Question about Medion MD-40954 Notebook
My laptop cut its self off and will not come back on
  • 4,281 Answers
First open back cover of laptop then reattach the battery and ram memory.
Then if it is still not power up then check with new battery.
If with new battery it is still not power up then you need to repair your laptop motherboard circuit at service center.
But if your laptop is power up then make sure in bios your harddrive is recognized.
For that when you power up laptop press F1 or F2 or del or ALT+F2 then you can see bios then make sure SATA is disable and harddrive is recognized.
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on May 10, 2010
What does "self healing" mean on a cutting mat?
A self healing cutting mat is one that after a cut is made it appears that the the mat heals itself (there isn't a line where the cut was made) but of course like most consumer products after extensive use they will eventually stop healing.
Sep 23, 2013 | Office Equipment & Supplies
My Yamaha amp turns its self off despite being connected to power! Standby button will not turn it on!
Try blowing the dust out if the back and allow air to flow around it as it might have a thermal cut out which means when it gets to hot it cut its self out ( hope this help )
Mar 22, 2013 | Audio Players & Recorders
When raising the bar to start to cut the Toro makes a terrible squeaking and the engine cuts. Help. The lawnmover will start. It is model 2622-21" rear bagger. We cut the back lawn and went to cut...
Is this a self propelled? Since it will run, blade spinning, the bar you are mentioning to start cutting is for the self propelled drive. The terrible squeaking is probably the belt slipping due to something causing the wheel to bind. Check for the ability to turn the drive wheel by hand. Then check under the cover for any binding.
I hope this helps you out.
Jul 27, 2011 | Toro Garden
I was wiping the hard drive when the laptop
Please come back to us with the exact error if you get any.
However, how you are performing recovery. Using recovery manager or recovery discs?
If you are using recovery manager, please perform hard drive self test and check with the result.
Hard drive self test steps:
1. Turn Off the notebook.
2. Turn ON the notebook and keep tapping F10 key
3. Once you are in BIOS, navigate to tools/diagnostics tab with the help of left and right arrow key.
4. You will find Primary HDD self test or HDD self test.
5. With the help of up and down arrow key select the respective test and hit enter.
6. Short test will take only 4-5 minutes. However, long test may take 40-60 minutes.
If the hard drive is fine, try to perform recovery using recovery discs....
If still the problem exists try with different discs.
If the hard drive fails replace the hard drive.
Hope this will work for you!!!!!!!!!!!!!!!111
Mar 17, 2010 | HP Compaq Presario V2000 Notebook
My phone has been cutting off by it self. Sometime's when the phone cuts off it will turn back on and say something about emergency download. Now my phone has cut off and will not turn back on
try to RESTORE FACTORY SETTING first, see if it ca fixed the problem, but if not, it wil need to be open and re-heat or resolder the specific IC or chips inside it.
Oct 31, 2009 | LG Vu CU920 Cellular Phone
Computer screen wont show up
The processor is damaged. or overheating. the laptop powers it self off to prevent damage. Have it serviced as soon as possible to try to save the processor.
Apr 02, 2009 | Dell Inspiron 1521 Laptop
LAPTOP WILL CUT OFF OR FREEZE UP FOR NO REASON
re-install the windows to fix that problem...
Mar 12, 2009 | Everex StepNote VA4103M Notebook
The Oven won't heat up
the thermal cut off located on the back of the oven has probably tripped,common problem. replace thermal cut off.
Dec 19, 2008 | Whirlpool RBS245PDS Electric Single Oven
Medion MD-40954 Notebook Logo
Top Medion Computers & Internet Experts
John Anderson
John Anderson
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
