Error E005 means the fuser cleaner roller has run out & may need a replacement. If the error is false it will disappear by following the reset procedure. To clear this error code press * 2 and 8 * in that 2&8 are pressed simultaneously. Go to the web counter and clear the counter back to Zero (0). Machine will now restart your machine & error code will disappear. If this doesn't help then try clearing both web counters in service mode, COUNTER>MISC>FIX-WEB> and COUNTER>DRBL-1>FIX-WEB> perform a Error Clear in service mode FUNCTION>CLEAR>ERR>. Hope this helps...
Daniel
You have to get into service mode and go to the counters and go to the web counter and reset it. Also, You may want to go to the Funcation mode and reset the error codes also. To lock the counters, turn the main power switch OFF then back ON.
press*28*
to enter service mode
select copier>counter>misc/fix web
then press cancel button
this will clear cleaning web count you do need to replace the web as it has run out hence the error code
good luck
E005 code refer to fixing web roller.After replacing the web be sure to reset the two web counter in service mode Copier-Counter- Misc-Fix_-Web and Copier=Counter-DRBL-1=FX Web.
E005 code means that the Fixing web needs to be replaced. Even if you were able to reset the code, the machine will start jamming with extreme frequency and deteriorate (damage) the Fixing rollers. I recomend having a qualified service tech remedy this error.
if your machine is giving E-005 that means your fixing assembly (fuser cleaning web is not detecting) is bad.
go in service mode by pressing additional fuction + 2 & 8 + again press addtional function
If you find that the E005 code won't reset after replacing the Web, and clearing both web counters in service mode, <COPIER>COUNTER>MISC>FIX-WEB> and <COPIER>COUNTER>DRBL-1>FIX-WEB> perform a Error Clear in service mode <COPIER>FUNCTION>CLEAR>ERR>.
