Question about Echo 30.1CC Chainsaw With a 14 In.bar and Chain
How to wind starter rope recoil spring on echo srm-200 grass trim
Its all apart and m having problems winding spring. Can't get it back into housing. Is there a tool which will help , like a shaft with a notch on which the spring is compressed then slid into the housing?? Im going to try something like that while i await the answer. DW sends
  • 4 Answers
I would take it to the dealer. I know that might be money you don't want to spend but better than having a broken saw. You could try their FAQ section, it's pretty thorough: http://www.echo-usa.com/faqs/
Posted on Aug 24, 2010
How do I replace the pull starter cord
How do I replace Graeme, Check the attached links,instruction and videos on starter rope replacement. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
String Trimmer Starter Repair
String Trimmer Recoil Starter Replacement Echo String Trimmer Repair Part...
How to Wind Up or Rewind Starter Pull Rope Recoil Spring on Yard Pro 130A...
Part 1 3 Changing the Recoil Rope on Craftsman Model 358 791030
Apr 01, 2016 | Garden
How does the recoil spring,waher,2 hairpins pins,dog footand rope pulley get reassembeled?
the rope rotor will go on first, then the washer goes on, put the dogs in then put the spring on. insert the rope into the rotor, wind it up, feed the rope through the starter cover, carefully allow the rotor to wind in the rope a ways then put the handle on.
Dec 20, 2012 | Stihl MS 290 Chain Saw include 20" 50cm...
Starter rope replacement
recoil spring has slipped out of the hole.pull your starter rope out of the wind up mechanism, insert the spring latch on both ends and put back into housing. with a piece of 3/4 square stock or something the will fit mthe hole start to wind the mechanism spring up tight. with apair vishgrips lock it down so it does not move. insert your starter rope anr release the visegrips. the springwii recoil and pull the rope in.cut off excess rope. good luck
Oct 17, 2012 | Little Wonder 6032 10 Inch Pro Lawn Edger,...
Recoil spring is broken how to replace this, The rope is ok. Victor mower
take your rope off pulley then start winding pullet by hand till ti wont wind anymore line the pulley hole with the hole in the top cap slip the rope threw both holes knot the end threw the pulley hole slowly let the spring rewind the rope into houseing until it stops pull 1 foot out cut hold on to it slip threw your handle and knot it all done
Jul 02, 2012 | Briggs & Stratton Garden
How do you rewind the starter rope spring on an Echo PB-200 Blower.
assuming the spring has not broken behind the pulley causeing this problem you should be able to just re tension the spring, hook the starter rope into the slot in the side of the pulley, this will allow you to wind the pulley ( in the direction that the engine rotates ) up, when you have turned it enough times that the spring is coil bound ( be careful as the spring will be under a great deal of tension ) release the pulley then one whole turn, now unhook the starter rope and allow the spring to recoil ( dont just let it fly back ) and wind the rope in.
Feb 04, 2011 | Echo 30.1CC Chainsaw With a 14 In.bar and...
How to put recoil spring and pull rope in echo 2400 brush cutter
The recoil housing is held on by four screws around the housing on the corners, the pulley is held to the housing by one screw, all tension needs to relieved from the spring before removing the pulley. you can either cut the rope if you are replacing it, or you can pull some of the rope out, lining up the notch in the pulley with the outlet hole, catch the pulley and hold it from rewinding, and using the slack in the rope pull a section back in and up through the notch, the pulley can now unwind its tension without winding up the rope. Now remove the pulley, it should leave the spring in the housing. If the spring is very rusty it should be replaced, if you've sprung the spring out and have a mess, be prepared for a little fight, you can try hooking the outside of the spring in its tab in the housing and while forcibly holding that in place begin coiling the spring back in place, or try gathering the spring into a large coil and holding the coil with a pair of pliers begin shrinking the coil's diameter by winding it up from the center, last resort and the one I'd recommend if you're looking at a rusty spring, get a new one from an Echo dealer, it comes pre-wound and a nifty retaining clip, it simply slides into place in the housing, and as it goes into place the ring will pop loose. Now for the rope. Install the rope by putting the new piece in the spool and tying it off, thread the other end through the housing from the inside out, and put it into the handle and tie it off on that end, now place the spool into the housing being sure to engage the spring lightly, now install the screw so the spool doesn't come out, pull the slack rope up through the notch in the pulley and begin winding the pulley in the direction it turns when the rope is normally extended, after about 4 turns drop the rope out of the notch and let the pulley wind up the rope, if you have slack repeat a couple turns until there is no slack
Jul 04, 2010 | Echo Rapid Loader, Trimmer Head
I do not seem to be able to get spring tension correct when installing new spring in re-wind starter.
with no tension on spring install your pull rope. leave a loop between the pulley and grommet in housing. there is a notch in the pulley, locate the rope coming out of the pully in the notch and wind the pulley in the direction of pull approx 3 or 4 times. Pull the loop out with the starter handle and try starter. If the starter handle does not come up tight to housing reclaim the loop with needle nose and give the pulley one or two more winds and try again until handle is pulled in snug to housing. Be carefull not to wind to tight or will damage spring. Also be sure not too much rope on pulley- it will bind up in housing on recoil.
