Question about Samsung LN-R409D 40 in. LCD Television
Snow lines on Samsung LN-R409D LCD TV
Hi - I'm having a problem with my Samsung LN-R409D LCD TV, and I'd appreciate insights on which part needs replacement.
You can see an image of the problem at:
http://www.flickr.com/photos/59144073@N00/4595423617/
Basically, there are horizontal snow lines going across the display, regardless of the video source. In the image, you'll see that the "Component 1" overlay in the upper left corner is not distorted, which suggests to me that the LCD panel itself is operational (ie, a faulty display shouldn't distinguish between data originating from a video signal vs an on-screen graphic). The snow lines occur consistently in the same position.
Any assistance would be much appreciated! Thanks!
  • 192 Answers
SOURCE: LN-T4665F 46 in. LCD- Black Line across screen
The set is under a year old and is under warranty. The LVDS cable inside these sets have a history of coming loose. The problem could be the panel. Either way, the set is the problem and needs to be looked at. This set is worked on in the home and does not need to be taken to a shop, so, you can still use it. Contact Samsung at: 1-800-SAMSUNG Hope this helps.
Posted on Jun 03, 2007
Coldcut
  • 1554 Answers
SOURCE: Static lines one screen
as the top is ok and the bottom has this issue.
It looks like the circuit board has a bad connection to your screen.
it is not repairable by you and not an adjustment.
you need to have it repaired.
don't you miss the old wack on the side fix?
Posted on Feb 17, 2008
SOURCE: Optimal settings
Samsung LN-408DX/XAA
How do I get the PIP to work?
Posted on Apr 27, 2008
  • 257 Answers
SOURCE: Screen shows several horizontal and vertical lines.
Press the menu on the TV and let me know if the menu is effected. If the Menu if effected , you can try unplugging the power cord for a minute and replugging it back. If the issue still persists , a physical diagnostic is necessary to determine the exact defective part on your device. It could be a problem of main board or even worse, the panel.
Posted on Aug 14, 2009
  • 257 Answers
SOURCE: Samsung LN-S3241D HDTV LCD snowy display
The main board may cause this problem. If it wass happened when you play DVD, so the main board needs replacing.
Posted on Aug 18, 2009
I have a 42' coby flat screen tv and the sound just went out all of a sudden.
Hi there Check , as I am sure you have, if the sound is on mute. Try other channels and check all cables and connections. Good luck
Aug 24, 2012 | Samsung LN-R409D 40 in. LCD Television
Tv got a black patch on the screen.. how will it go ?
If a tiny area it may be the LCD display panel itself--fatal.
If one half or screen left-right or up down it could be an inverter issue.
Apr 17, 2012 | Samsung LN-R409D 40 in. LCD Television
Blank screen Samsung LN-R409D, audio when turning on and off and blue light at power button in on position???
Hi there
Im afraid this sounds like a fault with the TV. Try turning it off at the wall for 3 minutes, and then with nothing plugged into the TV, turn it back on. If the problem persists contact the manufacturer.
Hope this helps
TV_Doctor
Jan 03, 2011 | Samsung LN-R409D 40 in. LCD Television
My tv will not turn on, it just clicks but doesnt
You will need to have the power supply board replaced. This is a common problem and Samsung has re-designed the new boards so this will not happen again. You can call 1-800-samsung for the nearest authorizd service center.
Feb 26, 2010 | Samsung LN-R409D 40 in. LCD Television
LCD TV Set up
no tips, but if you have tip on how to remove base that would help us out..we hung on wall and cannot remove the 4 screws to remove base, only 2 would come out.
Jan 01, 2008 | Samsung LN-R409D 40 in. LCD Television
Optimal settings
Nov 20, 2007 | Samsung LN-R409D 40 in. LCD Television
Samsung lcd tv le32r8
perchè quando collego il computer al televisore l' audio è assente?
Oct 15, 2007 | Samsung LN-R409D 40 in. LCD Television
Samsung LN-R409D 40 in. LCD Television Logo
107 people viewed this question
Jerry Greenberg
Jerry Greenberg
