Question about Cisco WRT320N Wireless Kit
The wireless on my new router is not working but the wired is.My wireless can connect to the signal but it stills says no internet access. it was working earlier today but not now. I have a Linksys WRT320N Router.
  • 2,260 Answers
If you connect the computer to the router , it works.
That means the wired connection is OK.
Open the set up page of the router check the wireless settings of the router.
I think your network is secured and you are not typing the correct network key.
just open the router set up and check the wireless settings .
Make sure that the DHCP server on the router is enabled
Click Here for step by step solution
Posted on May 10, 2010
Losing network connection
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Oct 19, 2012 | Toshiba Computers & Internet
Hi I have a RangeMax - and it has always been working fine. Last week I couldn't connect wirelessly, so I reset. Nothing. Now I've tried connecting wired through the hub - still nothing. The power is...
Can you please check the signal strength of the wireless router.
If you can log into the wireless router management page and check for the erros if any inside the logs.
Oct 30, 2010 | NetGear RangeMax WPN824 Router
My Netgear WNDR3300 just quit putting out a wireless signal. I just bought a new Compaq notebook and the wireless internet was working for like three days and now nothing. And it is running windows 7 and...
It seems that router wireless setting need to reconfigure,please follow steps to resolved issue
1. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
2. Access the router, usually by typing 'http://192.168.0.1' or 'http://www.routerlogin.com' in the address bar.
3. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. If WPA is selected in Security mode, then check the Password that show up in the passphrase box.
now try to reconnect wireless
Thanks for using Fixya
May 14, 2010 | NetGear WNDR3300 - RangeMax Dual Band...
download and install this program http://www.xirrus.com/library/wifitools.php - that should detect all the wireless signals being broadcast - check to see if your wireless is there there could be a few things 1) Loginto the router and remove the wireless encrytipn - see if you can connect now 2) loginto the router and make sure the wireless is enabled and on - should be a light on the front of the router when the wireless is on 3) remove your wireless profiles from the laptop http://mgmcc.forumotion.net/networking-tutorials-f17/removing-an-existing-wireless-profile-t109.htm 4) Your HP may have a wireless switch - some a physical switch other use a combination of the FN key + one of the F key to toggle on/off - make sure this is on
Mar 24, 2010 | NetGear WNDR3300 - RangeMax Dual Band...
Can connect to router and internet by cable..unable to get wireless to connect
Reset the router with the little reset button on the back. If still no signal, then you most likely need a new router. However, don't throw the old one in the trash. If the wired ports still work, it will make an excellent bridge from your new router to another room in your house that needs wired connections. I use my old router to connect my DVR, TV, Blu-Ray, and XBox 360 to the internet using the wired ports, and have it wired to my main router. If you don't need it for that, find a friend or family member who does.
Jan 06, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
One PC will not connect to Router and therefore Internet.
Sounds to me like the problem is related to the PC hardware. Please check the following in your PC:
- Network card is properly working
- Network cable connecting to the PC is properly working
Sep 21, 2009 | Belkin (F5D5231-4) Router
Lg r 405 will not recognize wireless signal from lynksys wrt350n
hi i would suggest to access your routers setuppage and set the channel to channel 11.
make sure also if your wireless network is secured, type the correct key those things are case sensitive.
to access the routers setuppage go to a computers that is connected to your linksys router (wired) then launch IE on the address bar type 192.168.1.1(this is the routers ip) then it will ask you for username and password for the username dont type any thing for the password type admin.
when your on the setuppage click on wireless tab. while on the wireless page set the channel to 11.
after that click apply or save settings on the page.
then after that try to connect to your wireless network on your laptop.
for further help you can call linksys hot line 1800-3267114
they will surely help you with this.
hope this helps.
Oct 19, 2008 | LG X-Note LM50 Notebook
Belkin router
it is possible that the settings for your ISP is already gone or the router is not recognizing the settings.
Oh by the way who'se your ISP, is it cable or dsl internet?
For cable internet the router's internet/WAN connection type must be set to "Dynamic" for DSL internet there are some that will require you to setup your userID and password given to you by your ISP, to do this just change the connection type to PPPoE and fill out the required fileds(usually it just the userID and password from your ISP).
To access your router setup page, just open internet explorer on your computer(given that its connected wireless or wired to the router) and type http://192.168.2.1 . Type admin for the password and leave the password blank.
Jul 15, 2008 | Belkin (F5D5231-4) Router
Wireless and internet
1. Make sure that wireless settings are properly synchronized.
>> ssid/security key.
2. Check your computers wireless connection status
> Make sure that it is set to "obtain ip address automatically)
3. If still not working if computer is set to obtain ip automatically, try assigning static ip on wireless pc
> You need to know your router's ip address and dns
4. Disable firewall on wireless pc.
Jan 23, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
Internet problem
Are you attempting to access your own wireless router? Do you know how to access your wireless router configuration? Does your wireless router support wired connections? If so, does your computer work on the on the wired connection? What is the manufacturer and model of the wireless router, laptop computer and if a separate accessory the wireless network card?
Thanks
Dec 05, 2007 | Computers & Internet
Cisco WRT320N Wireless Kit Logo
252 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
Gareth Tomlinson
Gareth Tomlinson
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
