Question about Maytag Neptune FAV6800AW Top Load Washer
The clutch assembly is stuck although the cluthch
The clutch assembly is stuck although the clutch bolt has been removed on my FAV6800.
  • 526 Answers
It sounds like the Spinner Shaft Coupler is severely rusted into the Clutch One-Way Roller clutches bearing in the Clutch Pulley and the Spinner Shaft. And if your machine is using the Upper One-Way Roller clutches bearing ring that may be severely rusted to the Spinner Shaft also.
Did you read my Clutch Fix post to disassemble and remove the clutch pulley assembly?
As you can see it’s a tight work area. You may have to rotate the Outer Tub out of the machine to ease removal. I suspect you could have a Tub Seal leak issue. I would lay the machine on it’s back protecting the drain hose exit and tap lightly with a hammer and see if you can free.
Let me know if I can help……Rich
Posted on May 10, 2010
  • FAV6800A FAV9800A
    FAV6800A FAV9800A May 10, 2010
    What are the 1st digits of your serial number?
Tip
2004 Hyundai Tiburon Clutch.
First you need to remove the Transaxle.
Manual Transaxle System REMOVAL
1. Remove the engine cover.
2. Remove the battery terminal.
3. Remove the air duct.
4. Remove the battery tray.
5. Remove the air cleaner.
(1) Upper
(2) Lower
6. Remove the back-up lamp switch.
7. After removing the CKP sensor, O2 sensor and oil pressure switch wiring bracket, separate the connectors.
8. Remove the brake fluid leveling sensor connector.
9. Remove the speedometer driven gear connector.
10. Remove the clutch release cylinder mounting bolt.
11. Remove the cotter pin of the shift cable (transaxle side).
12. Remove the cotter pin of the select cable. (transaxle side)
13. Remove the clip of the shift cable (transaxle side).
14. Remove the clip of the select cable (transaxle side).
15. Separate the steering column shaft joint.
16. Separate the power steering oil pump hose.
Be careful not to leak after separating.
17. Separate the hose after removing the clip of the power steering return hose.
18. Remove the upper connecting transaxle bolt.
19. Separate the start motor.
20. Install the engine support fixture.
21. After removing the tire, remove the caliper.
22. Remove the transaxle side cover.
23. Remove the transaxle side under cover.
24. Separate the tie rod end.
25. Remove the wheel speed sensor and the knuckle mounting bolt.
26. Drain the oil.
27. Remove the transaxle mounting bracket.
(1) Insulator bolt
(2) Body side mounting bolt (Upper)
(3) Body side mounting bolt (Side)
(4) Transaxle side mounting bolt.
28. Remove the front roll stopper.
(1) Insulator bolt
(2) Stopper bolt (Upper)
(3) Stopper bolt (Lower)
29. Remove the rear roll stopper.
(1) Insulator bolt
(2) Stopper bolt
30. Remove the drive shaft.
31. Remove the front muffler.
32. Remove the sub frame mounting bolt.
33. Install the transaxle jack.
34. Remove the transaxle lower mounting bolt to the engine.
35. Remove the transaxle assembly.
INSTALLATION
Installation is the reverse of the removal.
Then inspect and replace the clutch place and pressure plate.
INSTALLATION
1. Apply multipurpose grease to the release bearing contact surfaces and the release cylinder contact surface of the clutch release fork assembly.
When installing the clutch, apply grease to each part, but be careful not to apply excessive grease. It can cause clutch slippage and judder.
2. Apply multipurpose grease into the groove of the release bearing.
3. Apply multipurpose grease to the clutch release lever fulcrum contact surface of the clutch release fork assembly.
4. Clean the surfaces of the flywheel and pressure plate thoroughly with fine sandpaper or crocus cloth, and make certain that all oil or grease has been removed.
5. Apply a small amount of multipurpose grease to the clutch disc splines and input shaft splines.
Do not apply more grease than necessary. Too much grease could cause clutch slip or judder.
6. Using the special tool, install the clutch disc to the flywheel. When installing the clutch disc, be sure that the surface having the manufactures stamp is towards the pressure plate side.
7. Install the the clutch cover assembly onto the flywheel and install the six (6) bolts through the clutch cover into the flywheel.
8. Tighten the bolts by one or two turns at a time, in succession, to avoid bending the cover flange.
If a special tool is not available, tighten the bolt temporarily and then torque to specification in diagonal torquing sequence indicated below.
TIGHTENING TORQUE
Single mass flywheel:
15~22 N·m (150~220 kg·cm, 11~16 lb·ft)
Dual mass flywheel:
20~27 N·m (200~270 kg·cm, 14~19 lb·ft)
9. Remove the special tool.
10. Install the transaxle. (Refer to GROUP - Manual Transaxle Assembly)
11. Adjust the clutch pedal free-play. (See CH-6)
INSPECTION
1. Check the diaphragm spring end for wear and uneven height.
Replace if wear is evident or height difference exceeds the limit.
