Question about Toshiba 1370 Black and White Copier
WRENCH LIGHT HOW TO FIX THE WRENCH LIGHT FLASHING ON COPIER
  • 40 Answers
Hold down the c and 8 key this will give you a code give me the code i will tell you the fault
Posted on Jun 21, 2010
2 Suggested Answers
  • 58 Answers
SOURCE: Panasonic FP-7113 Plain Paper Copier
Service Time imageunit can be removed with two screwsand remove tank before lifting out. You can remove drum and cleaning blade section yourself 4 screws. Two on the cleaning and two on the removablr pins on the side.Then remove blade with two screws and fit cleaning blade and drum and reinstall.
Service manual for service mode to remove spanner display F9 ??
Cheers Justin
Posted on May 01, 2008
Our Data light keeps flashing and the printer won't print. How do we get the data light to stop flashing so we can use our copier again with our computers?
Sounds like a bad print job stuck in a print spooler.
Turn off copier. Go around to all computers that print to it and open the print queue. delete all print jobs. reboot each PC. Power up copier and see if it clears
Jan 15, 2013 | Sharp Mx-M450nb Digital Copier
Dp8020 wrench icon flashing and add paper red light on
Press the "Function", "Original Size (Ledger/A3)", and "3" keys simultaneously to enter the Service
Mode.
3. Enter the password, if required and select "OK" button (default password is 000 or 0000).
4. Enter the Copy Service Mode F9-06 and select LBP Fuser reset. Execute by pressing the green start button.
5. restart the machine after completion
Sep 26, 2012 | Panasonic DP-8020E Black and White Copier
You have a problem in paper casette,mechanical problem.Remove the paper casette and verify jamed paper or paper sensor blocation.
Apr 12, 2012 | Panasonic DP-8020E Black and White Copier
I have a Sharp Printer 2007 AL-1631 with a red flashing light. Can you tell me how to fix it?
Which light is flashing? One that looks like a small battery or the one that looks like a stack of 6 "dots"?
Oct 25, 2011 | Sharp AL 1631 Copier
I have a toshiba 1370 copier....the repair wrench is flashing and won't let me continue, how do i get the wrench to stop blinking?
switch on the machine, holding down 0 & 8 buttons, type in 89, press the green button, enter a 0, press green button again to accept the new value. switch off & then just switch back on as normal.
good luck.
Nov 13, 2009 | Toshiba 1370 Black and White Copier
How do you reset a lanier 6112 copier so the wrench stops flashing. thanks
The maintenance time is flashing.To be use the service enter code C-0-0-C or C -Interrupt-0-Interrupt,then press 20(maintenance counter clear) and 72 maintenance preset counter setting for a new value.
Aug 07, 2009 | Lanier Office Equipment & Supplies
Ricoh Aficio 350e copier Multifuntion machine
This blinking wrench red light means that your copier needs to be serviced. How old is your copier or how many copy have you done with it ?
Otherwise, you may need to call a service man for it.
Sep 08, 2008 | Ricoh Aficio 450 Copier
Cheers Justin
Apr 30, 2008 | Office Equipment & Supplies
Panasonic FP 1780 Copier. The copier has a flashing wrench that will not reset. I need advice on resetting the wrench.
Hold down 3 buttons in this order:
Paper Tray (Oval button), Recall (Diamond) and #3.
You should see an F2 in the display.
Enter #5 (Display should be showing F5)
Hit the Print Button. (Display should show C00)
Enter 70. (Display should show C70)
Hit the print button. (Display should show probably a 7 or 8)
Hit the print button again. The print button should go Red for a second and then back to green.
Wrench should be gone.
Next to get out of service mode
Hit Clear / stop button until the display shows F5
Then hold down 3 buttons in this order:
Paper Tray, Recall and the Clear Stop button.
You should now be back to working order.
If you have any questions or need parts, feel free to ask.
Have a good day.
Good luck.
Please remember to leave your rating if I have helped you.
Mac
Apr 15, 2008 | Office Equipment & Supplies
Toshiba 1370 Black and White Copier Logo
296 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
