Question about Samsung SyncMaster 205BW LCD Monitor
Samsung Syncmaster 205 BW,screen went black,power light is on (steady),cant turn it off.Turn off monitor with power switch in the rear. Computer works with different monitor.
  • 11,361 Answers
My Samsung SyncMaster 205 bw monitor was working a few days ago. And the suddenly some black and white slanted stripes appeared on my monitor. I shut off my PC and rebooted it and nothing came up. My blue...
Sounds like your monitor has croaked. Borrow a monitor from a neighbor, friend or family member just to see if it works. If it works, your monitor is bad. If the borrowed monitor has the same issues then your Video Card in the computer is bad and needs to be replaced.
May 01, 2012 | Samsung Computers & Internet
My monitor will no longer start up it just has a black screen
I estimate around $75~100 depend on hourly rate or less, more likely to have bad caps in the power supply, if the shop is real good, they should be able to fix it in less than an hour, see example of failed SAMSUNG monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 01, 2010 | Computers & Internet
Syncmaster 216 bw samsung goes black. when i push
your power supply needs to be repaired . you have bad capacitors. very comon problem
Dec 31, 2009 | Computers & Internet
Flashing screen when i first turn on my SamsungSyncMaster 2232 bw
I had a similar problem with my LCD computer screen. I took it apart and noticed a capacitor that was raised up on the flat end and appeared to be leaking a substance. Replaced it with a similar capacitor and works fine, for three years now.
Jul 05, 2017 | Samsung SyncMaster 2233BW 22" LCD Monitor
Do I need a disc to install our samsung syncmaster 205 BW monitor? If so, where do I get it?
Is this a new monitor, and there is no disc with it?
If you are running XP, Vista, Windows 7 etc. than the monitor is plug and play. Just turn the computer off, plug in the monitor, turn on the computer, and you should be good to go.
Aug 05, 2009 | Samsung SyncMaster 205BW LCD Monitor
Monitor doesn´t work
1 MAKE SURE THE DATA CABLE IS CONNECTED TO THE CPU.
2 MAKE SURE TO TURN THE MONITOR ON.
Aug 05, 2009 | Samsung SYNCMASTER 943B 19" LCD Monitor
My samsung syncmaster 941 bw just went white screen
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Aug 05, 2009 | Computers & Internet
Was searching the web and screen went black,,power light is on but no screen,,no menu screen,,cant hit auto seek,,nothing,,to me seems like the tube is blew out,,any suggestions?repair price?
whats the light on the towere if the light is stedy green then the tower is ok so unplug the data cable from tower and turn on the monitor then if it run the self test then monitor is ok if its not yiu need to repair or replace the screen
Jun 26, 2009 | Samsung SyncMaster 213T 21.3" LCD Monitor
Samsung 940 BW Monitor Not working (Black screen)
Hi...there,
That's indicated your backlight inverter are busted. Need to replaced a new one or repaired it. To repaired look for a bad capacitors with a bulged on top of each caps. Not sure, just replaced all the caps... Have a nice weekend!
Oct 09, 2008 | Samsung Syncmaster 940BW LCD Monitor
Samsung SyncMaster 205BW LCD Monitor Logo
1,147 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
