Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Won't do anything, no power
My WP Ulitmate Care II washing machine won't do anything. I started a load of laundry, it filled up and ran for a little and then stopped, still full of water. It has power to it and I have tried to move the dial around to empty the water and such, but nothing.
    President:
  • 1,430 Answers
This is usually caused by the lid switch. These are inexpensive and easy to replace. There are videos at www.appliancehelponline.com/servicemanual.html that will walk you thru testing and replacing this part. It may be a different model but the testing will be the same. You can also enter your model # for diagrams and illustrations of your specific model. All parts come with installation instructions. Not all models are available.
If this is not the problem check the motor coupler there is a video of that also.
Posted on May 10, 2010
My Whirlpool Ultimate Care II washing machine. When I load the laundry and start the machine, it will fill up with water, but it will not start the cycle without slamming the cover. Then once it starts it...
The switch on your door is a little bit worn out. Try adjusting it. If it fails, you may have to replace it. Check also the rubber gasket if it has become deformed or has sagged.
Sep 03, 2013 | Whirlpool Washing Machines
Whirlpool ultimate care ii won't spin
Possible that the drive is jammed , there is slipping or the motor is faulty. You need to check for free movement after disconnecting the power, if there is friction it must be reset.
Jan 21, 2013 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a whirlpool ultimate care II washer. It stopped in the middle of a load, full of water, and now it won't do anything. It won't drain, fill, move, or make any noises.
You will need to check the capacitor on the machine. It can be tested with a capacitance meter the easiest. It can be tested with a resistance meter, but this will tell you if the capacitor is shorted or open. It will not tell you the capacitive value if the component has drifted out of tolerance. You put the meter across the terminals and watch the display for counting up to infinity. This will occur quickly and disappear very quickly. Now reverse the leads on the terminals, (reverse the polarity). The same thing should happen, but a bit more pronounced. It will once again rise very quickly and go to an infinite reading. This tells you that the capacitor isn't shorted or open internally. Here is the capacitor to order if you should find it bad.
Nov 28, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Fabric softener isn't dispensing
it may be all gooed up. try pouring some very hot water into dispenser (fill it right up). let sit for half hour then do a load of laundry.plz rate-bozcro
Sep 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
MY WHIRLPOOL LAUNDRY MACHINE WILL NOT AGITATE
If it just fills and stops dead then its probably the door switch.If it fills and you hear the motor start and it makes a horrible noise then its probably the coupling between the motor and transmission. Theres also a slight chance its a stripped agitator spline
Apr 15, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Leaves white marks on coloured clothes
I'd try putting the machine on a hot fill wash, max water level put in half a cup of baking soda when the machine starts to washer turn it off and leave it to soak overnight, then let it finish the cycle the next day. Also make sure you tip some of the hot water down the beach dispenser and clean all around the top of the machine
Cheers
Mar 25, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
The washer just stopped pouring water. Only faint humming sound.
Cool!
How 'bout a FixYa for the effort, and let me know if you need anything else.
Feb 04, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Our Whirlpool washer won't drain
this machine has the pump directly atached to the pump assy, so if the motor is runnning your pump will drain water. more likely is that when you put the unit back together perhaps you didnt plug the lid switch assembly bak in. if there is no lid switch detected the unit will not drain or spin and when it gets to that mode it will simply stall out. no noise or anything. will fill, agitate but not spin and/or drain/ check the lid switch!
Nov 11, 2008 | Whirlpool Ultimate Care II GSQ9669L Top...
Whirlpool ultimate Care II problem
IF THE PROBLEM WITH THE AGITATOR IS THAT IT DOESNT HAVE THE POWER AS BEFORE IT SOUNDS LIKE THE AGITATOR DOGS NEED REPLACING.GOOD LUCK
Sep 10, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
The load won't start.
It sounds like you have a bad lid switch.It's an easy fix.You can get the part at your local appliance supply.
Dec 09, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
162 people viewed this question
Dan Webster
Dan Webster
Sal De
