Question about Air Tools & Compressors
We have an I/R SSR-EP25SE compressor and recently the belts rolled over and the unit blew cooling fluid out of the air filter so we replaced the filter and today I replaced a check valve because the spring was broken in the old one. Then we set the fluid level to the top 1/2 of the sight window. Now I turn it on and can't get it to pressurize the storage tank. It's as though there isn't enough volume coming out of the unit. When I isolate the compressor from the tank it will build to 108 psi and unload. I'm not very knowledgable on the subject and need some guidence from someone who is.
  • 12,061 Answers
Your cutout valve must be faulty, the Valve that allows air INTO the tank, isn't working, or is faulty, and isn't allowing full pressure to be delivered.
http://fileserver.urimarketing.com/LU/CourseCatalog/CompressorProblems.pdf
http://www.tpub.com/content/construction/14050/css/14050_208.htm
http://www.tpub.com/content/construction/14050/css/14050_207.htm
A compressor is a pump. When that pump is being driven by the electric motor, it pulls in free air from the atmosphere and drives it into the tank.
Different styles of air compressors do this in different ways, yet they pretty much all do the same thing.When your compressor is running and the pressure in the tank isn't rising, this is pretty aggravating. What the heck is wrong when the compressor pressure will not build?
On this page immediately below is a form that you can use to ask a question about what to do when your compressor will not build pressure?
To see existing comments and questions already posted about this subject please scroll to the bottom of this page (below the form).
I've just added a page that summarizes many of the answers about why a compressor won't build pressure. That page is right here.
Here is another new page that addresses the reed valve issue, to help you better understand how compressor reed valves contribute to why compressors don't build air pressure.
If these new pages or the comments at the bottom of this page don't provide the answer for you, just fill in the form and we'll see if we can help.
And, if you've got a suggestion about solving the "compressor will not build pressure" problem, also please use the form to let us all know about it, and perhaps help someone else.
Read more: http://www.about-air-compressors.com/compressor-will-not-build-pressure.html#ixzz0nanQ5E4v
Posted on May 11, 2010
  • steve853 May 11, 2010
    Thanks for the info.
    The valve that supplies the tank is manual and is working properly. What would be the next logical thing to look at?
HAVE A SSR 15-50HP SCREW COMPRESSOR WITH GC-14 INTELLISYS CONTROL KIT AND IT SHOWS "REV ROT MOTOR" WHAT THIS MESSAGE MEANS?
This is letting you know the motor rotation is incorrect. If this is a new unit or has just been installed or other rewiring work done in your plant etc. you need to get your electrician to roll 2 of the 3 incoming power leads. If this compressor has been in service and operating you have a vacuum switch or transducer possibly bad. you also need to check the transducer line or vacuum switch line ( both are normally 1/4 inch plastic tubing) for tightness and leaks. For example the line has rubbed a hole in it. When you try to start the unit the transducer does not see the required vacuum. The controller interrupts this low or no vacuum as the rotation is incorrect and thus gives a check motor rotation alarm and shuts down.
Feb 22, 2011 | Ingersoll Rand Stationary Air Cooled...
HAVE A SSR-XH60 SCREW COMPRESSOR WITH 39180419 INTELLISYS CONTROL KIT AND IT SHOWS "STARTER FAULT" WHAT THIS MESSAGE MEANS?
The motor starter overload auxiliary contact is wired into the intellisys control unit. If the motor would overload, then the thermal overloads in the motor starter will trip. When this occurs you will get that message. The overloads are in the electric panel on the left side. You will have to remove the screws to gain access. Be sure to have disconnect off when removing cover. There is a reset button on the motor starter you can press to reset. Now the question is why did it trip? There are a few common possibilities. On is dirt in the coil not allowing enough air to pass over the motor. Slipping belt generating too much heat. Old or low oil causing high temperatures. Pressure setting set higher than unit is designed. You can set pressure on the intellisys. Another reason is short cycling. If you have this set for start stop operation by pressure, the minimum run time should be at least 10 min, and I believe mfg recommends even longer. If it starts and stops too frequently, the motor will overheat.I hope this helps. (I maintain a very similar unit where I work) These units are usually very trouble free units if you keep the oil, oil filter, air filter, and separator changed as recommended.
Oct 19, 2010 | Ingersoll Rand Stationary Air Cooled...
AC IS NOT COOLING. FREON HAS BEEN CHECKED AND IS FINE.
Impossible to tell w/o the belt being installed. If the compressor is dead, no amount of freon will work. My guess is that they probably removed the belt due to compressor issues but if the compressor does kick on and there's no cool air, it may need freon. Freon can't be added unless the compressor is on and running.
Aug 14, 2009 | 1998 Mitsubishi Montero Sport
Where can i find motor fan part # 2mtr and 3mtr ingersoll rand compressor ssr-ep25
I would try Grainger (www.grainger.com)
They sell IR compressors and always have a large assortment of parts
Jul 16, 2009 | Ingersoll Rand Type 30 Fully Packaged Ir...
There is a squeal sound (high pitch) coming out of
The seal on the AC compressor has probably failed and allowed all the refrigerant and lubricant to be lost. This allows the bearing to run dry and now it is failing and making noise.
1. You could have the AC repaired, the compressor repaired or replaced and the system refilled.
2. You could have a mechanic disconnect the system and possibly remove the compressor (only if this model does not use a belt that relies on the compressor being in place).
3. It is probably way too late to try to refill the AC system with R134a refrigerant as it would just run out past the failed seals.
If anyone has an AC unit that just recently stopped making cold air they should attempt to recharge the unit (if it uses R134a - check your manual or underhood stickers). I just did and saved my compressor and AC unit from further damage.
Jun 17, 2009 | 1996 Jeep Grand Cherokee
Air Tools & Compressors Logo
135 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
