Bose 901 equalizer
How to I connect a Bose 901 equalizer to a Yamaha RX-461 receiver. Can I find the Channel A PA inputs, and insert it there? Does anyone know where the PA input is?
Mark
  • Cembalo Mar 29, 2008
    Hi Graeme,
    Unfortunately the Yamaha RX-V461 doesn't have a tape "monitor" loop or pre-out-amp-in jacks - only a constant volume line-level output on the md/cd-r output and the dvr output to record externally. (My 35 yr old Technics had both tape 1 and tape 2 "monitor" switches but died.) I would try to trace back the PA power transistors for L & R for speakers "A" and find their line-in point with an audio probe, cut the PC board runs if necessary, and solder pre-out and amp-in RCA lines running out the case to connect the 901 equalizer. What I don't know is how many stages the PA consists of or if the 5 channels of PA's are a separate pc assembly. (I haven't taken it apart yet.)
    I assume Yamaha uses this PA circuitry on many models and possibly another 5.1 schematic might be of some help. The RX-V461 schematic I can't find on the internet and a parts request to Yamaha has not been answered yet.
    Many thanks,
    Mark
  • alleycat1253 Jul 17, 2008
    HI, ..I RECENTLY BOUGHT A PAIR OF BOSE 901 SERIES 4 AND IT CAME WITH THE BOSE 550 AM/FM RECIEVER WITH BUILT IN SERIES 4 EQUALIZER...IS THERE A WAY TO HOOK UP AND USE JUST THE BIULT IN (EQ) AND HOOK IT UP TO A MORE POWERFUL RECIVER..ON BACK OF RECIEVER I ONLY HAVE 3 CONNECTION CHOICES AND THEY ARE...(AUX)..(PHONO) AND (TAPE " IN,OUT" "R +L "........CAN YOU HELP ME?.........THANKS ALLEN
  • 1,512 Answers
Hi Mark, had a look for a manual on your Yamaha, but not got to one as yet. Does it have any RCA connections on the back marked as preout prein? best place to put the 901 EQ is in line with L and R front channels at this preout prein point.
Some amps DO NOT HAVE IT. If our does not, then you could connect it in the tape loop, tape out(rec) to input on the EQ. and the output of the EQ connected to tape in(play), but connected like this, the EQ would affect the tone across all channels(unless you are just running a stereo rig, then this way works great!!) Try this and you may just have solved you problem anyway.
regards
Graeme
Posted on Mar 29, 2008
  • Graeme Ross
    Graeme Ross Mar 29, 2008
    Hi Mark, it is usual for there to be some sort of tape monitoring involved in a tape loop. Not a deliberate "monitor" as such, but you should still get audio to loop when you have selected one of the "tape" style functions. Do you have a VCR in/out for instance. That could be used as a loop, the actual source selection then made by changing the REC out selector(leaving the unit main source selection to VCR)
    went looking for a manual again, but came up nada. I know it sounds silly, but can you recheck the model for me. I have found plenty of listings under your model, which would tend to point to it being a released model, but odd that there seems to be no docs on it, even at Yamaha. Will keep looking
    regards
    Graeme
How to connect my bose 901 to rx-v2200
Bose Equalizer Out > to RX 2200 Tape/DAT In
Bose Equalizer In > to RX 2200 Tape/DAT Rec
more instructions on page 9 Bose 901
Sep 12, 2012 | Bose 901 VI Main / Stereo Speaker
How to connect bose 901 equalizer to yamaha rx-a1000
Short answer from personal experience.
There is no way around this part. Get a separate power amp for the 901's if you want to use them in a multichannel way or alongside non-901 speakers.
Connect the Active EQ between the pre-outs and the amp input.
http://products.bose.com/pdf/customer_service/owners/og_901.pdf
Run speaker assignment, levels, etc and have fun.
Helpful Hint: If you don't have sufficient between-speaker room for proper reflection off the front wall you CAN turn the 901's around and you won't believe the amount of air these things push! I have actually felt it ten feet away after explosions or crashing ocean wave sounds. Now THAT is multi-media.
Sep 05, 2011 | Yamaha RXA1000 Receiver
My problem is conect bose 901v to reciver yahama rx-v657
If you cruise around fixya solutions you will find a number of MY postings for many different receivers.
The difficulty you face is that the RX-V657 lacks the necessary Pre-Outs to feed the Bose 901 Active Equalizer which would feed the necessary dedicated amplifier you will need to route Front Channel programming to the 901's and ONLY the 901's without affecting anything else that flows through the RX.
I have 901's in my multichannel rig alongside 301's and a subwoofer. I know what I'm talking about.
Aug 25, 2011 | Bose 901 VI Main / Stereo Speaker
Amp out and amp in for bose eq.hook up
  • 1
    Examine your receiver to be sure it has a tape monitor loop. Receivers with a tape monitor loop will have a button or switch on the front for "Tape Monitor," and have two sets of RCA connections on the back, one labelled "Tape In," and the other "Tape Out."
