Question about HP OfficeJet 6210 All-In-One InkJet Printer
Can not reinstall printer software
My printer stopped scanning so I reloaded the software. This uninstalled the existing software. However on re-installation a fatal error occurred due to a more up to date file existing. I thought the uninstall would have taken care of this. I now have no way of re-installing the software. I have tried 3 times and the install stops at 14% each time with the fatal error msg. Any help appreciated.....
  • YourZEN
    YourZEN May 11, 2010
    Hello, Tried all steps following ? 1. disconnect the printer from the computer 2. go to the control panel and delete this printer in the hardware 3. reinstall the printer and wait making a connection until the installation has finished or when a text says to do so.
  • 109 Answers
If you have a cd for the driver explore to contents of your CD
got to the UTIL folder then go to CCC and there you will find Uninstall-L3
run it .. it will uninstall the driver from the registery as well
If u dont have the cd you might also use find the UTIL folder in you temp folder
Go to RUN and type %TEMP% and look for the UTIL folder .. the rest is the same
Now restart the computer
Download the latest full feature software and driver from HP.com.
Downloaded softwares are more reliable compared to discs also it is updated.
You can download the software from hp.com
If it does'nt work create a new administrator user account and download the driver and install it
Hope it works for you
All The Best!!!!
Posted on May 10, 2010
  • JULIUS SUNUWAR
    JULIUS SUNUWAR May 10, 2010
    In the TEMP folder you will find the UTIL folder under the folder name starting with 7z.... You can look on all the folder that starts with 7Z
    All The Best!!!!
Rosetta stone windows 7 fatal error 1141
To fix this problem i would suggest to uninstall this software and scan PC with PC optimizer like Reginout to fix windows internal errors and corrupt registry entries.
Re-install the Rosetta stone. Disable Anti-Virus and Firewall before installing Rosetta Stone.
Jan 16, 2013 | Computers & Internet
I try to scan a document and i get the message that "X" folder does not exist, would you like to create one. although this folder does exist is select "ok" another window opens saying...
Uninstall the Printer Software from Add or remove Programmes in the Control Panel.
Get the Drivers and Softwares Installed again.
There is an Issue with the Installation of the Scanner Drivers and Software.
Good Luck!!!!
Sep 24, 2011 | Office Equipment & Supplies
I already downloaded driver for my HP Deskjet F4185 I can print but can not scan
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
The reloading must check the errrors of the software and correct the issues, if not the scan section can have errors.
Jun 13, 2011 | Computers & Internet
Fatal error unhandled c00000fdh exception at 30119435h in autocad 2011
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Fatal-Error-Unhandled-Access-Violation-Reading-0x0000-Exception-at-bcbdad73h.html
Fatal Error while opening AutoCAD Dec 05 2014
Applies to AutoCAD 2009, AutoCAD 2010, AutoCAD 2011, AutoCAD 2012, AutoCAD 2013, AutoCAD 2014, AutoCAD 2015, AutoCAD Architecture 2009, AutoCAD Architecture 2010, AutoCAD Architecture 2011, AutoCAD Architecture 2012, AutoCAD Architecture 2013, AutoCAD Architecture 2014, AutoCAD Architecture 2015, AutoCAD Civil 3D 2009, ...
See More
Issue:
While in the process of starting AutoCAD , a Fatal Error occurs.
Causes:
Fatal errors usually indicate program corruption or a corruption somewhere within the operating system.
Solution:
There are several ways to address the problem: Note: A fatal error can be caused by DisplayLink Core software. If you have this installed on your system, try uninstalling it and then see if this resolves the issue. Additionally, some antivirus or desktop locking programs can cause errors in AutoCAD as they lock the system environment from working. Your antivirus may even need to be uninstalled.
Sep 16, 2010 | Autodesk AutoCAD 2010
Fatal error when installing hp scanjet g3110 software
The error may occur if there is a new version of Solution Center or a component of the scanning software has already been installed due to a software update or due to incomplete uninstallation.
b9ebeb2.jpg Solution To resolve the issue, complete the following steps:
  1. Run the uninstaller from the CD.
  2. Run all four levels of uninstallation from the CD. Browse the CD to the Utils folder and then the CCC folder, where you could find:
    • uninstall_L1.Bat
    • uninstall_L2.bat
    • Uninstall_L3.bat
    • Uninstall_L4.bat
    Run these files, and follow the instructions. Most of the fatal errors that occur due to the incomplete uninstallation should get resolved after the four levels of uninstallation are done. However, if there is a new version of the software that has been installed, then continue with the next step.
  3. Download Microsoft Windows CleanUp Utility from Microsoft Knowledge Base Article 290301, Description of the Windows Installer CleanUp Utility . Click here to go to Microsoft Knowledge Base Article 290301 (http://support.microsoft.com/kb/290301) .
  4. Open Windows CleanUp Utility, scroll down the list, check for the HP Scanjet related entries and remove them. Entries that need to be removed:
    • Bufferchm
    • DocProc
    • Esupport Q-folder
    • Scan
    • Solution center
    • WebReg
    NOTE: Some entries are common for both earlier and newer versions of Solution Center and bear common names. Deleting these entries may result in the other versions of Solution Center not working.It is advisable to install the older version of the software first, and then the newer version. 2d75964.jpg
Restart the computer and try reinstalling the software. This should resolve the issue
Oct 22, 2009 | HP ScanJet 4100C Flatbed Scanner
I get fatal errors MSI.aio.scan when installing HP
try uninstalling ie8 if you have it installed hp software does not like ie8
Jun 28, 2009 | HP PSC 1315 All-In-One InkJet Printer
When attempting to install HP Officejet 5600 All in One printer, I was notified that a "Fatal Error" occurred during installation process prior to connecting to USB port on computer
Sometimes when installing new software, if you get fatal errors, that could be a sign of virus activity on your computer. I would download one of the many free antivirus programs and scan my computer either that or download the Trinity Rescue Kit CD and boot from it and run (I believe) option #6 "Virus Scan non interactive" That will scan your computer for viruses while the operating system isn't running.
Nov 07, 2008 | Office Equipment & Supplies
Fatal error msi.netdevicemanager01
1)Stop the installation
2)Go to Command prompt
3)then type : subst X: C:\
4)Press enter
5)exit out of command prompt
6)Then restart the installation again it should complete
X:\ is the drive you are getting at the time of the installation as invalid drive.
Sep 25, 2008 | Office Equipment & Supplies
Fatal error msi.webreg
hmm..did you run disk clean and defrag, after uninstall?
Jun 16, 2008 | HP DeskJet F380 All-In-One Printer
Scanner component stopped communicating
well, reinstall the software and see if it will work.
Aug 13, 2007 | HP PSC 1350 All-In-One Thermal Printer
HP OfficeJet 6210 All-In-One InkJet Printer Logo
57 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
