Question about Altec Lansing ACS 490 Computer Speakers
Need users manual for a altec lansing acs 500 speaker system
Has acs 250 subwoofer/ surround sound dolby pro-logic. i want to connect this to my computer
How do I get the C5 Subwoofer to activate?
Hello
If subwoofer is inactive now, the sound preference settings you set now is wrong.
Before using the remote control for the following
operation
* Set the remote control mode selector to AUDIO
** There are exceptions in the operation mentioned
above. In such a case, follow each instruction
Dolby Pro Logic II*1
# Dolby Pro Logic II has a newly developed multichannel playback
format to decode all 2 channel sources - stereo source and Dolby
Surround encoded source - into a 5.1 channel.
Dolby Pro Logic II has two modes - Movie mode and Music
mode
# Pro Logic II Movie (MOVIE)
Suitable for reproduction of Dolby Surround encoded sources
# Pro Logic II Music (MUSIC)
Suitable for reproduction of any 2 channel stereo music sources
# Dolby Digital*1
Used to reproduce multichannel soundtracks of the software
encoded with Dolby Digital
# DTS Digital Surround*2
encoded with DTS Digital Surround. DTS Digital Surround (DTS) is another discrete multichannel
digital audio format available on CD and DVD software
Jun 19, 2011 | JVC TH-C5 System
Whent I connet my android to my samsung HTC55 using the aux 2, just one speaker work, that is correct? is there a way to connect my android and all my speakers work
Your Android phone can only output in mono or stereo, but it does not have a surround sound decoder, so it cannot output natively to a 5.1 surround sound system. However, your HTC550 has a Surround Sound Mode called Dolby Pro Logic II, which will simulate 5.1 sound from any stereo input. Try activating Dolby Pro Logic II mode on your receiver to get surround sound on your Android phone.
Apr 28, 2011 | Samsung HTC550 Theater System
I have altec lansing pro logic speakers from my
Check that your computer doesn't have a microphone (internal maybe) and that it's not switched on.
Cheers.
Jul 08, 2010 | Audio Players & Recorders
Connected to laptop with vista via USB connection to speakers - NO sound
A letter from Altec: E-mail from Altec Lansing explaining how to use the ACS 495 speakers with Windows XP and Vista: "These speakers require no special drivers or software to work properly. At the current time we do not have AMS software or an USB audio device driver compatible with Windows XP or Vista. There are no plans at this time to develop this software. Your speakers will work with Windows XP & Vista. Just make sure you use the audio cable from the back of the subwoofer to the audio or sound out port of your sound card. Do not use the USB cable. Sound does not come through the USB port The USB cable just allows you to use the AMS software. This software gives you some control over some of the sound features. The same functionality of the AMS software can be gotten by using the buttons on the speakers and the volume control software that comes with your Windows system. If you double click the speaker icon from the system tray, that will open this software up. With the USB connector removed or the computer turned off, STEREO or PRO LOGIC modes can be selected by depressing and holding the center control down for approximately three seconds. The mode selected will be indicated by the color of the LED on the front right speaker. When the light glows yellow it is in the STEREO mode. When the light is green it is in the PRO LOGIC mode."
Nov 09, 2009 | Altec Lansing ACS 495 Computer Speakers
No sound coming from ACS 48 Altec Lansing speakers
Hi janros123 - I don't know if this will help - I have a subwoofer ACS48 that needs satellite speakers (they are blown). Want to buy my subwoofer or sell your satellites? I will buy your broken subwoofer, too...thanks, and good luck! Greg illdooyoo at gmail dot com
May 16, 2009 | Audio Players & Recorders
Altec avs500 speaker sound in 2 speaker only and not the rest
Try making sure the surround sounds knob is turned all the way to the right and that the switch on the subwoofer is on stereo and not gaming.
Mar 13, 2009 | Altec Lansing AVS 500 Computer Speakers
I have altec lansing speakers AVS500 and have no sound
It sounds like the subwoofer speaker has blown. If you are comfortable working with a soldering iron and speakers then you can open the case and replace the speaker with a replacement subwoofer speaker. A good online store for replacement speakers is PartsExpress.com
Dec 28, 2008 | Altec Lansing AVS 500 Computer Speakers
Connector problem
just buy a minijack-minijack cable. It's very cheap.
Jun 05, 2008 | Altec Lansing VS4121 Speaker
Surround wont work
try and download sound softwares from majorgeeks.com.
hope this works.
Jan 05, 2008 | Altec Lansing VS3251 Speaker
Home Entertainment
It depends on what you want. Is your existing solution a surround sound system (You only mention a subwoofer, what other speakers do you have?)? Do you want full 5.1 or 7.1 surround sound? If you don't have this, and want it, your amp will have to be replaced, but your sub will fit in just fine. If you currently only have front left and right speakers, you will need to purchase a centre speaker and another pair (5.1) or two pairs (7.1) of speakers.
Sep 13, 2007 | Audio Players & Recorders
963 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
