Question about Dryers
Fitting tumble dryer drive belt
I have dissmantled my tumble dryer and bought the correct drive belt but when i fit it around the wheels and drum it is about an inch too loose how/where do i take up the tension i have a Zanussi TDS382W and the drive belt part number i have bought is 1975H7
Looking from rear of dryer,one spring on motor is for tension,therefore put belt around drum(groove to the drum surface).Then rotate the motor firmly clockwise tensioning the spring,take belt from right of drum over tension wheel then put grooves of belt on shaft of motor.Release motor to tension spring,job done !!!!!
Posted on Mar 10, 2009
    Scholar:
  • 178 Answers
If the belt you are replacing is the same length as the one you took off, it shouldn't be too hard to do. There should be a tensionor pulley attached to a spring that pulls the slack out. Typically, the belt will run on top of the tesnioner pulley, then under the motor drive pulley. Look at the dryer itself and make sure the spring didn't pop loose and fall in the bottom.
Posted on Mar 28, 2008
SOURCE:
How to fit belt on a tricity bendix tm310w tumble dryer
round the pulley then around the tensioner then around the drum.
Jun 08, 2014 | Tricity Bendix TM310W Electric Dryer
HOW TO FIT A DRUM BELT ON A TUMBLE DRYER KELVINATOR
Normally you loosen the bolts to the motor after fitting the belt around the drum. DON'T try to streach the belt to fit over the motor pullery.
Dec 19, 2011 | Dryers
Beko Tumble Dryier - Model DRVS 73 W the Belt 9PHW 1967 has broken. Is there a step by step guide on how to fit the replacement belt.
Very easy on all tumble dryers.
UNPLUG FROM POWER FIRST!
This is simply a case of:
Take the top off the machine (Usually a couple of screws holding the lid on at the back).
Or - Rempove the inspection panel from the back
Drop the new belt over the drive motor spindle
On some machines you may need to thread the belt around a tensioning wheel
Now take the belt and place it on the side main wheel that drives the drum and simply spin the drum wheel with your hand, guiding the new belt into place as you spin the wheel.
It should simply stretch a little and work its way onto the wheel as it is hand turned.
Note, once it is on, take a look at the drive motor and make sure that the belt is sitting in the same place as the old one. Most of these motors have a slotted spindle and you can see from the clean and shiny surface where on the spindle the belt used to sit. If it is a little out of place, once again just take hold of the belt and pull it toward you or push it away as you spin the main drum wheel in order to move it into the correct slot.
Jun 23, 2011 | Dryers
Simpson Maxidry Tumble dryer (Cloths dryer) How
Hi there, There is a switch at the bottom of the dryer. It has a groove for the spring to fit around. Then the spring goes through the metal tag with the holes in the pulley. The pulleys 2 prongs then fits into the slot near the motor. The belt goes through the pulley and around the motor wheel. When fitting the drum, tape the belt at three points on the drum with the machine door facing down making installation easier. Once installed remove the tape. The dryer now works like a dream. See the attached photo. Good Luck!8e72e75.jpg
Jun 21, 2010 | Dryers
I changed the belt on my Creda tumble dryer. Now its making noise
You may have to change the Guide wheel that the drum needs to rotate on
Sep 06, 2017 | Dryers
How do i fit new belt to my indesit tumble dryer
its easy, firstly wrap the belt round the motor spindle, feed the belt around the drum drive as much as you can, then turn the drum by hand and it ease the belt on as you turn it, be careful not to pinch your finger.
Mar 25, 2010 | Dryers
How to change a belt on hotpoint tdl54 tumble dryer
The belt goes around the pulley of the motor after fitting it around the drum first.
Mar 23, 2010 | Hotpoint Dryers
How to fit new drive belt to white knight tumble dryer
YOU HAVE TO REMOVE BACK AND EASE REARWARD - THEN SLIP DRUM BELT IN FRONT OF DRUM THEN REASSEMBLE - NOT EASY TO EXPLAIN
Apr 05, 2009 | Dryers
I need to fit a new belt to a Creda Tumble Dryer
There should be some kind of tensioner around the motor or one of the pully's. The other problem could be that the belt you bought is the wrong one for your model. If you still have the old belt, measure the new belt against the old one and the new belt should be slightly smaller. I hope this info helps.
Nov 29, 2008 | Dryers
Dryers Logo
1,556 people viewed this question
Top Dryers Experts
Marvin
Marvin
paul
paul