2. Check the pressure plate surface for wear, cracks and color change.
3. Check the rivets for looseness and replace the clutch cover assembly if necessary.
CLUTCH DISC
1. Check the clutch facing for loose rivets, uneven contact, deterioration due to seizure, adhesion of oil, or grease, and replace the clutch disc if defective.
2. Measure the rivet sink and replace the clutch disc if it is out of specification
3. Check for torsion spring play and damage and if defective, replace the clutch disc.
4. Clean the splines on the input shaft and install the clutch disc.
If the disc does not slide smoothly or if play is excessive, replace the clutch disc and/or the input shaft.
CLUTCH RELEASE BEARING
The release bearing is packed with grease. Do not use cleaning solvent or oil.
1. Check the bearing for seizure, damage or abnormal noise. Also check the diaphragm spring contacting points for wear.
2. Replace the bearing if the release fork contacting points are worn abnormally.
INSTALLATION
Then remove pressure plate and Clutch plate.
1. Insert the special tool (that came with your clutch kit) in the clutch disc to prevent the disc from falling.
2. Loosen the bolts that attach the clutch cover to the flywheel in a star pattern.
3. Loosen the bolts in succession, one or two turns at a time, to avoid bending the cover flange.
on Jan 13, 2010 | Hyundai Tiburon Cars & Trucks
How to replace the clutch fan on a Isuzu rodeo
no year, engine (size) stated.
on all cars its the same,
gain access to it, (shrouds,etc, depands on how big your arms are.)
off the fan belt. (release tension-er.)
off the fan and clutch replace new clutch to old fan/.
put back
set tension on belt.
the FSM steps for fan off are below (buy the FSM and read it?)
guess 1995...
  1. the fan is first then clutch.
  2. Disconnect the negative battery cable.
  3. Remove the upper radiator shroud and, if desired for additional clearance, remove the radiator from the vehicle.
  4. Although it is not necessary in most cases, the radiator may be removed from the vehicle for easier access to the fan
  5. retainers. If the radiator is left in place, use extra caution to prevent damage to the fragile radiator fins.
  6. Remove the fan assembly attaching nuts (clutch type) or bolts (standard type), then remove the fan assembly from the engine.
  7. Some vehicles use a space between the fan and the water pump pulley. If used, be sure to retain the spacer for
  8. installation.
  9. If necessary, the clutch may be removed from the fan by removing the attaching nuts or bolts (as applicable).
  10. end remove.
Nov 12, 2015 | Isuzu Cars & Trucks
Forward or reverse will not engage - cluthch problem?
happened to me. found loose drive clutch cable. Adjustment bolt is just under the handlebar, attached to the cable. adjusting lock nut came loose and tension adjusting bolt spun out from vibration. retighten sleeve onto adjustment bolt and see if drive drive will engage. IF NOT.......look to other end of cable......UGH!
Mar 04, 2014 | Tecumseh Snowblower Snow Blower Starter...
Cluthch wont disengauge
The ramps inside the clutch are worn beyond use. You need a special bolt to pull clutch. This is a dealer job. The puller bolt costs about $45.00 and you cannot buy the parts needed without being a dealer.
Feb 11, 2014 | John Deere 2006 Buck 500
Truck still moves with clutch pressed in.
I had this problem on my 2600i Mazda.
Check your clutch resevoir--if this is low or empty this is the problem--there is a leak. The leak is usually the clutch cylinder (has a bleeder valve) which is bolted to the transmission. Follow the metal lines from the reservoir down by the tranny should be a bolt or two and a bleeder valve ($20 or so). Bleed like you would your brakes.
Hope this helps--
Jun 06, 2017 | Ford F-250 Cars & Trucks
I need to remove the cooling fan shroud from my 1995 Lincoln Continental. How is the easiest way to go about this?
Engine Fan REMOVAL & INSTALLATION 3.8L Engines
  1. Disconnect the negative battery cable.
  2. Remove the radiator upper sight shield.
  3. Disengage the electrical connector, then remove the integrated relay control/constant control relay module assembly located on the radiator support.
