pin threads and apply 1 drop of a thread locking agent or similar sealer.
  4. Apply a small amount of disc brake caliper slide grease to the shaft of the locating pin.
  5. Reinstall the locating pin and torque to 30 ft. lbs. (41 Nm).
  6. Reinstall the guide pin and the cotter pin.
  7. Adjust the parking brake by operating the parking brake control several times.
  8. Reinstall the wheel and tire assembly. Torque the lug nuts to 62 ft. lbs. (85 Nm).
  9. Lower the vehicle.
  10. Adjust the parking brake by operating the parking brake control several times.
  11. Pump the brake pedal several times to achieve a good pedal before attempting to move the vehicle.
  12. Check the brake fluid level in the master cylinder fluid reservoir and add fluid as necessary.
  13. Road test the vehicle and check for proper brake system operation.
Hope this helps (remember to rate and comment this answer).
May 01, 2011 | 1995 Ford Contour
How to bleed brakes on a 1992 Chevy Caprice. Specifically the rear drums
start from the fartherest place from brake master cylinder, that will be the rear passenger side wheel. it takes two people to bleed brakes. you will find the bleeder valve screws at the top of inside of the rear drums on both rear wheels, have someone pump the brakes up, will take at least 4 pumps of brake pedal, at 4th pump keep pressure on pedal while you break loose the bleeder valve on the rear wheel, fluid will come out and brake pedal will go down to floor, keep pressure on brake pedal until you've tightened the bleeder screw back [note] you'll only have to back the bleeder valve out about a half turn until you see the fluid come out. after you've done the rear brakes add brake fluid to the master cylinder as it will be low. then go to the front passeger side and you will find the bleeder screw on the brake caliper. repeat the same proceedure as back. remember that pressure on the pedal is a must until you've tightened those bleeder valve screws back or else it will **** air into the brake system. suggest that you bleed all 4 wheels not just the back. after you've bled the front make sure you add more brake fluid back to the master cylinder, it will be low again. hope this helps and thank you for choosing fixya.com
Nov 21, 2010 | 1992 Chevrolet Caprice
I noticed my clutch resovoir appears to be very low, if not empty. n reading the owner's manual, it states the fluid will "rise" as the clutch wears. Should I be able to see any fluid in the resovoir? What...
Do NOT add brake fluid to the clutch reservoir. The BMW clutch uses mineral hydraulic fluid which will not mix with brake fluid.
If your fluid is dropping, the chances are good that the slave cylinder is leaking. If not attended to soon, it will eventually contaminate the clutch, which will then also need to be replaced.
Oct 25, 2010 | 2006 BMW R 1200 GS Adventure
Brakes have a mushy to floor response
usually an indicator of either a loss of pressure due to low fluid and/or air in the system (brake fluid leak) or extremely worn rear brakes (if drum brakes in rear). possible causes include master cylinder (internal fluid pressure leak), external fluid leaks (calipers, lines, wheel cylinders), rear drum brakes extremely worn down or severely out of adjustment. normally worn disc brakes may reduce pedal height SOME, but seldom "to floor". but the "mushy" quote combined with the "floor" quote suggests a hydrolic fluid pressure problem.
Sep 13, 2010 | 2005 Ford Taurus
Brake fluid pressure
You are getting plenty of fluid to both rear wheels when you bleed it? Rear brakes drum or disc?
Apr 14, 2010 | 1999 Ford Taurus
How often do I need to service a BMW 123d?
Hi and welcome to FixYa. I am Kelly.
Here are your service intervals:
NOTE Besides Oil changes there are inspection intervals I & II
http://www.savagebmw.com/Service/content_service_Intervals.htm
Inspection interval I
BMW Inspection I (return to top) Undercarriage
  • Change engine oil and filter while engine is at normal operation temperature.
  • Check transmission for leaks.
  • Check rear axle for leaks.
  • Visually check fuel tank, lines, and connections for leaks.
  • Check condition, position, and mounting of exhaust system. Examine for leaks.
  • Check power steering system for leaks.
  • Check overall thickness of front and rear disc brake pads.
  • Examine brake disc surfaces.
  • Clean brake pad contact points in calipers.
  • Grease wheel center hubs.
  • Check steering for absence of play, condition of suspension track rods, front axle joints, steering linkage, and joint disc.
  • Check front control arm bushing for wear.
  • Check brake and clutch system connectors and lines for leaks, damage, and incorrect positioning.
  • Check for free movement of the parking brake cables. Adjust parking brake if necessary.
  • Check all tire pressures (including spare). Correct if necessary.
  • Check condition of tires (outer surfaces (left/right)), tread wear and pattern; In case of uneven tread wear readjust wheel alignment if required.
Engine Compartment
  • Read out diagnostic system
  • Check engine cooling system/heater hose connections for leaks.
  • Check coolant level and antifreeze protection level; add coolant if necessary.
  • Check level of brake and clutch fluid in reservoir; add fluid if required.
  • Check windshield washer fluid level and antifreeze protection. Fill up and/or correct if necessary.
  • Check air conditioner for operation.
  • Reset Service Indicator.
Body/Electrical Equipment
  • Check battery electrolyte level and add distilled water if required.
  • Perform batter load test.
  • Check lighting system, i.e. headlights, foglights, parking, backup, license plate, interior (including map reading lights), glove box, flashlight, illuminated makeup mirrors, luggage compartment lights.
  • Check instrument panel and dashboard illumination.
  • Check all warning/indicator lights, check control.
  • Check turn signals, hazard warning flashers, brake lights, horns, headlight dimmer/flasher switch.
  • Check wiper and washer system(s); wiper blades, washer jet positions.
  • Check condition and function of safety belts.
  • Oil hood, trunk/tailgate, and door hinges.
  • Grease hood, trunk/tailgate and door latches. Check operation of all latches.
  • Check central locking/double lock.
  • Replace microfilter or Acc. Cabin Filter.
  • Check heater/air conditioner blower, rear window defogger.
  • Check rear view mirrors
  • Visually examine the SRS airbag units for torn cover, obvious damage or attachment of decals, decorations, or accessories.
Final Inspection
  • Road test with check of brakes, suspension, steering, clutch/manual transmission or automatic transmission
Inspection interval II
BMW Inspection II (return to top) Undercarriage
  • Check thickness of parking brake linings.
  • Half-shafts; check for leaks at flexible boots.
  • Inspect entire body according to terms of rust prevention limited warranty.
Engine Compartment
  • Replace spark plugs (as applicable by year and model)
  • Replace intake air cleaner element.
  • Replace microfilter or Acc Cabin Filter.
Final Inspection
Service indicator lights if installed:
http://www.savagebmw.com/Service/content_service_IntervalsLED.htm
That should just about cover the works other than failures.
Thanks for using FixYa!
Kelly
Feb 16, 2010 | 2008 BMW 1 Series
Bleeding abs brakes
Try using a pressure bleeder. It will force the air out. Works every time.
Nov 08, 2008 | 2001 Ford Mustang
Shimano 24 Speed  Road Racing Bike Bicycle Modell Rs888 Logo
458 people viewed this question
Top Shimano Cycling Experts
Michial Gueffroy
John Egan
John Egan
Eric Hidle
Level 1 Expert
Are you a Shimano Cycling Expert? Answer questions, earn points and help others
