Question about Kenmore 22422 Top Load Washer
Turning knob is broken
Looking for replacement part
    President:
  • 1,937 Answers
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Look at the section on the console.
NOTE: If the sears site references a "manufacturer substitute" part number, it's likely a Whirlpool part that can be purchased at most appliance parts stores.
Posted on May 10, 2010
Need control knob timer dryer doesn't shut off
If you are stating that the timer knob never moves to the off position, then the timer is probably bad and needs replaced. If you can't turn the timer because the knob feels too loose then possibly the knob is just broken. Timer knobs usually just pull straight off so you can look at the back side and see if the plastic around the shaft hole is cracked.
May 11, 2015 | Whirlpool Dryers
Knob on outside frost free water faucet turns freely
remove the knob.
it might be stripped out. If not, something is broken inside. turn of the water and disassemble until you find the broken part. If it is not the knob, it might be easier to replace the assembly.
Aug 22, 2014 | Plumbing
Looking for a replacement knob
We have these in stock in black 15.00 includes shipping.
DickyO
Cleveland Business Machines
216-241-0027
Jul 15, 2010 | Royal Satellite 40 Typewriter
I have 2 Hunter ceiling fans and the wall switch has 2 knobs which you push to click on or off.......after you click on...you can turn the knob and increase or decrease the fan speed. You can click on both...
Hello .. you should be able to find a replacement for your fan control at any building supply store, a home depot type store. Look or ask for a variable speed fan control. This is slightly different from a normal liight dimmer . You might also look for a replacement knob before replacing the whole switch, or matbe getting a replacement just to replace the knob ..
Jun 18, 2010 | Hunter Ceiling Fan Control Switch
When we go to turn the dryer on it makes a buzzer sound, how so we make the dyer work?
Is it the same buzz that goes off when the load is finished? The knob may be broken, if so what you need to do is pull it off and see if the handle knob is really turning the smaller knob, if it isn't, replace the knob.
If the knob is fine then you have a problem with your controls and you need someone with electrical experience to look at it.
Mar 13, 2010 | Kenmore 400 6943 Dryer
Loud buzz when dryer turned on drum doesn't turn
Is it the same buzz that goes off when the load is finished? The knob may be broken, if so what you need to do is pull it off and see if the handle knob is really turning the smaller knob, if not, replace the knob.
Mar 12, 2010 | Dryers
Broiler turns on all by itself. what can I do?
Hi, maybe your knob is broken, and it look as if it's off, remove knob and manually turn off , or you could have a faulty thermostat, or faulty circuit board, if knob is broken, you are smart, you can buy one and replace, if faulty thermostat or circuit board, you will need mechanic to check. good luck.
Aug 05, 2009 | Amana AER5715QAS Electric Kitchen Range
Thermostat
I have seen some thermostats that have a ceramic stem attached to the inside end of the control shaft. The ceramic stem is non-conductive and heat-resistant. If this stem is broken or missing, then turning the knob will have little or no effect.
The solution is to replace the thermostat.
Feb 21, 2008 | Honeywell HZ2110 Utility Heater
Kenmore 22422 Top Load Washer Logo
97 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
