Question about Rainbow E series Canister Wet/Dry Vacuum
Rainbow e series
I live in the uk and bought my machine from the us what transformer do i need to be able to use my machine in the uk.
    President:
  • 1,673 Answers
You need one that will reduce your 220V AC to 110 AC that we have here in the US.
Posted on Mar 29, 2008
I want to take apart and clean my D4C Rainbow and my E series 1 speed, I bought both of them on Ebay, and both have odors,( They are suppose to be the vacuum that cleans and purifies the air) that leaves...
Sorry, but a Rainbow D4 has no filtration at all. The E series has a HEPA filter that needs replacing. You can put liquid Lysol in the water on the D4 and that will help
Apr 30, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Have a rainbow e-2 that was running and quit.
Hi, there is no reset button on a Rainbow vacuum. There is a safety switch on all E series and E2 series Rainbow vacuums, that keep it from running without the water basin on it.
If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
Apr 25, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Im looking for a supplier in uk as my hose for my rainbow hoover is broken, can you please give me an email add or phone no. thanks
hi
they are US based
Customer Service
If you have questions about any Rainbow product, please contact Rexair’s Customer Service Department. They will provide you with the answers you need, or will direct you to a local Rainbow Distributor who can help get you the information you need.
To contact Rexair World Headquarters,
you can write:
Rexair LLC
50 West Big ******, Suite 350
Troy, MI USA 48084
Or call, (248) 643-7222,
Monday through Friday,
between 9:00am and 5:00pm (EST)
and ask for Customer Service.
OR email at
customerserv@rexairllc.com
Feb 24, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow water not spinning
All Rainbows - remove the hose and turn it on without the hose plugged in - if works better - hose is clogged
If it works bad even with the hose out:
E-series Rainbow - take HEPA filter cartridge and try then. If helps - you need new HEPA (you can get it here)
SE Rainbow vacuums - remove exhaust cap
and you may find a dirty sponge in there - just remove it and it may help.
If none of that made any difference - you may need it to be checked. If you do not mind shipping - our info is HERE
Feb 15, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow E Series
You are supposed to use the hard surface cleaner solution and mix with water. Vaccum the hard surface first, then dip the hard surface attachement in the mixture (while machine is off. otherwise you will just **** up all the mixture! :) ) turn on the machine and "mop" away!! I love it!!
Jun 23, 2008 | Rainbow E series Canister Wet/Dry Vacuum
How do I remove the pin on my Rainbow Vacuum Model SE clips?
When I used to repair Rainbow SE vacuums for a living, I had a long nail of small diameter that I had filed the end off of just for this purpose. The pin you need to remove is grooved on each end to "catch" in the plastic housing, but a slight tap with a hammer, using this "nail" will do the trick. When you're ready to re-attach it, just tap it again to put it back in place.
Apr 04, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Wattage
Sorry I don't. but E series owner manuals. I don't know if it says in them or not, but you can here to take a look:
http://www.rainbowsystem.com/manuals/
Or you can maybe contact them direct.
Mar 30, 2008 | Rainbow E series Canister Wet/Dry Vacuum
My Rainbow E series power switch doesn't work
To get access you need to remove the plastic side cover panels. To remove these, I found the easiest way was to use a small flat screw driver, leverage it under the pastic in the centre at the 'cord end' and lift carefully. There are two lugs at the top and one at the bottom. The plastic panel will 'bow' a little, but with care, it will pop off. The gold looking vents underneath are just a 'facade'. By removing the side plastic panels they will expose three screws either side. Undo these and the top will half of the cleaner will lift off. Good luck!
Jun 25, 2006 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow E series Canister Wet/Dry Vacuum Logo
136 people viewed this question
Top Rainbow Vacuums Experts
Joseph Hoffmann
Jax Planet
Jax Planet
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