  • 2
    Take the two cables that are provided with the 901 speakers and insert one end of the first cable into the "Amplifier Input" jacks of the equalizer. Connect the red connector to the R input and the other connector to the L input. Connect the other end of this cable into the "Tape Out" connections on the receiver. Again, hook red to R and the other to L.
  • 3
    Connect the second cable between the "Amplifier Output" jacks of the 901 receiver and the "Tape In" connections on the receiver. Follow the guidelines in Step 2 for R and L connections.
  • 4
    Plug the 901 equalizer into a 120-volt electrical outlet. Your 901 equalizer is now installed.
  • Read more: How to Install a Bose 901 Equalizer ' eHow.com http://www.ehow.com/how_4813156_install-bose-equalizer.html#ixzz19vfsJTQu
    Jan 03, 2011 | Bose Audio Players & Recorders
    I have a Yamaha RX-V992 receiver and I would like to install a Bose 901 active equalizer Where will I connect this to my receiver? Thanks Mark
    Basically here are the connections you have to do:
    In case you don't have tape recorder forget the "box" named tape recorder. Your RX-V992 is the box named receiver or preamplifier. You have to connect with RCA - RCA cables the tape out from the RV-X992 to Bose input, and the Bose output to tape in at RV-X992. With the setup connected like this whenever you choose from the RV-X "tape monitor" you will hear the sound equalized from Bose; if you disable the "tape monitor" switch you will hear without any equalization.
    In case of a problem or clarification, don't hesitate to post me a reply.
    If you are satisfied, rate my solution with the "thumbs".
    Thanks and regards
    Please kindly rate this solution
    Stelios
    direct FixYa link: http://www.fixya.com/users/technical114
    May 09, 2010 | Audio Players & Recorders
    Want to use Yamaha rx-797 reciever with bose 901 and bose 301. Yamaha says tape monitor kills digital input signals. Also sya digital inputs are the optical jacks, RCA inputs are analog, but 797 does not...
    I don't know why the comment from Yamaha about Tape Monitor killing digital inputs is relevant.
    According to the manal I downloaded, THIS stereo receiver doesn't have digital inputs.
    As to using 901's and 301's...
    You will need a separate Power Amp for either the 901's or the 301's. Sorry, but you can't share the amp with the Active-Equalized signal and non-901's.
    I use 901's and 301's in MY 7.1 rig with a separate amp for the 901 and NOT using a Tape Monitor, but a preamp out feed for the front channels.
    Feb 15, 2010 | Yamaha RX-797 Receiver
    I would like to know how to connect my Bose 901 to my Yamaha RX-V765 AV Receiver.
    Ahhh, the good ole Bose 901. (I like those)... And you want to connect them to the Yamaha RX-V765 AV receiver. That should be a piece of cake. I assume you only have two Bose 901 cabinets. If so, you simply need to connect one end of your speaker wires to the terminals found on the 901 cabinets, and the other end of the speaker wires need to go to the Front Left and Front Right speaker outputs of the RX-V765. The RX-V765 is a 7 channel surround receiver. Weather you run it as a 7 channel theatre or as a more classic 2 speaker configuration, you will want to run the 901 cabs from the Front L and Front R speaker outputs, unless for some reason you want to specifically use them for any of the surround channels in which case it will not harm anything if you use them for surrounds - it's just that if you're simply wanting to use them as your principal speakers, you want Front L and Front R.
    So connect them as I explained, power the receiver up, put on your favorite CD and enjoy!
    Oct 24, 2009 | Audio Players & Recorders
    Bose 901 equalizer hookup
    how do I hook up the bose 901 EQ to a yamaha DSP3090??
    Nov 08, 2008 | Bose 901 VI Main / Stereo Speaker
    How to connect bose 901 speakers to 5.1 setup?
    The solution is simple and cheaper than you think.
    The analog 5.1, 6.1, 7.1 outputs on your receiver should be active even with digital inputs that you want to hear. Your receiver turns everything it processes into analog output just before the speakers anyway so there's no loss of access to multichannel sound this way.
    What I did was to buy a separate amp for the 901's and feed the Front L&R analog audio out to the EQ which is directly in front of the amp. The Active EQ is only for the 901's which don't have woofers or tweeters so Bose flattened out its final response electronically with some serious boosting at both ends. Having it in line with any other speakers would feed them a grossly over-compensated signal.
    Your receiver will drive the rest of the speakers.
    This is the cheapest way to have your 901's and hear them, too. Since the 901's are really efficient you don't have to buy a big amp that would heat the room. I'm using a separate Carver amp with 2x100w for mine.
    Sep 09, 2008 | Bose 901 VI Main / Stereo Speaker
    1,159 people viewed this question
     Grubhead
    Grubhead