Nov 22, 2009 | Garden
Starter rope pulley will not pull the rope back into the leaf blower.
Most commonly, the recoil rope rewind spring is broken. However, inspect the recoil housing assembly first to make sure no debris or rope fragments have prevented the rope rotor from rewinding. Always remove the spring 'AS A LAST RESORT'. Many rewind problems can be solved by inspection of the rotor and not have to remove the spring. In case you do, I will include instructions on how to re-install.
1) remove the recoil housing
**NOTE: normally you DO NOT need to remove the rotor pulley or spring to replace the rope. This is the area that causes so many guys a lot of extra trouble
2) locate the string that is left and the hole it is threaded thru
3) determine how much string has broken off of the rope that came out
Note: if more than 1 inch is left, then the rope needs to be replaced
4) after rope is obtained, make sure both ends are melted to a point for easier threading thru handle and rope rotor
5) install the rope (with the handle installed on one end) thru the recoil housing and towards the rope rotor.
6) with the rotor free of tension, route the rope from the groove toward center and up thru the hole. Tie a knot in the end of the rope, leaving a 3/8" tail free.
7) wind the rotor in the direction of what the rope would pull (this will tighten the spring) until the spring is completely wound. remove 1/2 to 1 revolution, and then allow rope to wind onto the rotor until all rope is wound.
8) Pull the rope several times to position rope properly into rotor.
*note : there should be NO droop in the handle after released
If droop is evident, wind the rotor and rope 1 revolution tighter so there is no droop of handle when released
9) when unit is functioning proplerly, re-install housing onto unit
Nov 21, 2009 | Craftsman Garden
Wont coil back into its housing, so trimmer wont start. Has compression though
Hi, this a cut&paste from elswhere but it applies to your problem:
how to repair a recoil spring: whats missing is this, you should always wgear eye protection when dealing with springs of any kind.
remember safty first. :)
Remove the recoil shroud and take a look at the assembly.
You might have a broken spring or just a rope that has slipped out of the reel.
The spring usually breaks at one of the end tabs. If so, you will need to get a replacement spring and carefully wind that in, before re-assembling the rope reel. You might wish to replace the rope also, if it shows signs
of wear.
You will need to remove the entire cooling shroud. There should be 4 bolts on the sides. You might need to remove the fuel tank also. Pre-wind the recoil reel by hand [about 6 turns, to set the spring tension] and clamp it with Vise-Grip pliers. Remove the old rope. Thread
the new rope through the shroud housing eyelet and to the reel hub. Let the reel re-wind itself until it is full. If there is not enough spring tension you can wind it a couple of turns more by slipping the rope around
between the reel and shroud. Re-clamp the reel. Cut the rope to length and thread it though the handle. At all knots, burn and melt the rope with a
lighter to prevent untying. Re-assemble.
(special thanks to "Micheal"the author)
May 19, 2009 | Poulan Pro 25hht 25cc 22" Gas Hedge...
The recoil on my sears model 917.377610 is stopped recoiling. Looking for some help yo get it apart and fix the problem. I cannot get it off the engine
This usually happens at the most inopportune time. You go out mow the lawn, pull the rope and it comes out in your hand. Here's how to fix it yourself.
First, we'll talk about a simple rope replacement. In most cases you will have to remove the blower housing from the engine to get to the underside of the rewind starter where the rope is. We'll assume at this point that the spring is ok and you can just wind it back up again. You can check the spring by turning on the hub in a counter-clockwise direction and see if the spring gains tension. Do not try to remove the spring from its holder or you may end up having to take the mower in for service.
1. Remove the rope from around the hub. Since there is no tension, it should come right out. If you are lucky and it broke near one end, you can probably just re-use it. If it is badly frayed or too short, you will need to find a replacement at a local hardware store.
2. Attach the handle or tie a knot in one end of the rope so it will not wind all the way into the hub. You also may want to burn the rope ends to keep them from fraying and causing a problem in the future. Set the rope aside where you can grab it once you wind up the spring.
3. Wind the hub in a counter-clockwise direction using your thumb to keep it from unwinding, until the spring is tight. Then let it come back slightly so the rope hole in the starter housing lines up with the rope hole in the hub.
4. Stick the rope through both holes while holding the hub from unwinding. This is tricky because you don't want the hub to unwind on you before you have the rope secured in it. A pair of needle nose pliers or a small screwdriver or pick may help get the rope through.
5. Tie a half hitch knot in the rope after you have it through both holes. While holding the rope, release your hold on the hub and let the rope slowly pull itself back into the starter.
6. Put the blower housing back on and your ready to start the engine & mow.
Apr 19, 2009 | Garden
Echo 30.1CC Chainsaw With a 14 In.bar and Chain Logo
509 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
