Question about Samsung HLN5065W 50" Rear Projection HDTV-Ready Television
AT&T Uverse HDTV
I recently had AT&T Uverse HD service added in my home. I thought my HL-N5065W was HDTV ready. However when connecting the AT&T box to component 2, it shows that no signal is being received. When I plug it into video, it works. What gives?
    New Friend:
  • 3 Answers
On some of the HD ready projection TVs they have a separate input for component HD, also some have a separate component input for HD
Posted on Jan 10, 2010
SOURCE:
Why would our Samsung MN HL 850 86W make a crackling noise after it warms up? It sounds like the cracking of a fire. What could it be?
Your lamp ballast is going bad. Might last a few more months, but eventually it will have to be replaced. Bulb will also likely have to be replaced at same time, but try the ballast first.
May 04, 2014 | Samsung HL-S5086W 50" HDTV
How to hook at&t uverse cable box
If set works with games etc via rear audio/video jacks do the same with cable----get a cable box with audio/video etc outputs on it and go from them to ones on the rear of set----no coax connection needed and a better picture.
May 19, 2012 | Toshiba 57h83 57-inch Hdtv-ready...
57H83 57 in. Rear Projection HDTV Television: I have a Toshiba 57H83 and recently purchased the ...
I would suggest to leave your directtv hd/dvr box connected the way It is.
The HD Colorstream 1input on your TV should work just fine.
This TV does not have an HDMI input but you can buy an adapter and connect to DVI/HDCP IN and that might be able to get 1080i video resolution on your TV.
Jun 30, 2017 | Toshiba 57H83 57" Rear Projection HDTV
My Samsung HL-P5063W set turns off on its own randomly. Set is 5 years old. This started after I went on the AT&T Uverse service, but that may be coincidental. The Uverse box and service stay on, but...
First thing change the lamp. There are several other things but this is most common. Be sure tab on lamp door presses door switch in downward position when you change the lamp. MCM Electronics you can get a philips bulb for $99.00.
Nov 29, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
HDMI failure Samsung HL-R5087W 50 in HDTV
After reviewing the service manual for this set, the problem is is in the DIGITAL BOARD. To get the right Digital Board you will need the Version number of the TV.
Good luck
N Sabre
Nov 09, 2009 | Samsung HL-R5087W 50" HDTV-Ready...
Can not get hd on LTN1785W tried component 1 &2 just blu scrn
do you subscribe to the HD, if you do you will have to activate it through the menu button, go into the aspect ratio and set it on 720p or 1080i press OK the it will run a test...press the "up" arrow and then press OK.
Now on Uverse you can only get HD through the HDMI or the Component,red green blue, outputs.
May 16, 2009 | Samsung LTN1785W 17 in. HDTV-Ready LCD...
Uverse standard remote control stops working at night
The remote stops working the Uverse box or the TV or both?
Try putting the Uverse box behind the plane of the TV screen so the I.R. that the TV emits doesn't get to the front of the Uverse box.
Mar 20, 2009 | Samsung HL-S5687W 56" HDTV
Connecting TV to cable service for HDTV
normally you need a converter box for hd because normal stations are broadcasted in hd.....its not common enough for them to do it...and you probably have to buy a package with your cable company for the hd channels. another thing...is your tv hd ready?
Sep 30, 2008 | Mitsubishi WS-48313 48" Rear Projection...
HDTV-AT&T UVERSE
First of all, is your blue "HD" light lit up on the front of your Uverse box?
If yes, then you're in HD
If No, you need to check your connections from Box to TV
1.Those Red-Blue-Green cables are for video only, they don't carry sound and shouldn't be connected to audio outs. Audio needs a seperate cable. Make sure your Red isn't on the audio out which is also red. Make sure your blue and green aren't switched with each other either. Check that at both ends.
2. Try an HDMI cable. It will carry audio and video together and it's one cord instead of 5.
3. What brand/model of TV is it? Is it an older projection TV? The HD tuner might be shot. The individual color tubes commonly fail after a few years.
4. Are you selecting 720p or 1080i from your TV's menu or from the Uverse menu? You'll need to set it through the Uverse box, not the TV.
5.Follow -Menu -Settings -Aspect Ratio to change to 720 or 1080. This should start an autotest which will scramble your picture for about 5 seconds, then bring you back to a menu asking you to keep settings or revert back settings. If you never see that question pop up, then your TV isn't supporting the HD, and you settings will be rolled back automatically. If the question does pop up and you can read it, select "keep settings" and press OK. Your blue HD light should come on the front of the box now.
Mar 01, 2008 | Philips 55PW9363 55" Rear Projection...
Colors out of Whack on HD input 4 only
May need higher quality component HD cables? Tried switching Blue on Red? Just some thoughts.
May 02, 2007 | Philips 60PP9202 60" Rear Projection...
Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
140 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
