Question about Whirlpool GS460 Gas Kitchen Range
Oven going off
The model number is #SF114PXSQ and is about 1.5 years old. The oven starts up and gets to temperature sometimes, but sometimes the oven shuts down and gives the fault of F-2. You can press cancel and restart it and it will work again for a while. Electronics ?
  • Whirlpool Master
  • 43,501 Answers
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Posted on May 11, 2010
What needs fixed in my built in Tappen oven, model 12-1263-30, when it is 90 degrees off?
Hello Wendy;
My name is Peter. I am a retired field service appliance technician.
The normal operation of a oven is the oven will rise 20-40 degrees above the set temperature and turn off. Then, when the oven temperature drops 20-40 degrees below the set temperature it will turn back on and cycle again. This is true except for the new accurate ovens.
Since you are getting heat your oven heating element is good.
You have a older oven.
Your problem is either the oven thermostat which cost over $200.00.
  • MFG Number 5303202782
25691587-pfxp0re3pkk4llvjptchxxrl-3-0.jpg Or, your oven control, which base on your oven age is no longer available.
Now, here are your choices:
1.) Take a chance and purchase the oven thermostat and install it. If this does not solve the problem you can return it less shipping and restocking charges.
2.) My professional recommendation is to put the old girl to rest.
You can:
a.) Go to a Sears Outlet (Scratch and Dent) Store, save a couple of hundred dollars on a new oven and still get a one year warrantee .
b.) Go to a used appliance store.
c.) Go to Habitat Stores - used appliance stores.
d.) Go to Second Chances Stores - Appliances removed from homes that were torn down.
Best of luck,
Peter
May 11, 2015 | Kitchen Ranges
Whirlpool oven keeps heading up
What is the model number of your unit?
Jun 26, 2013 | Ovens
Oven overheating / temp control wonky
Please double check that model number. That number is coming up as a refrigerator.
Feb 09, 2013 | Kitchen Ranges
Hotpoint BD 42 Oven, main oven fan turning slowly and oven is not heating up to temperature
Hi you will to have a tester , start off by checking power at the outlet , if you have the 220 volts then we need to check the elements inside the oven, you may a have a bad element and a bad fan , after checking power get bacl to me , also need model number and serial number
Dec 01, 2011 | Ovens
My Maytag oven works when it wants to when I heat it up it take forever and then sometimes it will stay heated at the temperature I set it at and sometimes it just quits and wont start heating again after...
The number one problem for these ovens is the ignitor. This one is your ignitor according to your model number When it is weak it is intermittent. Sometimes you can get the oven to work if you give it a swift kick. This video explains how it works:
The next likely suspect is your oven sensor. That is the link to your oven sensror according to the model number you posted. Here is a video which shows how to check it:
Jun 14, 2011 | Maytag Ovens
My Sharp microwave convection oven (R-967M / R96STM) cuts out during convection pre-heating and cooking, It appears it stops heating after 1 min. If the START button is pressed again the oven starts...
Also the fact it is a convection oven could mean the oven temperature sensor is not picking up the oven temp. it is not telling the machine it is there by the board seeing its resistance, the unit will shut off as a safety feature. The oven sees temperature by reading the value of a temperature dependent resistor. As the temperature changes so does the value of the component ( oven temp sensor) that way the unit determines the temperature inside the unit. Sometimes those sensors will break since they are in the area with the heat and moisture, they get old and break.
Aug 17, 2017 | Sharp Microwave Ovens
I have moved into a house about 11 years old. I started the self clean and now about two hours into it an alarm is going off signifying "F2 door locked". Can't turn off alarm :-( Don't know part...
F2 During CLEAN The Control is senses oven temperature above 915F-930F. If actual over temperature condition occurred: Look for welded relay contacts. If this happens, replace oven control (also called clock or ERC). If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective. Check door lock switches. Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature.
Jun 03, 2009 | GE Ovens
Claibrating the temperature of a GE gas oven
First of all, do not use the oven thermometers from a grocery store. they can be off by 20 degrees or more. These directions may help you for electronically controlled ovens. The older manually controlled ovens have a small screw head in the center of the oven temperature knob that can be adjusted in usually 10 degree increments.
To Adjust the Thermostat
Touch the Bake and Broil Hi/Lo pads
at the same time for 3 seconds until the
display shows SF.
Touch the Bake pad. A two digit number
shows in the display.
Touch Bake once to decrease (-)
the oven temperature, or twice to
increase (+).
The oven temperature can be adjusted
up as much as 35°F. or down as much
as 35°F. Touch the number pads the
same way you read them. For example,
to change the oven temperature 15°F,
touch 1 and 5.
When you have made the adjustment,
touch the Start pad to go back to the
time of day display. Use your oven as
you would normally.
NOTE: The thermostat adjustment for Baking
will also affect Convection Baking or Convection Roasting.
Nov 22, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven does not maintain temperature. Part 2
sometimes when they get hot that is when they fail
Sep 18, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Whirlpool GS460 Gas Kitchen Range Logo
174 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
