Question about Roper RT21AKXKQ Top Freezer Refrigerator
Refrigator with a top freezer freezes up about every 4 weeks
What is your best estimation of what is wrong with it to the last thing that could be wrong with it. it is a roper refrigator . havent had too long.
    Guru:
  • 1,705 Answers
Check the door and seals, does it close and seal properly.
If the seals are letting in warm air, the fridge goes into overtime, hence freezing up.
Its also worth checking that the fridge isn't on too higher setting.
Posted on May 10, 2010
The coils in the. Back of the freezer keep freezing up! I use a hair dryer to thaw...freezes up again...what is wrong
The problem could be in the draining of defrosted ice. The drain may be clogged thus allowing water to back up. Next I would check the fan and make sure it is running. The last thing if that doesn't help is get a refrig specialist to check out evaporator and compressor. Now consider this, if it is much older than 10-12 years old , you may want to replace it. His sometimes is the beginning of the end.
Feb 03, 2013 | Amana ABD2533DES Stainless Steel Bottom...
MY MAYTAG MTB1891AR TOP FREEZER IS NOT FREEZING PROPERLY. THE REFRIG SEEMS TO BE COOLING FINE??? COULD THIS BE A DEFROST TIMER ISSUE?
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 16, 2011 | Maytag MTB1891AR Top Freezer Refrigerator
Fan seems to be working, but feezer and refrig. not as cold as should be, ice cubes not freezing over night. fan motor was replaced about a year ago. refrig. is about 8 years old
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
heatman101
Sep 26, 2010 | GE GTS22KBP Top Freezer Refrigerator
Rt18dkxhw00 refrig , frezer not freezing and refrig a little warm
freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Sep 10, 2010 | Roper RT14DKX Top Freezer Refrigerator
Mod#RS25AGXN002 FRIG NOT COOLING FREEZER NOT FREEZING
the return air ducts are iced up and need defrosting, empty the fridge and freezer and unplug for 3to 4 hours with the doors open
Oct 03, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Items in the back of the refrigerator freeze.
is this something that has just started happening? Most kenmore top freezers have a vent that allows cold air from the freezer into the refrig through a vent located on the back wall in the center of the refrig section. if packages are pushed up under this vent they can freeze.
If you have widespread freezing in the refrig setion then a temperature control could be the fault. thanks for using fixya. Peyton..
Feb 17, 2009 | Kenmore 72992 / 72994 / 72999 Top Freezer...
Frigidaire side/side refri section warm
Oceanrunner, it looks like a couple of things might be going on: One is how much defrosting did you do. If it was a full defrost, you might have too many door openings going on. This causes condensation. Do a full defrost and then be sure the door is closed when not actually getting things in/out. Don't forget to check to see if your condenser coils are clean. If not, clean 'em! That may fix it.
It is possible that your defrost timer is defective but I think not based on your defrost cycle starting. It is possible that the defrost coil is bad. This means that you'll have to access the coil and check if for continuity. Typically, this is located with the coils and below them in the back of the freezer. One wire on each side. Unplug the box...Wiggle 'em to clear any corrosion... Unplug..If you've got a multimeter, check for about 100 ohms between the terminals...You can then turn the unit on and wait. See what happens. If frosting begins, actuate the defrost cycle. (Frosting should be even after about 5 minutes or so across they pipes. If the gas level is low, the frosting will not be even.)
Some cold water units run through the coils. If they get too cold...they freeze. This is caused by low gas or by frosting from other sources. Don't panic: this unit has an extended warranty on the sealed unit...the compressor and all that...for 5 years. That means the gas, too. Call your manufacturer for service.
Nov 28, 2007 | Refrigerators
Roper RT21AKXKQ Top Freezer Refrigerator Logo
141 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
