Question about Maxtor Hard Drive
Maxtor harddrive stopped working
My maxtor external hard drive, when plugged in lights up, however the drive does not show on my pc why?
  • Anwarul Haque
    Anwarul Haque May 11, 2010
    Need info About OS and drive ..
  • 6,831 Answers
Body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; } Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 27, 2010
The Maxtor harddrive was moved and the plug got jiggled so it wasn't showing on my pc...I fixed the issue, then kept getting an error message "checking dish one touch" with 2...
Open My Computer
Note the drive-letter assigned to the Maxtor
Close My Computer
Click Start
Click Run
Type CMD
Press Enter
If the drive-letter was 'E:', type 'E:'
Press Enter
Type ATTRIB -H -R -S *
Press Enter
Open My Computer
Double-click the icon for the Maxtor
Does it still show "zero" files/folders?
Does it show a 'FOUND' folder?
What file(s) are in that folder?
Nov 02, 2010 | Maxtor OneTouch 4 500GB External USB 2.0...
I HAV A 250 GB EXTERNAL HDD.. WHICH HAS STOPPED WORKIN AFTER 2 YEARS.. LOT OF INFORMATION ON IT... WOULD REALLY APPRECIATE IT IF SM1 COULD HELP ME RECOVER IT.. CAN STILL HEAR SOME NOISE INSIDE WHEN I...
This problem is caused alot by the hardware the hard drive is plugged into. Take out your harddrive and bring it to any computer retailer, and ask them if it is the hard drive or the hardware the harddrive is plugged into. This happend to me and I had to purchase a new case for it, but before that it stopped working and the harddrive got corrupted, so i purchased a new hard drive and hardware component for it, and they tranfered all the data from my harddrive to my New hard drive.
Hope this helps ^^. Please dont forget to rate, Thanks
Mar 08, 2010 | Maxtor Hard Drive
Maxtor basics 160gb portable hard drive is showing error performi
go to my computer p[roperty then hardware -> device amnager then uninstall usb drivers from it then install aagain.
then connect your harddisk then it found.
Jun 23, 2009 | Fantom Drives Titanium II (TFD160U2) 160...
Maxtor Basics 320 GB external harddrive cant be recognized
There's a good chance the shop you bought the drive from didn't have SP3 installed. For some reason, SP3 has an issue with USB peripheral devices. Windows has created a patch to rectify the problem. Click on the link below and install the "Fixit" patch to enable your PC to recognize your HD. Best of luck.
Greg
http://support.microsoft.com/kb/925196#fixit4me
Jun 18, 2009 | Maxtor Basics Personal Storage 3200 Hard...
Maxtor 3200
Seagate troubleshooting Error Code 10, states that drive has failed. (Seagate bought out Maxtor)
Before you resign yourself to everything is lost on this harddrive, how about trying one more thing?
How about putting the harddrive inside in a new external enclosure, and see if it works? I suggest that perhaps the external enclosure it's in, is bad.
The harddrive inside is a 3.5 inch harddrive. Same width as used by a desktop computer. It is a Sata harddrive.
Here's an example of a 3.5 inch Sata, external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3901268&CatId=2780
Just pop the external enclosure open that holds it now, take it out, and install it into an external enclosure like the example above. Plug in the USB cable.
Don't know if this applies to your particular Maxtor Personal Storage 3200, but when I went to search for the type of harddrive it uses just now, I ran into thsi, and thought I would pass it along. http://www.seagate.com/www/en-us/support/downloads/personal_storage/ps3200-sw)
May 10, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor Harddrive Disconnects
get a new external drive and transfer all the files to the new drive.
Jan 14, 2009 | Maxtor OneTouch II external hard drive...
Maxtor external hard drive stopped working
How is it connected ? USB?
If you start w/o Maxtor connection is your PC starting correctly?
Is issue showing when you connect USB cable on working PC?
Jan 04, 2009 | Acer Extensa 4620 Notebook
I had my maxtor one touch 4 750 gb external hard drive installed on a dell laptop with windows xp i plugged it into a mac and installed it but couldnt get it to work so i plugged it back into my laptop and...
Hi there, I think it may be to do with the format of the harddrive - see if you used the Maxtor in a Windows XP environment it would have been formatted to suit that OS.
Is the Harddrive formatted to NTFS?
Jul 22, 2008 | Computers & Internet
Maxtor OneTouch 4 Mini 250GB External Drive Does not show up on my computer
Are you connecting Drive via a USB hub or direct into two separate USB sockets on PC?
May 05, 2008 | Maxtor OneTouch 4 Mini 160GB External USB...
Maxtor One Touch 4 500 GB External Hard Drive (Windows XP (SP2) - I have an issue with my harddrive, where when I plug it into the USB, initially the power light comes on & beeps but it is not showing...
Had same problem. I shut down computer and restarted and Maxtor was installed and had desktop icon and everything worked then. I then backed up with no problems.
Apr 14, 2008 | Computers & Internet
Maxtor Hard Drive Logo
55 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
