Question about Microsoft Xbox 360 Console
How do i turn off family settings on my x box
Family settings don't seem to be highlighted on settings, enabling you to re-set them; why??
    New Friend:
How do I download apps for free
Posted on Aug 07, 2014
  • 27 Answers
It will only show up if you have a childs account for play on the console. once there is one then you can set it accordingly
Posted on May 10, 2010
How do I turn off closed captioning in HDMI? I've turned it off in tv mode but it still is on. It's annoying
What's the HDMI source? You need to disable the CC on the cable box or DVD player. These are only two of the possible HDMI sources that will provide the captions directly.
Without knowing the source, I can't tell you how to disable the captions. For many devices, you'll need to enter the settings. (Some cable/IPTV boxes will need a passcode to enter the settings menu.) On my IPTV box, the CC option is tucked into the Hardware Settings under Audio. On some satellite TV boxes, I found that the closed captioning had to be turned on at the primary box and that would enable secondary boxes to also show the captions. (It was an annoying feature for a family with one hard-of-hearing guest. They didn't need closed captions on the primary box. The specifics of their set-up and service meant that the secondary box couldn't display captions directly.)
Please add a comment with the HDMI source for specific information on turning off the captions that you currently see on that source device.
Nov 27, 2017 | Televison & Video
Which button turns on subtitles
If you have a digital Set-Top Box with digital cable service:
Using Navigator:
  1. Press the SETTINGS button on your remote.
  2. Scroll left or right to the Quick Settings category.
  3. Scroll down to select the Closed Captioning option and press SELECT.
  4. Scroll up or down to highlight On, On with Mute, or Off and press SELECT.
Using i-Guide:
  1. With your Set-Top Box currently on, push the POWER button on your Set-Top Box to turn it off.
  2. Immediately-within one second-push the MENU button on your remote. You should see a User Settingsmenu screen displayed.
  3. Use the arrows keys on the remote to highlight the Closed Caption option and press OK or SELECT on your remote to toggle Enable/Disable.
  4. Power on the Set-Top Box to return to watching TV.
Otherwise, if you have basic cable, please consult your television's user manual for instructions to turn on/off closed captioning.
Sep 17, 2016 | LG 32LG30 32 in. LCD HDTV
Touchpad does not work
Locate the function key (F1 to F12) that has the touchpad sign. This is often a rectangle with two smaller rectangles below it representing the touchpad and its two buttons.
Press FN + The touchpad button
If this doesn\'t work, then you need to do the following:
  • Navigate using the arrow keys to "Device Settings" or "Touchpad" or the similar option on your system and press "Enter."
  • Press the "Tab" key until the "Enable" option or a check box next to it highlights and then press "Enter." Press "Tab" again until you are highlighting "OK," and press "Enter." Your touchpad will be re-enabled.
    If no go, then update your touchpad driver by going to Computer (right click), Manage > device manager.
    Look for the touchpad driver and update. If you want to avoid these kinds of problem in the future, then install radarsync to automate the updating mechanism of your computer. It\'s automatic and you don\'t need to do anything.
    I hope this helps!
    Carlo
  • Dec 17, 2012 | Toshiba Computers & Internet
    Enabling closed captions on toshiba
    Download the user manual to this TV. It has all details. Click here to download it.
    Sep 16, 2012 | Toshiba 32A33 32" TV
    Can't get closed captioning to work on westinghouse 46" 4680 led tv
    What is the video source? Some set-top boxes send a closed caption signal that doesn't match the TV's CC interpreter. For those devices, you need to enable the captions on the set-top box.
    I know how to enable captions on one particular Dish satellite box. The steps will depend on if your TV is TV1 or TV2 connected to the box. If the TV is TV2, you need to set the box in Single mode (so both TVs are set to the same channel). This is done with the Mode button on the box itself (highlight Yes and click Select using the Dish remote when prompted to go to Single Mode). If the box is in Single Mode, you won't get a prompt but the unit will go to Dual mode. There is a small LED on the box to indicate Single or Dual mode.
