Question about Namco SRS Street Racing Syndicate for Windows
Launch srs on windows 7 (resolution)
When i launch srs on windows 7 the resolution isn't correct... why this problem?
My pc is hcl monitor working on windows 7 When I start my Pc the windows comes directly shows that Attention Not Support Out Of Range I.know pressing F8 Key but Nothing is happening help
Sounds like you set the refresh frequency/resolution of your monitor to a value not supported by the monitor. You need to restart in safe mode and reset the resolution.
Keep pressing F8 at boot until the menu appears. Try restoring to a previous point.
Or try
- Boot in Safe Mode with networking and Uninstall your current GPU Drivers.
- Download the current Drivers and install
- Restart the PC in the Low resolution Mode (F8 Safe Mode launch menu)
- Use your Graphics Card Control Panel and Force change your settings back to the original working ones.
Mar 21, 2016 | Computers & Internet
Wireless does not function on my toshiba laptop, L300 what do I do?
First of all, make sure your wireless device is powered on.
Then if problem continues, go to Control Pane->Device Manager and make sure your wireless device is installed correctly. the wireless device mustn't have any notification icon(yellow, red). For example in this image wireless device is installed correctly
If your device has a yellow icon that means your device isn't installed correctly. You need to reinstall wireless driver. If you have drivers CD install drivers from it. If you don't have CD, You can download driver from the following link:
If your OS is windows 7 click here If your OS is windows xp click here If your OS is windows vista windows 7 driver will work. So download windows 7 driver.
After you download unzip package and launch installer. Follow installation instructions, restart your pc and you are done.
Thank you for choosing FixYa.
Jun 02, 2011 | Toshiba Satellite Pro L300 Notebook
Recently reinstalled windows on my computer and I can not adjust the resolution for my monitor. Its only giving me 640X480 screen resolution. Did I not install somethimg correctly?
i am guessing that you installed windows 7. you didnt say. it sounds like the proper driver is missing for your monitor. you will have to first try to do all the updates from microsoft. after that then go to the manufacturer of the computer and look for video drivers that are compatible with windows 7. if nothing there then go to the site for the maker of your monitor and look for the drivers there.
not knowing the brand of computer or which windows product you installed, makes it hard to give you more info. but i think this will get you started. let us know how this goes.
May 31, 2011 | Microsoft Windows XP Home Edition
Hello i need driver printer panasonic kx-flb802 for win 7 pelease send me or help me tank
What region are you in? Panasonic has drivers for the KX-FLB80x series for Windows 7 here: http://panasonic.net/pcc/support/fax/world.htm . Just click on your region and then scroll down to the correct series. Use the drop-down menu to select your model. At the next page, scroll down to the Download link.
Microsoft has drivers that will run the KS-FLB801 in the Windows 7 OS. The entire unit should work but you will not be able to launch a scan from the all-in-one. (You could launch Windows Fax and Scan to launch a scan.)
Apr 17, 2011 | Panasonic Office Equipment & Supplies
I cant get correct resolution with windows 7 no apparent drivers of FP 222w under windows 7 (22 inch monitor)
You normally don't need any drivers for LCD monitors. The resolution should be 1440><900 or higher.
Samir
Feb 28, 2011 | BenQ FP222W LCD Monitor
Pop up of monitor adjust screen
Hi, you probably have to set the correct resolution that fits on your monitor. The correct resolution is: 1920x1200 You can set it by right-clicking on your desktop and choosing "Screen Resolution" in Windows Vista and Windows 7. If you use Windows XP, right-click on your desktop and choose "Properties" Then open the rightmost tab to choose the resolution
Jul 19, 2010 | CTL 261UW 26Inch Wide Screen LCD Monitor...
Cant get the task bar
There are a few things you can try. 1st I would try to see if the the windows key on your keyboard will launch it. If it does launch make sure it is pinned to the bottom as the taskbar can be moved to either side or the top of your screen. If you do launch it but cannot see all of it your display resolution is not set correctly. If this is the case right click anywhere on the desktop and choose properties the tab all the way to the right will let change the screen resolution. If you need additional help please post back.
Please rate this solution if it has helped you.
Thanks, Gary
Jul 13, 2010 | Compaq Computers & Internet
Window Vista problem??
If you receive this error message or encounter difficulties when attempting to launch Pro Tools using Windows Vista disabling DEP may solve the problem.
This option disables "Data Execution Prevention", a feature of Windows that can sometimes cause errors. This won’t harm anything, but also isn’t always necessary.
How to Disable DEP:
1. Click "Start"
2. Click "All Programs"
3. Click "Accessories"
4. Right Click on "Command Prompt"
5. Left click on "Run as Administrator"
6. Click the Allow button if it asks you for permission
7. Type or copy and paste this into the command prompt window:
bcdedit.exe /set {current} nx AlwaysOff
8. Hit enter and you should see the confirmation: Operation Completed Successfully
9. Reboot and DEP should be off.
If you would like to re-enable DEP enter the following into the command prompt window:
bcdedit.exe /set {current} nx AlwaysOn
Hit enter and you should see the confirmation: Operation Completed Successfully. After restarting the computer, DEP will be re-enabled.
Nov 04, 2009 | Microsoft Windows Vista Home Premium with...
Namco SRS Street Racing Syndicate for Windows Logo
525 people viewed this question
Top Namco Video Game Consoles & Games Experts
Josh Whitehead
Josh Whitehead
EnergeeUK
Level 1 Expert
Are you a Namco Video Game Console and Game Expert? Answer questions, earn points and help others
