Question about John Deere 3010,3020 Tractor Basic Carburetor Repair
Riding mower wont run unless choke is full on and dies when choke is shut off
    Scholar:
  • 110 Answers
Probably a failed or disconnected fuel shut-off solenoid. It's located on the bottom of the float bowl. Check that there is battery voltage present when ignition is on. If so, solenoid has either failed, or jammed due to gum build-up.
Posted on May 10, 2010
My troy built riding mower won't run full throttle it only run at about half throttle
if it runs good at half throttle, it just wont throttle up it sounds like the throttle cable has slipped. you might try to adjust it to get full throttle back .but if when you turn it up to full throttle and it dies then you have a choke, carburetor, fuel line, fuel filter or fuel tank problem. hope this gives you an idea.
Mar 29, 2016 | Troy Garden
Engine wont run unless choke is almost closed and will die when you open choke up into normal position
Its a lean fuel conditoin. Probably something in the carb. Also check flow from the tank and the intake mounting screws.
Oct 25, 2012 | Husqvarna Lawn Tractor  25 HP 54in Deck...
Mower wont run unless you hold the choke up
see if the solenoid on the bottom of the carb is getting power and is working if its working then you have a plugged jet inside the carb
Aug 26, 2012 | Garden
1641 cub cadet how to check fuel shut off solenoid
it wont start at all if the solenoid is unplugged try and see if it will run with the choke about half way on if so you have trash in your carb
Apr 21, 2012 | Cub Cadet Garden
It wont run unless the choke is on. its been like this since the day i bought it
The carby or fuel system has a blockage or the fuel shut off solenoid in the carby is faulty
Apr 12, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
24 hp Briggs Stratton sears riding mower engine wont start unless you use start fluid cleaned filter have flow to engine
If the mower starts and continues to run after injecting, you may want to make sure the choke is working properly. If the choke plate is not closing all the way, it will make cold starts difficult.
Feb 12, 2011 | Craftsman YT 4000 42" Briggs Stratton 24...
This is a lawnboy mower about twenty years old and has run fine intil about a week ago. Now...after starting...It will surge up and down at full speed...then start to bog down unless throttle is placed...
drain all gas out of the tank and carb the new gas with 10% ethenal is ruining old gas engines after everything sits for a day install a plastic shut off valve in gas line. put high test gas with the seafoam then turn gas valve off after every use it will run good. then call your congressman and complain otherwise we will all be replacing any engine older than 4 years old
Sep 15, 2010 | Garden
22 horse kawasaki riding lawn mower will not run at full throttle unless the choke is engaged
That is not a good situation. Too rich of a fuel adjustment can wash the bores out on that engine and prematurely wear it out! You will likely need to have the carburetor linkage and plate adjusted so that full throttle operates without engaging the choke. (If this is a single lever that you slide from slow, idle speed to fast, then on to choke)
May 09, 2010 | Husqvarna Garden
Lawn mower stays running on jumper cables but once disconnected it shuts down when choke is engaged
if it is already running and you "engage" the choke, you will flood the engine with too much gas and it will sputter and die. the only time you engage the choke is to start the engine when it is cold. if the mower dies when you remove jumper cables, and you leave the choke alone, you need to have someone look at your charging system.
Apr 08, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Try to start mower and turns over but wont start unless you pour gas in carb then it will start and run fine. 1648s scotts mower with a kohler motor.
Does it continue to run after you start it by pouring gas into the carburetor or does it die again?
If it continues to run, it sounds like your choke is not working. Probably disconnected -- check linkage.
May 05, 2009 | Garden
John Deere 3010,3020 Tractor Basic Carburetor Repair Logo
579 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
