Question about True GDM-47 Refrigerator
My GDM 47 refrigerator is not turning off, and I have replaced the open air thermostat control on it. Could I have done anything wrong in the installation or is it something else?
4 Suggested Answers
woodchuck789
  • 4070 Answers
SOURCE: Our GDM-47 refrigerator is not cycling on and off.
Is it getting cold enough to cycle off. Should be around 10 degrees in the freezer.If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will gradually cause it to warm up because ot the blocked air flow.
Posted on Aug 30, 2009
  • 88 Answers
SOURCE: Tru GDM-47 cooler evaporator icing up.
possible bad defrost timer,or control on an off is bad,were you adjust temperature...thermostat from 30 to 65.00 dollars....possible there is leak or unit is under or overcharged..more than likely under charged...possible defrost heater is not working...good luck..michael doctor airr appl.repair..service tech..843-384-8474...call if need additional help ..its free..
Posted on Mar 27, 2010
  • 906 Answers
SOURCE: GDM-41 Refrigerator: True GDM-41 Refrigerator getting too cold...
good day,
hope this link below will solve your problem.
ref
Posted on Aug 03, 2010
Temperature has dropped to 10 degrees.
If the refrigerator seems to run all the time, then the problem is probably the thermostat. The -49 thermostat consists of a 30"(approx) sensing tube connected at one end to an electric switch box with control knob (the knob is usually labeled "COLDER". The switch box electrical contacts could be stuck closed, or the sensing tube has been damaged such that the switch box is getting the wrong signal. In either case, replacing the the thermostat module/sensing tube should solve the problem. These modules cost in the range of $50 to $100.
Mar 18, 2015 | True GDM-49 Refrigerator
Gdm 45 with new thermostat goes down to 28 degrees and compresor does not shut down
If the new thermostat sensor is secure and where it belongs, it has the wrong charge in the system. That cooler takes a critical charge. The factory charge is in ounces if refrigerant. The system needs to be evacuated completely with a vacuum pump and recharged with an accurate scale that weighs in ounces. That will solve your problem. A refrigeration tech carries the necessary tools that an hvac tech doesn't. Hope this helps and good luck.
Apr 13, 2014 | True GDM-45 Refrigerator
My true GDM-26 never shuts off and my drinks are frozen?
Faulty thermostat, the thermostats are cheap and wear out easy
Aug 15, 2013 | True GDM-26 Refrigerator
I have a true commercial refrigerator that the temperature is not working. It reads 11 degrees F and wont go up using the temperature control knob. Any advice?
The only thing it could be is the thermostat. Or, maybe your thermometer is reading wrong. Is everything freezing up? The thermostat is located up near the top usually on the side of the fan housing inside. It is easy to replace if you have a refrigeration supply company close by.
Sep 27, 2010 | True GDM-12 Refrigerator Commercial
Got a true cooler with a new compressor... noticed ice on evap when checking temp contrl. replaced temp contrl and still not getting as cold as it should be... ???
probably an wrong freon level. Check that out. could be a freon leak from when the compressor was replaced. Bad weld joint could be the issue.
Let me know if I can be of any further help,.
Jun 16, 2010 | True GDM-47 Refrigerator
Mar 27, 2010 | True GDM-47-RL Refrigerator
Wire that connects thermostat to air diffuser assembly severed
Yes, the air diffuser has to open to allow the cold air from the freezer to be blown into the fridge.
Sep 21, 2009 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Our GDM-47 refrigerator is not cycling on and off. we changed the temperature control
Aug 30, 2009 | True GDM-47 Refrigerator
GDM-26 humidity very high
assuming fridge is at correct temp, i suspect fault is with your humidity detector. the humidity inside a fridge is a lot less than the outside air
Oct 09, 2008 | True GDM-26 Refrigerator
True GDM-47 Refrigerator Logo
35 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