  4. Disconnect the fan electrical connector. Fig. 1: Disengage the fan electrical connector 86873115.jpg
  5. If necessary, remove the air bag crash sensor.
  6. Unbolt the fan/shroud assembly from the radiator and remove. Fig. 2: Unbolt the fan assembly from the radiator 86873116.jpg
    Fig. 3: Remove the fan from the engine 86873117.jpg
    Fig. 4: Slide the fan as an assembly up and away from the radiator. Be careful not to dislodge the mounting stud on the left side. 93143p56.jpg
  7. Remove the retainer and the fan from the motor shaft and unbolt the fan motor from the shroud.
  8. Installation is the reverse of the removal procedures. Tighten the fan shroud retaining bolt to 23–33 inch lbs. (2.6–3.7 Nm). Tighten the fan shroud retaining nut to 71–106 inch lbs. (8–12 Nm). Fig. 5: Constant control relay module location — 3.8L engines 86873118.gif
4.6L Engine
  1. Loosen the fan clutch-mounting shaft from the water pump hub.
  2. Loosen the fan shroud from its radiator mounting and remove the lower hose from the shroud.
  3. Lift the fan and clutch assembly and the fan shroud from the vehicle.
  4. If necessary, remove the fan-to-fan clutch retaining bolts and separate the fan from the fan clutch. CAUTION
    Closely examine the fan for cracks or separation, to avoid the possibility of personal injury or vehicle damage. To install:
  5. Assemble the fan and fan clutch. Tighten the retaining bolts to 15–20 ft. lbs. (20–27 Nm).
  6. Install the fan and clutch assembly and the fan shroud. Mount the fan clutch shaft to the water pump hub and tighten to 37–46 ft. lbs. (50–62 Nm).
  7. Slip the shroud into the lower mounting clips and install the shroud retaining screws. Fig. 6: Fan and fan clutch assembly — 4.6L engine 84173064.jpg
5.0L Engines
  1. Loosen the fan clutch-to-water pump hub retaining bolts.
  2. If necessary, remove the drive belt from the water pump pulley.
  3. Remove the fan shroud upper retaining screws. Lift the shroud to disengage it from the lower retaining clips.
  4. Remove the fan clutch-to-water pump hub bolts and remove the fan and clutch assembly and the fan shroud.
  5. If necessary, remove the fan-to-fan clutch retaining bolts and separate the fan from the fan clutch. CAUTION
  6. Assemble the fan and fan clutch. Tighten the retaining bolts evenly and alternately to 12–18 ft. lbs. (16–24 Nm).
  7. Install the fan and clutch assembly and the fan shroud.
  8. Install the fan clutch-to-water pump hub bolts.
  9. Slip the shroud into the lower mounting clips and install the shroud retaining screws.
  10. If removed, install the water pump drive pulley and adjust the belt tension; refer to Section 1.
  11. Tighten the fan clutch-to-water pump hub bolts evenly and alternately to 15–22 ft. lbs. (20–27 Nm). Recheck the belt tension.
Jul 14, 2010 | 1995 Lincoln Continental
I am trying to remove the bolt for the fan clutch assembly on a 97 chevy blazer.
  1. 1 Remove the fan and clutch assembly from the fan's pulley. The assembly attaches to the pulley with several bolts on the circumference of the pulley. To remove the bolts, position an open-end wrench over each bolt and turn each bolt in a counterclockwise direction while grasping one of the fan's blades to prevent the fan from turning with the bolt.
  2. Step 2 Pull the fan and clutch assembly away from the engine, then lift the assembly out of the engine's compartment.
  3. Step 3 Remove the bolts which hold the fan to the clutch. The bolts are located on the back of the fan, and can be removed with a open-end wrench.
  4. Step 4 Place the fan and clutch assembly on a flat surface with the clutch facing up, then pull the clutch straight up to disengage it from the fan.
Nov 12, 2009 | 1997 Chevrolet Blazer
Can a shade tree mechanic change the clutch in '97 mitsubishi 3000?
Removal (3000GT AWD)
1. Remove air cleaner cover, air hoses and vacuum pipe. Remove air cleaner, intake hose, battery, battery
tray and washer tank.
2. Disconnect transaxle control cables and speedometer cable. Raise and support vehicle.
3. Remove both inner fender splash shields. Remove clutch tube bracket and disconnect clutch release
cylinder (including clutch damper assembly on FWD models) and wire aside. Support transaxle assembly
with jack and disconnect upper transaxle mount. Remove mount, bracket, plug and stoppers.
4. Remove transaxle assembly upper coupling bolts. Disconnect tie rod ends and lower arm ball joints.
Remove right support member, starter cover (if equipped) and starter.
5. Remove left side bearing bracket mounting bolts and pry left axle shaft from transaxle. Wire left axle
shaft and inner shaft assembly aside. Pry right axle shaft from transaxle and wire aside.
6. Remove front bank side and rear bank side transaxle stays. Support transaxle assembly with a
transmission jack. Remove transaxle assembly lower coupling bolts and lower transaxle from vehicle.
7. Insert a clutch alining tool to prevent pressure plate and clutch disc from falling. Loosen pressure plate
bolts gradually in a crisscross pattern to avoid warping pressure plate flange. Remove pressure plate and
clutch disc.
May 14, 2008 | 1999 Mitsubishi 3000GT
Maytag Neptune FAV6800AW Top Load Washer Logo
162 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
