Question about Hannspree HC-194D 19" LCD Monitor
My lcd is a Hanns-G 194DP and i have this Problem: The LED is yellow and on the Display is standing: Self Diagnostics No Signal'' can i Help me ?
  • 80 Answers
Open it up and look at the capacitors. The round "tin can" looking components. If the tops appear bulged, then replacing them may help. Check out the YouTube video... and web site...
http://www.youtube.com/watch?v=9Q6_TgNJvQw
Good Luck!
Posted on May 15, 2010
Screen colour adjust
Go to link and download the manual.
http://www.hannsg.com/US/EN/Products/LED%20Monitors/Common.aspx?productId=125
Remember that the computer display card can override all manual settings.
Jul 18, 2014 | Hannspree HANNS.G HX191D 19" LCD Monitor
Yellow blinking light . what does it mean
A blinking yellow for this model indicates the TV is too hot, unplug & allow 30-45 min to cool before re-plugging .
OR: lamp not installed or lamp door not closed. there is a lamp door switch that may not be closing, simulating door not closed
LED Indications
The front panel Status LED provides an indication of
the set's operation and the possible cause of a malfunction.
If an abnormal condition is indicated, perform the
Self Diagnostics procedure.
Self Diagnostics
To activate, press the front panel <ACTIVITY> &<CH
??> buttons at the same time and hold for 5 seconds.
The STATUS LED will then flash denoting a two digit
code.
• The number of flashes indicates the value of the
MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2
second.
• The LED then flashes indicating the value of the
(ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: If the Error Code is "23", the LED
will flash two times, pause, and then flash three
times.
Table 2-2: LED Indications
Error Codes, descriiptions and the most likely cause of
the error are listed in Table 2-3.
Note: The TV must be in "Shut Down." The LED
will probably be indicating an abnormal
condition. If the TV is switched Off, AC is
removed, or a System Reset is performed, the
code automatically resets to "12" No Error.
See the Error Code Log to retrieve a history of
errors.
Note: Use the front panel buttons, not the remote
control.
Note: If there is no response, the front panel may be
locked by a V-Chip setting. To unlock, press
and hold <ACTIVITY> on the front panel for
8 seconds.
LED Indication Condition
Off Off (standby)
Green Power On
Slow Blink Green Power Off with Timer Set
Fast Blink Green (80 seconds) > Off Power Off (Cooling fan still working, 80 sec)
Red Lamp Failure
Yellow TV Too Hot
Slow Blink Red TV May Require Service
Slow Blink Yellow Lamp Door Open or No Lamp Installed
NORMAL INDICATIONS
ABNORMAL INDICATIONS (For details perform Self Diagnostics Procedure.)
Jul 07, 2014 | Mitsubishi WD 65837 65 in. HDTV
Need screw size for stand
Take the Stand to the hardware store and have them try a few sizes that fit. You need Machine Screws and who knows what length?
Jan 05, 2014 | Hanns.G HL269DPB Black 26" 5ms Widescreen...
I have a thin yellow line running from top to bottom about 10 inches from the left side, what's wrong?
This can be due to faulty LCD driver IC which creates a noise bar and is shown. Check the cords to the display and also the ground connection to the display. If this is good then the IC can be faulty.
Dec 15, 2011 | Hanns.G Corporation JW-199DPB 19" LCD...
Hanns-g 19" HX191d monitor blank screen. Power led is intermittent flashing green. Does not show 'no signal' when powered up alone. Has this monitor died or is there a way to fix it?
This type of issues is caused by parts called capacitors that have failed and are keeping the power supply from starting up correctly. You can rebuild the power supply board by replacing the bad capacitors and this will bring the monitor back to full working order. Here is a link to information showing what parts need to be replaced with pictures and parts list.
http://www.ccl-la.com/catalog/product_info.php?cPath=21_31&products_id=194
I hope this helps you.
BuddyMc
Oct 14, 2009 | Hannspree HANNS.G HX191D 19" LCD Monitor
Hanns g monitor display got yellow tinge
reinstall completely video card, also from device manager. REinstall and reset the video resolution. you have it set too high for your monitor.
Mar 02, 2009 | Hannspree HW191D LCD Monitor
Hannspree HC-194D 19" LCD Monitor Logo
205 people viewed this question
Top Hannspree Computers & Internet Experts
tomar33
 Chuck N
Chuck N
Are you a Hannspree Computer and Internet Expert? Answer questions, earn points and help others
