You can now buy a wheel with an all-terrain larger tyre on ebay or through DorelYou can now buy a wheel with an all-terrain larger tyre on ebay or through Dorel
You can't post conmments that contain an email address.
hello,what is the mileage on your audi? has it had a very hard life? the most common faults that we see in our workshops are- drive shaft inner velocity joint's.have your vehicle inspected visually,get the wheel balancing done,also swop the front 2 wheels and tyres for the rears (provided that you don't have staggered sizes, ie; larger as opposed to same size) hope that helps, cheers.
This system is hot swop, which means you can take out the 'faulty' drive, and put in a new one. The system will then copy all the data over automatically.
Just double check your configuration (operations manual) to be sure the drives are properly set as hot swop with auto switching data transfer etc. Don't take my word for it because I haven't physically seen your setup so I cannot be 100% sure it is configured correctly.
BTW, Serious Thumbs Up on making a great choice on your NAS system, HP X1600 is my all time favourite so far and my personal reccomendation to all my customers at the moment!
is it one coil for each cyl or a double ht ? if single coils swop over and see if problem moves ! if double ht then swop leads over if you unbolt the coil and fit an earth wire to the coil body and try in a dustbin of water ! sometimes the ht are too short to swop ! check connections and earths !
Unfortunately they make them the way no other wheels will fit on there, you can look for a jogger that has big air filled tires they will be easy to steer.
Unless it has been modified it is a 1.9L 4 cylinder, the same engine in all Saturns from 91-99. The only difference is whether or not it is a SOHC or DOHC, meaning single or double overhead cam. Double overhead cam has spark plug sockets in the center of the top of the head and is overall slightly larger than the SOHC engine which has spark plug sockets on the front of the engine. Usually there will be something on the rear bumper like DOHC as well. The engines are nearly identical in all other respects but the transmissions are not the same. If your car has 14 inch wheels most likely you have a SOHC while if your wheels are 15 inch you have a DOHC.
I'm not really sure. With the double drawer configuration, I know the top drawer is larger than the bottom drawer. If I had to take a guess, I would say the single drawer might fit in the top of the double drawer.
First of all, a heartfelt congratulations! Second, it's definitely challenging having children so close together.
The Zooper Boogie is a good stroller and it's engineered in a VERY specific way to provide baby safety and comfort. It does this by providing a slightly lower center of gravity focused on the rotating single front wheel. This makes it more maneuverable for parents and keeps baby at the center of the swivel. Attaching a second compartment on the front or back of this particular carriage would undermine the engineered balance, tremendously. At least one occupant would suffer from an extended swing when maneuvering that could be more than just uncomfortable, especially if it was extended forward over the front wheel. Some stroller companies might be willing to do this, Zooper doesn't.
The best alternative that they offer is the Tango which is engineered for two. I know that you mentioned that you wouldn't purchase a double stroller but modifying a single might be uncomfortable and possibly dangerous for your little ones. I would recommend against it.
