Question about Fuji FinePix F40fd Digital Camera
Broken Battery Door
Two small pieces of plastic have broken off of my battery door. One seems to be used to depress a switch that tells the camera that the door is closed properly, and the other is simply a tab that keeps the door from springing open. The camera won't turn on without the door closed, but if I stick a pin into the hole that the first piece of plastic used to fit into, the camera turns on and seems to work fine. Is there any way that I can get a replacement door, or otherwise solve the problem?
  • 667 Answers
I would think a call to Fuji would be in order: 800-755-3854
They should be able to sell you a new battery cover
Posted on Mar 28, 2008
6ya staff
SOURCE:
I have a CANON camera A610 - since i changed the batteries it is not powering. The batteries are new. Please advise the possible problem
Double check that the new batteries are actually good. Note that so-called "heavy duty" batteries are terrible for use in digital cameras.
Next thing to check is the battery door slide switch. This is a tiny black micro-switch in the the battery compartment. It's activated by a tiny plastic piece on the battery door slide mechanism that may have broken off.
Dec 17, 2009 | Canon Cameras
Nikon D200 battery door - is it broken?
The battery door is meant to come off so the MB-D200 battery pack can be inserted, but it sounds as if yours has broken. There should be equally-sized rods that form the pivoting hinge, on on top and one on the bottom. Yes, you can buy a replacement part, probably through a local dealer or online. I believe online they cost around $20-$25. To remove the door, you are supposed to open the door to a 60-degree angle to the camera body and gently pull the door off. To replace the door, again, hold the door at a 60-degree angle to the body and gently press it into place. Or you could pay a repair shop an arm and leg to do this for you ($50 or more + shipping if you use a mail order repair shop).
I remember the 'good old days' when film SLR's were made to take a beating. Sadlly, we're in the era of plastic and I always have to remember to treat every piece of equipment as if it were made of glass!
Hope this helps?
Dec 13, 2008 | Nikon D200 Body Only Digital Camera
Turns on only for split second!
I was just trying to solve this exact same problem on my girlfriends A345 and upon inspecting the battery door I noticed a small tab had been broken off. I lined up the tab and just above the memory card where it says push to eject there is a slot. In that slot is a tiny black pressure switch that the broken off tab used to depress. I stuffed a small piece of wire in there and hit power and it works just as it did :) hope this solves your problem as I'm sure these tiny tabs break off without people noticing since the battery door closes and locks without them
Oct 28, 2008 | Fuji FinePix A345 Digital Camera
Broken battery compartment door switch
The switch is a micro switch that is depressed(and not sad :)) by a plastic tag moulded on the battery cover. Once the cover is moved into position and closed, the tag presses on the micro switch closing the switch and thus removing the error message. As with any switch, a switch is simply open or closed, Open = high resistance or O/L, while closed = 0 ohms reistance. You can use a small wire to overcome the switch by soldering the wire to both tags of the switch so it is permenantly 0 ohms. This will send a message to the microprocessor that cover is closed and camera ready for use. Hope this helps.
Twitcha
Sep 28, 2008 | Olympus FE-140 Digital Camera
Battery door broken
You're making it harder than it has to be. Simply hold the camera in your left hand, and open the battery door so it is standing up. Look closely at the lower left corner of the batterry door. Notice the notch shape. The door plastic door is locked in place by the mating little "L" shape on the hinged door of your camera. Thats all that keeps it from sliding off when you put in batteries. Simply insert a small screwdriver or knife blade in that slot, twist it counterclockwise to push the battery door lock to the left, and slide the door off with no force at all. It's a snap.
Jan 15, 2008 | Sony Cyber-Shot DSC-S500 Digital Camera
Card-cover open
Look for the switch on the memory card door of your camera. Usually a small piece of plastic on the door closes the switch when the door is closed. Check to make sure that the plastic piece is not worn down and is making contact with the switch. You can confirm that this is the problem by powering on the camera while closing the switch manually with a toothpick. Make sure you keep your fingers clear of the extending lens while doing this. If the plastic is worn down or broken off, try attaching a small piece of scrap plastic with super glue.
Dec 16, 2007 | Olympus C-7000 Zoom Digital Camera
Broken part on camera
I suspect you won't be able to buy the part. However, you might be able to fashion a suitable piece of plastic and glue it in place using an expoy resin adhesive like araldite. Or use gaffer tape to hold it shut! Samsung may be willing to repair it but it'll probably cost you.
Oct 28, 2007 | Samsung Digimax D53 Digital Camera
Broken door
Tape it shut is the only solution here No Spares no Repairs.
Jul 06, 2007 | Pix S-470S Digital Camera
Not turning on
Hello Ariel, You need a new battery lid. The problem is the lid has a pin that when closed properly, allows the battery to power up the camera. You can get one for $30.00 on Ebay item number 7623965577 if you act fast. This is a good camera and would be worth $30.00 (plus 5.50 shipping) to fix it. Please let me know how it works. Best regards, nightdiver
May 31, 2006 | Kodak EasyShare C340 Digital Camera
Fuji FinePix F40fd Digital Camera Logo
568 people viewed this question
Top Fuji Cameras Experts
Ekse
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