    Next press Menu on the remote and go to Properties (9). Click Select and then navigate to Closed Captions (6). Click Select. Go to the Closed Caption On/Off line (1) and press the left arrow and then the up/down arrow to set to the captions to On. Press the right arrow and then Select with Done highlighted. Exit the Menu by hitting Cancel repeatedly.
    I hope this helps.
    Jul 24, 2012 | Westinghouse Televison & Video
    I need to turn off the mouse pad on my hp probook 4525s, do I need to install any special softwer or what to do?
    you do not need to install any special software.
    Here is what you have to do to turn off the mouse pad of your hp probook 4525s;
    Turn on your hp probook 4525s, wait till it boots completely.
    Click start,
    Scroll to Control Panel select Control Panel.
    Under control panel, (you will find a Mouse icon), click Mouse and a dialogue box will pop out.
    On the dialogue box, click "Device settings".
    Under device settings, you will find "Synaptics Touchpad..."
    Highlight the "Synaptics Touchpad..." by clicking on it once, then click disable.
    By now the mouse pad should be disabled. Apply the changes for it to take affect.
    To enable follow the same procedure and click enable using an external USB mouse.
    Yours sincerely.
    Elect_Comp.
    May 23, 2011 | HEWLETT-PACKARD HP 4525s ProBook
    How do I get my Emachine laptop mouse enabled again.
    You will need to double click on the Synaptics Touchpad icon on the system tray. Select Pointing Device Properties. Then you will click on Device Settings and select Settings. Next, you will highlight Tapping and check the Enable Tapping box in the properties window.
    Mar 30, 2011 | E-Machines M2350 Notebook
    I have a Compaq Presario CQ60 scroll touchpad stop working
    The notebook model you have is shipped with the Synaptics touchpad driver. Please follow the below steps to enable scrolling features:
    1. Open Control panel -> click on Mouse . It will display Mouse Properties dialog box.
    2. Under Mouse properties Window click the Device Settings tab
    3. Click on Device Settings -> Settings button. This will display the Properties for Synaptics TouchPad on PS/2 port.
    4. Follow the steps below to enable the Tapping Feature :
    Highlight Tapping in the Left hand side , and Check the Enable tapping in the Right hand box .
    5. Follow the steps below to enable Scroll feature:
    Highlight Virtual Scrolling in the Left hand side and Check both the boxes in the right hand side.
    6. Click OK .
    Alternatively you can anble scrolling by reinstalling touchpad driver.
    Touchpad driver for Vista:
    ftp://ftp.hp.com/pub/softpaq/sp39501-40000/sp39534.exe
    Touchpad driver for Windows 7:
    ftp://ftp.hp.com/pub/softpaq/sp44501-45000/sp44940.exe
    Mar 09, 2010 | Compaq Presario CQ60-220US PC Laptop
    My HP Pavilion Dv6 1030us the touchpad won't work.. It moves okay but It doesn't click! The buttons work fine, the only problem is with the touchpad and is driving me crazy! =/
    Try going to the control panel > mouse settings, Open the mouse settings and at the top of the page, there should be a tab for device settings. Click on this tab, It should bring up the touchpad device, highlight it and click on the settings button. When the settings window shows, scroll down to tapping, highlight tapping and make sure that the box is checked for tapping enabled. While you are in there go through all the other settings.
    Jan 06, 2010 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
    Sp4805 turns on by itself, direct tv picture will run for a short while then dorps out. I can't seem to pick a source? I tried my dvd player and it seemed to work normally. menu options are not highlighted...
    In the sources menu where you assign sources, the second selection from the bottom is where you enable/disable sources which can inhibit a source/input from working even if it is assigned. Also check mark the auto source enable box.
    If the input you are trying to use is not assigned or enabled many of the menu items are grayed out.
    A quick fix is selecting the "factory reset" in the menu as the default factory settings are such that all input's are set to work.
    Good Luck!
    SagerTronics
    Nov 13, 2009 | InFocus ScreenPlay 4805 Multimedia...
    Microsoft Xbox 360 Console Logo
    70 people viewed this question
    Top Microsoft Video Game Consoles & Games Experts
    Tre Elkins
    Martin Murray
    Stu Morris K
    Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
